Old 7th August 2024, 07:19 PM   #1
Marcus den toom
Marcus den toom's Avatar
Default Brass cannon with gun carriage and limber
One of my most recent purchases is a bit of an odd ball in my mostly medieval collection. But it is just such a pretty "little" cannon, i could not resist.
Problem is though i have no clue what model/type of cannon this is.
It is most likely Swiss and might be a type of mountain cannon (Gebirgskanone).
The brass barrel is 75cm long and has a 50mm caliber.
The original Limber is also included with a munitions box which doubles as a seat (3 arms/back supports still included). Everything is painted white with alternating blue stripes.
No markings are present.
Does anyone know more about this type of cannon?
If it is indeed a mountain cannon it could have been pulled by donkeys . Let's hope i did not make an ass out of myself by buying this in fear of having to pull it myself.
Old 7th August 2024, 10:26 PM   #2
Marcus, do you suppose this little fellow had a flint lock ignition installed on it?
A very handsome piece of artillery!
Old 8th August 2024, 07:28 AM   #3
corrado26
corrado26's Avatar
Based on the striking white-blue color scheme and the design of the carriage, I think that this could be a cannon from the Bavarian mountain artillery around 1850. Around 1850 there has certainly not been a flintlock but a percussion lock
Old 10th August 2024, 06:14 AM   #4
Marcus den toom
Thank you both for your reply. It is in any case a beauty.
After some more searching on Bavarian cannons i have not yet found this exact type. The colours match but the design is a little different.
Percussion or if it is a bit earlier than 1850s a flinrlock mechanism could have been used. There are some holes near the touchhole which support this idea.
