Old 6th June 2025, 03:02 PM   #31
Pertinax
Pertinax's Avatar
[QUOTE=Marc M.;297764] I also thought I read that the mandau's were kept in the men's house, longhouse. No idea if this is correct, can't find the post again.
A.W. Nieuwenhuis «Quer Durch Borneo»
Ergebnisse seiner Reisen in den Jahren 1894, 1896-97 und 1898-1900; Erster Teil
Chapter VII.
...The main weapons of the Kayan are the sword (malat) and the spear (bakir); the blowgun (se̥put) plays only a secondary role as a weapon; only a few understand how to use it at all, and no true Kayan is capable of collecting and preparing poison for arrows. It is mainly descendants of the Punan among them who prefer the blowgun, the original weapon of the nomadic tribes. The sword, on the other hand, is not only the most important weapon for the Kayan in war, but also the most important item in daily life, rivaled only by the small knife (nju, Fig. h, Plate: Swords of the Mendalam Kayan), which is always carried in a special container on the inside of the scabbard. Any work that cannot be performed with a knife or axe is performed by the Kayan with his sword, which therefore never leaves his hand. When working in the fields, however, he uses a simple sword made for this purpose to chop down branches and undergrowth. However, when on long journeys, he uses his war sword both against the advancing enemy and for hewing boards and chopping firewood. No Kayan takes two kinds of sword on expeditions, but everyone ensures that his own can serve all purposes. Therefore, both at Kapuas and Mahakam, simple but well-crafted blades are generally preferred for serious military campaigns, while the beautiful ones decorated with inlaid copper and silver serve only as highly valued ceremonial objects. Only a warlike chief, such as the Pnihing chieftain Bĕlarè, also took beautifully crafted war swords on expeditions, but he may well have used them to fell small trees...
Old 6th June 2025, 03:40 PM   #32
asomotif
asomotif's Avatar
As for the monetary system. an interesting book is :
Stranger in the Forest: On Foot Across Borneo
By Eric Hanssen
Het crossed the Island by foot in the early 80's and in that time such a journey still depended on trade items, rather than money.
Old 6th June 2025, 07:58 PM   #33
asomotif
asomotif's Avatar
Here some pictures of my mandau which I think qualifies as mantikei.
Old 8th June 2025, 03:29 PM   #34
Hi Willem,
Sorry, forget you as a person who knows also well about mandaus!
And thank you for providing the word "mantikei" for laminated mandaus, I searched for nothing in my memories for this word!
PS: I see a little bit of rust at the tip of the blade from your nice mantikei mandau you should care about!
Old 8th June 2025, 03:44 PM   #35
Marc M.
Impressive chopper.
Marc
Old 10th June 2025, 01:44 PM   #36
Pertinax
Pertinax's Avatar
Roughly / locally forged blades are sometimes referred to as "mantikei".
I have 1 blade in my collection with a similar surface as this one.
They are rare, but I am not sure if they have a special status.
Here is what A.W. Nieuwenhuis wrote about blacksmithing in Borneo:
…Cheaper and better European iron has, as already mentioned, replaced the home-smelted iron previously used exclusively by these tribes. The natives living along the middle reaches of the Mahakam and Kapuri have completely abandoned smelting their own iron; above the Mahakam Falls, it is still practiced occasionally by the Long Glat. For this purpose, a large quantity of charcoal is first burned in the forest, then iron ore is sought in the scree banks of some small tributaries of the Mahakam. This iron ore occurs here in yellow-brown lumps in the form of blunt twigs and small cylinders, and is said to be of varying quality depending on the river. A strong fire is then lit in a hole in the ground, and alternating layers of charcoal and ore are kept ablaze until completely burned. After cooling, a lump of iron mixed with slag is found at the bottom of the hole. Understandably, the carbon content varies greatly, and cast iron, steel, and wrought iron are unevenly mixed within it. From such a lump, the blacksmith then chips off a piece the size of the object he intends to make. Even the best weaponsmiths have difficulty distinguishing and converting the different types of iron into one another…
…Therefore, if a weaponsmith wants to create a sword with the properties of steel, he will only immediately find the right one by chance; most swords that must meet a specific required property are repeatedly reforged and mixed with new types of iron. The smiths know that steel can be hardened, but iron cannot, and that pieces of iron with certain properties, welded together, can produce a metal that can be hardened easily; however, they always remain at the trial and error stage, and a homogeneous mass is almost never achieved. Hardening occurs only in its crudest form, by suddenly immersing the entire glowing object in water; hardening with oil or partial hardening, e.g., when forging a sword, is completely unknown.
For the reasons mentioned above, the particularly good swords to which the Bahau smiths owe their fame are rare and only come about by chance; they can never compete in quality with the best weapons made by European smiths. By far the majority of swords possess the qualities of iron rather than steel weapons, and even those with beautiful inlays I have often seen straightened by their owners after they had suffered wear and tear. Occasionally, parts pop out of the edges, or large chunks fly off, etc. Thus, apart from the difficulties associated with smelting the iron, it is understandable that the natives, among the items purchased at the coastal points, mainly bring large quantities of good iron bars up into the interior, despite the weight of the load. Swords forged from this iron are therefore much more highly valued than those made from their own material…
…Sword-making, in particular, suffered most from the introduction of European goods from the coast; furthermore, the fact that the presence of a European administration has severely restricted warfare among the Bahau tribes has also had an unfavorable effect. As a result, for example, beautiful swords of good quality are no longer forged at Kapuas. During my visit to the local population, the blacksmith was able to make me a sword and decorate it with engravings based on ancient designs, but the quality of the iron left much to be desired and made the weapon completely unsuitable for military purposes…
