Old 21st September 2025, 06:27 PM   #1
Sakalord364
Default Is Wootz steel more difficult to work with and perforate then Regular steel?
Here is an Afghan private purchase sword from the early 1900s that was posted here before, the Handguard/Hilt is made entirely of Wootz, and the perforated openwork design on the guard resembles the the steel gothic hilted swords of the British.
I was curious because the openwork designs/perforations (such as the triangles etc.) on the Afghan hilt are rather rough and asymmetrical when compared to the British examples.
Was this because the British hilts were mass produced according to a set pattern, and perforated with specialized tools, thus the decorative perforations on the hilt would be neater and more uniform, as opposed to the Afghan example which was a unique one off piece made by hand?
Or perhaps was this because Wootz steel is harder to work with and perforate and thus cracked and was much harder to pierce when compared to the sheet steel I’m assuming the British makers used for their hilts?
Sakalord364 is offline   Reply With Quote
Old 25th September 2025, 01:29 AM   #2
fennec
You right when you say that wootz is harder to work, but in my mind only at the forging steps.. Once finished, you can work it.
See those wide koftgari parts, and other kind of inlay. those was first carved with other tools, obviously harder than the sword (that has a heat treat for softening it, not too hard, or too brittle). Wootz is quite "soft" once correctly forged. Only cementites inclusions gives it its hardenss, but possibly dont make the engraving harder (only supposing, never carved wootz haha).
So I dont think that its the reason of such work, even I'm not sure the gard is also made with wootz
fennec is offline   Reply With Quote
Old 26th September 2025, 10:45 AM   #3
19c crucible steel can look a lot like wootz, but isn't I've heard if you over-work the forging you can lose the patterning as it evens out or removes the inclusions that cause it. India ran out of the ore that wootz was made with, and then lost the techniques passed down verbally thru the earlier ages on how to work it. In reality, modern steels are more homogenous and have better properties for swords, but wootz has its mystical appeal. Pattern welded steel or that early crucible steel isn't wootz. There is a Russian who says he's able to duplicate wootz, i'm not sure if that has been verified.
Old 27th September 2025, 01:03 AM   #4
I've not engraved into wootz but into pattern welded steel. When I hit a harder steel in the pattern, the engraving gets more difficult.
Wootz is much smaller and so I'm not sure, though I can agree that the pearlite particles could make things more difficult as well.
