Old 17th February 2025, 12:36 PM   #1
Default Late 18th c. to mid. 19th c. Santa Cruz de Mudela dagger
I am the happy winner of this small (23 cm) late 18th century to mid. 19th century Santa Cruz de Mudela dagger. The blade shows thick encrusted corrosion which I will remove soon as I have it in my hands.
The seller thought that it's a Ligurian dagger but I got told from a knowledgeable collector that it's from Spain.
Like usual, all comments are very welcome!
Old 17th February 2025, 03:40 PM   #2
Pendita65
Detlef, your home turns into an armoury thnx for sharing its a nice dagger.
Regards, Martin
Pendita65 is offline   Reply With Quote
Old 17th February 2025, 06:29 PM   #3
Hi Martin,
You could be right but this little dagger doesn't matter!
Old 22nd February 2025, 11:56 AM   #4
Here is a picture of how I received the little dagger, thick encrusted corrosion.
Old 22nd February 2025, 12:01 PM   #5
And here the same dagger after I've cleaned and polished it.
And a picture together with other daggers of similar size for comparison.
Old 23rd February 2025, 04:42 AM   #6
M ELEY
Wow, Sajen, you did a great job restoring the surface of this awesome dagger. Did you use any solvent or just 'elbow grease'
Old 23rd February 2025, 09:03 AM   #7
Thank you! The side I've pictured was cleaned by elbow grease only, the other side I've cleaned from the thick rust layer with vinegar essence but I will have the same elbow grease work to polish the surface and get out most of the pitting and to polish the surface.
