I recently procured some items that were listed as "Inuit Root Diggers," and that made sense, however when I got the items, they were quite large, especially the Adze.I haven't seen( my knowledge on this subject is even more limited than that on others), any Eskimo implements this large and as such I was wondering if they could belong to any other group of people?
They seem to be made of whale or walrus bone. The largest piece measures 20" x 4". |
I can't figure out why the fish bone part has so many cuts and holes, perhaps it's a multi-use tool which would make sense in a semi nomadic culture in the time period it came from.
It looks very very old. |
My theory is that there was a wooden haft that went through the middle of the heavy hoe shaped implement and that it was lashed onto the shaft, through the cleat, pulling it down, locking it to the handle and securing it against any downward strikes.This is just my guess, not based on anything.
The only hole that goes all the way through is the one for the handle. |
If you can tell if they are bone and not ivory they could be from Tierra del Fuego. The side lashing I believe is more of a South American method rather than Inuit. Just a suggest no expert. They are a rather cool collection of artifact and if from Tierra del Fuego I would think them rather rare too. Inuit ice axes.
From my view,I definitely believe them to be bone.The lashing looks like it could work on my piece, the only exception is that my implement has a provision for a haft to be inserted inside it whereas the examples you provided,I believe are laid on top of the handle and lashed onto it.
I think Drac's item is Walrus Ivory. I only used Fish Bone as a euphemism for the material. If you look at the end that is narrower, where it is cut, you can see the dentine core of the tusk.
Rick, are you talking about the smaller piece or both of them?
I'm getting a bit confused here, there is only one piece of Bone/Tusk, correct?
At the narrow end where the square hole is, if you look where the narrow end is cut off, the end grain seems to show the dentine as a different pattern as seen in the picture below. While doing a bit of a search for like tools, I came across a picture of very similar Inuit items. All of the descriptions of these were identified as petrified tusk. I should have saved the photos, but I didn't. Maybe an image search for Inuit ice axe will provide the picture again. https://walrusivory.org/wp-content/u...py-980x784.jpg Last edited by Rick; 27th August 2025 at 04:26 PM. Reason: not enough coffee, or maybe too much |
With the exception of the wooden handle, there are 2 pcs. that are either bone or tusk.
