Old 18th July 2025, 02:22 PM   #1
LeonymusBosch
LeonymusBosch's Avatar
Default Stone cannonball?
Hello everyone,
I was recently asked to identify a possible cannonball and I would like some more opinions on this.
The finder said "iron cannonball, 16th c. removed from ground and walls of an Ottoman fort"
First off all, the ball is made of stone, not iron. It's 72 cm in circumference and 24 cm diameter and weighs 16 kg. The size of it makes it impossible to be iron or lead as it would have to be much heavier if solid. If it were iron, the only possibility for that kind of weight/size ratio for an iron one, the ball would have to be hollow, made as a shell for 18/19th c. howitzers and mortars. This is definitely not it, it's not perfectly round, it looks like stone with parts left unfinished, not magnetic ofc and there were certainly no large siege or rather fort mortars at the find location.
Name:  WhatsApp Image 2025-07-17 at 10.14.49 (1).jpg
Name:  WhatsApp Image 2025-07-17 at 10.14.49 (2).jpg
My thinking is this could possibly not be a cannonball at all, or it could be for late 15th or 16th century cannons. If yes, likely Ottoman as they had cannons large enough which would fire projectiles of this size, and there were multiple battles and sieges nearby in mid to late 16th c. but I'm unsure if they actually brought them to that location.
What do you think?
LeonymusBosch is offline   Reply With Quote
Old 18th July 2025, 02:32 PM   #2
LeonymusBosch
Could it be a catapult projectile?
Old 18th July 2025, 11:53 PM   #3
adrian
I think that it is highly likely to be a stone cannonball, often the obvious answer is the correct one. These took some work to get sufficiently round, and catapults etc did not require such uniformity for their projectiles. Likewise, if it were part of a masonry work of art or decoration, that has broken away, there would be some evidence of that.
Below from my collection, a 6" dia (15cm) stone shot weighing 10.5lbs recovered from the Malacca Strait, it is probably Portuguese, and three smaller examples about 4" dia, from an 16th century English shipwreck.
Old 21st July 2025, 12:36 AM   #4
M ELEY
I thought I'd post my "balls" as well-
I've had them for a number of years, but never posted them as I wasn't positively sure they were really stone cannon balls. Over the couse of years, I decided to approach them from a different angle, basically ruling out what they were not! I know they aren't Native American game balls for play, as they are perfectly smooth and larger than the typical Indian ball. They are not stone mill balls because THERE ARE NO SUCH THING! Yes, there were iron mill balls that are confused with iron cannon balls, but the only stone grist tools were stone wheels (I've done a lot of research, but if I'm wrong, let me know!). I don't buy that they were simply some hoddyist's project, because they are made from plain granite and creating them would have been very time-consuming! And they are not to my knowledge Victorean 'garden balls' as the ones I've seen of those are smaller and not perfectly smooth. Mine are about the size of a baseball or slightly larger. I've seen pics of very similar cannon balls dating from around the time of the English Civil War ca, 1650's.
Stone cannon balls became obsolete in the mid-17th century when used against castles and stone forts. They continued to be used, however, in the maritime setting. Stone balls fired ship-to-ship would tear holes through the hull, creating a shower of stone shards and wood shivers. By the time of the early 18th c, ship's hulls became thicker and the stone cannon balls were no longer viable.
Old 21st July 2025, 07:29 AM   #5
LeonymusBosch
Thanks to the both of you!
I was also trying to rule out every option before conceding to myself that it could be a cannonball.
Yeah, catapults didn't really need to smooth the surface like that, that's true.
Someone brought a really big cannon to siege the small fort.
Old 22nd July 2025, 01:14 AM   #6
Radboud
Or it was fired from a mortar.
Old 25th July 2025, 08:12 AM   #7
LeonymusBosch
actually yeah, more likely
Old 25th July 2025, 11:56 AM   #8
Ed
Ed's Avatar
You might get a vessel of the appropriate size, pour in enough water to cover the object (before you put it in). See what the level is by making a mark on the side.
Insert your ball and see how much water is displaced. Calculate the volume of the displaced water.
Like this ... diameter of vessel is 6 inches.
When you immerse your ball the level goes up 2 inches.
Ergo the increase in volume is expressed by π rē h
Pi = 3.14
r=6/2=3
rsqr=9
H=2
Soooooo the volume of your ball is 3.14 x 9 x 2 = 56.52 cubic inches
Now weigh the sucker. Lets say it is 4 lbs
The density is 4/56.52 = 0.07 lbs/cubic inch.
Now hunt around for a density table .... here is one
Seems this particular ball is magnesium.
I have just provided you with hours of fun!!!
Ed is offline   Reply With Quote
Tags
cannon, cannonball, croatia, habsburg, ottoman
