Old 19th June 2024, 02:24 AM   #31
xasterix
xasterix's Avatar
Originally Posted by Gustav View Post
Just a couple of facts to regain some attachment to reality:
I have looked into Spanish museums for some time now. Until now I haven't found any Kris from Phillipines in their collections that would predate 1800.
There, as Alan has pointed out many times, is a Kris, which probably everybody nowadays would call an "archaic" Moro Kris in its pure form. It comes from Brunei and was made in 1842.
We have two tendencies. The first one I would call academic, it works with available dates, and treats these dates as facts. Everything else ranges between hypothesis and speculation.
The second is amateurs approach and is based on speculations going beyond the available dates.
The possible truth often enough is situated somewhere between these viewpoints in my opinion.
What I personally see in the Kris from this thread is an old blade with very possibly reworked fretwork (Greneng in Javanese Terminology), conservatively datable from first half of 19th cent., in a dress from the turn of 19th/20th centuries.
I would beg to differ on the "amateurs approach." There are some of us who work within the academe, and who would only make statements grounded in fact or formal theory.
1. To note, there exists pre-1800 documentation of krises encountered in the PH in terms of local and foreign sources (Spanish friars, Dutch accounts, plus that captain who visited PH pre-1700s, I'll have to re-check my references).
2. There's also a book, with APA entry [SOLHEIM II, W. G. (1960). The Philippine Iron Age. The University of Arizona] which has a kris artifact found in Bohol area I think, dated 12th-15th century, I'm attaching the plate. Of course, we don't have any clue as to how it was dressed, if it was PH-origin; but the fact that it was found in PH soil points that kris was already being circulated in that time period.
3. Then there are also Moro elders' accounts, oral traditions, even myths and legends which trace krises back to pre-colonial times. These are valid sources under formal anthropological framework.
To summarize: there's no doubt that krises were already circulating in the Philippines pre-1800, pre-1700, even pre-colonial. In documentation it's clear that these were found in Southern (Moro) areas; in archaeological evidence at least, one is found in Visayas area (Bohol), which is not too far from Moro areas.
Old 19th June 2024, 08:44 AM   #32
Gustav
Xasterix,
I didn't adress anything you wrote about in your previous post.
What I did address is the wildly speculative attempt to set back in timeline a 20 inches long blade for about two hundred years - and the sentence "The pre-1800 designation comes from Cato following his study of museum pieces (including Spanish examples), plus statements he obtained from Moro informants."
Oncemore - after looking into the subject for some time I am not aware of any Kris in Spanish museum collections with documented provenance that would pre-date 1800, and I very much doubt we can find kris with such provenance in PH.
Old 19th June 2024, 06:58 PM   #33
Gustav,
Thank you for your spirited comments. I take no offense from your description of "wildly speculative" and "amateurish attempts" to push back the dating of this kris. In fact, I fully expected to receive responses such as yours from several people. As a retired academic I understand your frustration with what I wrote above. However, as a longstanding visitor to the Philippines and collector of PH weapons, I am no less frustrated by statements from those outside the local cultures who wish to label so many older examples as 19th C when those indigenous cultures report that much older examples existed.
With respect to museum specimens, the apparent absence of provenanced pieces pre-1800 might be traced to the way many museums document their acquisitions. They can usually date when the item entered the museum's inventory, but there is no further information about the possible age of the item before its acquisition by the museum. As a result, the formal age of such items is dated from the when it was acquired. To try to gauge how old these items may actually be, it is necessary to speak with museum staff, and this is what Cato says he did. Museums also have far more items than are displayed. Simply looking at what is on display can be very misleading with regard to the breadth of the collection, and what is displayed over time can vary. What a curator chooses to display may be based as much on the condition of the item or its artistic merit as on the desire to display an historical perspective.
Thus, I believe your statement regarding no provenanced kris pre-1800 in Spanish museums is misleading. There may well be, and likely are, pre-1800 examples in those museums that are simply not described as such in museum documents or placed on display. I have not visited Spanish museums nor contacted staff at those museums to address pre-1800 kris in their collections. Perhaps you have. Cato says he did, and I give his efforts some credence.
Mr. Cato has not defended the criticisms of his work. I can understand that. Why get into acrimonious debate? He put his ideas and findings out there, and we can make of them what we wish. One should not decry his efforts for doing so. A lot of work went into his book and it is thought provoking.
My approach in presenting this kris for discussion has been to take a controversial position and to stimulate discussion of the age of an old kris example. I am perfectly willing to be proven wrong. However, I know of no firm data that would contradict what I have said here.
Xasterix has provided some of the (very limited) data available on old kris. In the plate he has posted of archeological findings, there is an example (j) that resembles a keris buda.
Ian.
Old 19th June 2024, 09:13 PM   #34
Gustav
Ian,
thank you for your well tempered response - what you say in this last post resonates with me, because my viewpoint on Keris in early european collections is similar - the earliest firm provenance for a certain specimen is from 1607, but there are blades, which could be considerably older (there are records of early collections starting with 1512) and possibly from the late Majapahit period. Saying that was and perhaps still is regarded as some kind of blasphemy.
As I wrote, I simply don't see all this in the Kris blade of this thread, and I won't repeat it oncemore.
Regarding "inoficial" information about objects in museums, even very good ones - I must say, that the curators always (in my experience) have only the information which is found in their database (sometimes with significant errors) and not a iota more.
Regarding the artifact from Bohol and its relationship to Keris, we have been through that already, here a quite good thread about it:
http://www.vikingsword.com/vb/showth...ht=Bohol+Keris
Gustav
Old 17th December 2025, 03:54 PM   #35
xasterix
xasterix's Avatar
I forgot to reply to this; apologies for the delay, but let me add another:
The third is based on oral tradition, which can be gleaned, for example- from Moro elders here in the Philippines. This is a primary source and a very authoritative one, as emphasized by several international academic studies. The challenge in obtaining this is access- there is a high level of trust needed to facilitate information sharing.
Certain Moro elders can identify and age-estimate antique and vintage blades- after all, generational transmission through oral tradition is very much alive among their people. They have a great deal of knowledge which has not yet been published.
I have a bias towards the third approach, because the first approach, while objective, is based on a a colonizer's perspective (Spanish or American). There are limitations to such data, the most common being loss of meaning due to translation. Observer's bias is also prevalent in colonizer documentation.
That being said- the "best" possible outcome would be data that is verified by both the first and third approaches.
Old 17th December 2025, 06:32 PM   #36
Xas, thanks for adding these thoughts. There is actually a fourth method that has recently been brought to my attention by another forum member who happens to be an archeologist. This involves carbon dating of the carbon contained within the steel. I believe it involves determining the ratio of C14/C12 content. Unfortunately, this is a destructive analytic method, although only a few grams of metal are required. The obvious place to take a sample would be the tang (if one can get to it).
Old 20th December 2025, 05:12 PM   #37
xasterix
xasterix's Avatar
Thanks for that Ian; that's a relatively foolproof and thoroughly scientific way of looking at it. Did he mention how accurate it would be (can it be narrowed down to years or decades)?
Old 7th January 2026, 12:34 PM   #38
Ray, I don't know the precision of the carbon-dating method for steel. However, I did find a nice overview article for the use of carbon dating of iron and steel: HERE
Regards, Ian
