Old 2nd February 2025, 10:47 AM   #1
Default Unusual Albacete knife
This run-down Albacete knife crossed my way recently, the edge seems to be several times resharpened, the ferrule near the blade shows some dents and two handle inlays are missing. I never before have seen such an Albacete knife, do you have?
32 cm long, blade with brass bolster 21,3 cm long. Quite heavy with 164 gram.
Last two pics show it together with my other Albacete daggers for comparison.
Old 4th February 2025, 05:26 PM   #2
I am not overly fond of the tilt to the blade. The over-sharpening doesn't help either. Not sure what purpose it was made for. Much prefer the traditional double-edged daggers. You have a good collection of them. I do really like that dog head pommelled one tho.
Old 4th February 2025, 06:37 PM   #3
Hi Wayne,
Yes, it's an ugly duckling! And yes, the repeated sharpening doesn't let it look better. The question was, if someone has seen a similar one before.
It would look much better when the original edge would be still present.
Old 5th February 2025, 07:00 AM   #4
Hi Detlef,
I'm confident the hilt and guard are likely from Albacete but not convinced about the blade. I have not seen the same form of dots on an Albacete blade, nor a brass ricasso decorated with circles and dots in the middle. That does not look like any Spanish motif I can recall. Could this ugly duckling be a marriage of disparate parts? That would be my guess.
Ian.
Old 5th February 2025, 06:19 PM   #5
corrado26
corrado26's Avatar
I think the "cuchillo"in the foto is the basic type of your piece. You find it and others in a book that I bought some time ago when I still had a collection if more than 50 cuchillos of Albacete
Old 8th February 2025, 12:26 PM   #6
Hi Ian,
Someone had the same guess that it could be a marriage but when you look close you will see that the ornamentation on the bolster is the same as on the handle cups. I am nearly sure that everything is of the same age and not a marriage.
Old 8th February 2025, 12:29 PM   #7
Hello Udo,
Thank you for your comment! And yes, this would be the basic form of my blade but it was many times resharpened.
Old 10th February 2025, 01:41 PM   #8
... when you look close you will see that the ornamentation on the bolster is the same as on the handle cups. ...
Sorry Detlef, I don't understand what you mean.
Old 10th February 2025, 07:02 PM   #9
Hi Ian,
A picture explains sometimes more than words!
