Old 26th October 2025, 02:48 PM   #1
Pendita65
Default Madura Keris?
Hi all,
After lurking for the last six months I picked up this 9 luk Keris yesterday. It's I need of some serious TLC. It sure can use a good cleaning of the rust. I don't know a lot about it what I find interesting is that the wilah is standing in an angle from the Hilt. The Warangka is a model i have seen before but don't know how it is called. And my guess is that the Keris is from Madura. There is pamor to be seen but after derusting it might be better visible.
Hope someone can provide me some more info about this Keris.
Thnx for now and regards
Martin
Pendita65 is offline   Reply With Quote
Old 26th October 2025, 04:34 PM   #2
Hi Martin,
Jep, the sarung is Madurese. But like you I can't name it exactly.
Pics of my example attached.
Old 26th October 2025, 04:45 PM   #3
All three I've have/had (one I sold) and one from Alan G. Maisey.
Old 26th October 2025, 09:10 PM   #4
Yes, Madura, dress is a sandang walikat style.
It is possible that in Madura, sandang walikat might be known by a different name, but if it is, I do not know that name.
Old 26th October 2025, 11:26 PM   #5
Pendita65
Thank you both so much, for the information. and i was also wondering the hilt /hulu when you hold it straight up the wilah is really under an angle, that is different than most of the keris i have.
Maybe a stupid question but has it a name? And if i am right it has 9 luk?
Regards, Martin
Old 26th October 2025, 11:51 PM   #6
Jep, I count 9 luk.
Old 27th October 2025, 12:37 PM   #7
Did you mean a dhapur name?
The dhapur names that are generally known come from a pakem, or guide-book that was produced as a reference to dhapurs as they were known in Surakarta.
It is really only accurate for Surakarta, but we do tend to use those names for all of Jawa.
This keris is from Madura, & it possibly has --- or had --- a unique Madura name, which might still be known by some people in Madura, but which I do not know.
Then we have another problem with the eroded condition of this keris. Determination of a dhapur depends upon the presence or absence of specific characteristics, & this keris is so badly eroded that we cannot be sure exactly what characteristics were present when it was new.
However, we are all free to name a keris which is in our care with its own name.
Old 27th October 2025, 08:37 PM   #8
Pendita65
Thank you Mr. Maisey and Detlef,
yes i was curious what the dhapur would be, but most of the time the wilah is more in line with the hulu or ukiran. and this keris the wilah goes with a bevel arround 50 degrees.
So i was curious if this has a name in determinating a Keris.
Regards, Martin
Old 29th October 2025, 03:37 AM   #9
This is actually a pretty good question Martin --- I think of "good questions" as ones that I need to think about before I can respond to, and although I could have given a quick, off-the-cuff response to this question, I've been thinking about how best I should respond. I think I might now be able to do so.
In Jawa, when we refer to the angle of a keris blade, we refer to that as the "condong campur" of the blade.
"condong campur" applied to the keris & in Bahasa Indonesia can be understood as a "confused angle", actual translation is campur = mixed/confused, condong = leaning; used in Basa Jawa context the understanding is similar but the actual translation is campur = to mix, condhong = in agreement with.
So the blade angle in this keris is bit too "condong campur".
Now, in the Surakarta Pakem, there is a straight keris that is Dhapur Condhong Campur. It has not been drawn with an extreme blade angle, the only remarkable thing about it is that it has sogokan for the full length of the blade. There is also a waved keris that is given as Condhong Campur.
So there you have an explanation of how we would think of this keris in Jawa, but it still does not give you a dhapur name for it, and in my opinion, the blade is far too worn for us to be able to determine exactly how it looked when new.
Footnote: in fact the practical application of this extreme angle is an attempt at an ergonomic application, the angle moves the blade point to a position more favourable to centering on an opponent's body. Now that doesn't matter much today, but it might have provided some slight advantage when keris were used to end life.
Old 29th October 2025, 08:30 AM   #10
Pendita65
Dear Mr. Maisey,
thank you again for the way you took the time to think about my question and giving an good explanation. Step by step i learn new things about the Keris and it is an never ending story i guess in getting into the depth of the keris and its meanings in execution and the mystical side of it.
I just aquired the book by David Gallas about the mystical side of the Keris.
called: Pusaka Pangruwating Jiwa.
So hope to gain more insight into the world of Keris.
Have a nice day and thank you so much again,
Regards, Martin
Old 29th October 2025, 08:37 AM   #11
You're most welcome Martin.
Old 30th October 2025, 05:09 AM   #12
RobT
RobT's Avatar
Default Condong Lelah Discussion
Regarding Alan Maisey’s footnote,
The practical reason for this angle (Condong Leleh) was discussed in this thread (http://vikingsword.com/vb/showthread.php?t=5174) started by Michel on Sept. 3, 2007. Although I fenced sabre, I know that the blade angle on foils was considered so advantageous that the judges would rigorously check and limit the angle amount before and during matches.
Sincerely,
RobT
Old 30th October 2025, 08:12 AM   #13
Rob, you've used 'condong leleh' rather than 'condong campur', I think most people would agree with this usage, in fact I used to use leleh rather campur all the time myself.
A few months ago I was pulled up on this usage by a Javanese gentleman whom I regard as pretty well educated in matters revolving around the keris, he made the point that 'condong leleh' implies a 'soft angle' whilst 'condong campur' implies an angle that is not quite right. What he said made sense to me, even though the more usual usage is as you have given it.
Currently I'm using 'campur' & trying to find out how many people disagree with this. Currently its about a 50/50 split.
Old 24th November 2025, 09:33 PM   #14
Jayaningkurnia
I understand in Madura, sandang walikat warangka are often used as the primary sandangan and more ornately decorated. There are several types/designs, among other Jurigan (the most common Sumenep style often paired with donoreko hilt), Saron, Nam-Nam, etc.
Jayaningkurnia is offline   Reply With Quote
Old 26th November 2025, 07:42 AM   #15
Yes, some keris dress used in Madura is highly ornamented, my memory is that this ornamentation is not limited to sandang walikat form.
I do not understand the word "jurigan" in this context, can you please clarify.
Thank you.
Old 6th March 2026, 03:30 AM   #16
Jayaningkurnia
Mr. Maisey, I was referring to the variations in the shape of the Madurese warangka.
To my understanding, Madura, or in particular Sumenep which is considered to be the older (sepuh) cultural center there, has several common designs for warangka. Among other there are: 'daunan' ('leaves', akin to java-style ladrang, albeit more like 'capu'), dhang-odhangan ('shrimp', akin to jogja-style gayaman, though alot more shrimp-like in shape), and jurigan (more symmetrical, western-style scabbard often featuring the sumenep's crest or jaran panoleh, like what is shown at the beginning of this thread - though this one is rather simple).
There's a paper written by students from Universitas Negeri Surabaya titled "KARAKTERISTIK KERIS SUMENEP KOLEKSI MOCH. MANSHUR HIDAYAT" by Ahmad Erwin Siswanto and Nunuk Giari Murwandani on this topic - worth reading if you are keen on Madurese/Sumenep krises.
Old 7th March 2026, 08:56 PM   #17
Thank you Jaya, I've had a look at that paper, just skimmed it, not yet read.
It appears to be a useful piece of work.
