Old 18th April 2024, 04:16 PM   #1
awdaniec666
awdaniec666's Avatar
Lightbulb Terminology of Polish-Lithuanian arms
After a recent annoying discussion in a well-known facebook forum (yes, I see my mistake...) about trying to explain to someone that a Polish-Hungarian type sabre is not the same as a Karabela, I decided to record the terminology of weapons from the Polish-Lithuanian Commonwealth here in all its facets from the literature, the way I got to know it.
In each case the picture of a weapon type is shown which is representative of possible alterations and the common names are given. I try as best I can to show an original example of each type, but if it makes didactic sense, a replica may also be used. This will then be clarified.
Please note that the terminology only really took off at the end of the 19th century and that the terms were used synonymously before then. In the 17th century, for example, there were "curved sabres", "curved pallasches", "straight sabres", "swords" (could be anything from rapiers to dussacks) and so on and so forth.
Let's start with Karabelas, after all, that's where the muck grew.
awdaniec666 is offline   Reply With Quote
Old 18th April 2024, 04:37 PM   #2
awdaniec666
Karabela
Synonyms: Szabla orla (Eagle´s sabre), Szabla z rękojeścią karabelowatą (Karabela-hilted sabre), Szabla z otwartą rękojeścią (open-hilted sabre; imprecise)
Note: The term used to describe any highly decorated sabre or pallash. Furthermore, there are two types according to today's understanding: the combat Karabela and the Karabela kontuszowa (dress version).
Old 18th April 2024, 04:42 PM   #3
awdaniec666
Szabla polsko-węgierska (Polish-Hungarian sabre)
Synonyms: Szabla węgierska, Węgierka, Batorówka (wrong)
Old 18th April 2024, 04:47 PM   #4
awdaniec666
Ordynka
Synonyms: Ormianka (debatable), Smyczek, Szabla tatarska, Czeczuga (Special feature here: distinctive blade, see picture)
Old 18th April 2024, 04:51 PM   #5
awdaniec666
Szabla husarska
Synonyms: Szabla czarna (debatable), Pałasz husarski, Szabla z zamkniętym kabłąkiem
Old 18th April 2024, 04:52 PM   #6
awdaniec666
L-ka
Synonyms: Szabla czarna (debatable), Pałasz husarski, Szabla z półotwartym kabłąkiem, Szabla husarska
Old 18th April 2024, 04:57 PM   #7
awdaniec666
Pałasz husarski
Synonyms: Pałasz prosty, Pałasz
Old 18th April 2024, 05:03 PM   #8
awdaniec666
Szabla z furdymentem
Synonyms: Szabla litewska, Szabla czarna (debatable), Pałasz husarski, Szabla z zamkniętym kabłąkiem, Szabla husarska
Note: Alteration of the hussar sabre (curved or straight). It´s just about the basket hilt here.
Old 18th April 2024, 05:08 PM   #9
awdaniec666
Buława (Commanders Mace)
Old 18th April 2024, 05:10 PM   #10
awdaniec666
Czekan
Synonyms: Siekierka, Toporek
Old 18th April 2024, 05:11 PM   #11
awdaniec666
Nadziak
Old 18th April 2024, 05:13 PM   #12
awdaniec666
Obuszek
Synonyms: Obuch
Note: Spike can be fully rounded.
Old 18th April 2024, 05:19 PM   #13
awdaniec666
Kopia husarska
Synonyms: Kopia rycerska, Lanca, Kopia
Note: May be a copy in the Muzeum Narodowego w Krakowie.
Old 18th April 2024, 05:24 PM   #14
awdaniec666
Koncerz
Synonyms: Panzerstecher
Old 18th April 2024, 05:30 PM   #15
awdaniec666
Buzdygan
Old 18th April 2024, 05:40 PM   #16
awdaniec666
Batorówka, Zygmuntówka, Janówka
Every sabre with the image of Stefan Batory, Sigismund III Wasa or Jan III Sobieski on it, usually as gilding on the blade. Regardless of the time of creation.
Note: Image from "Najcenniejsze Tom IV" by Muzeum Wojska Polskiego in Warsaw. Fully recommend it!
Old 18th April 2024, 07:34 PM   #17
awdaniec666
Corrected and now invalid post!
Old 18th April 2024, 08:34 PM   #18
awdaniec666
Kościuszkówka
Old 18th April 2024, 08:51 PM   #19
awdaniec666
Common sabre types from the Polish-Lithuanian Commonwealth without current significant terms, synonyms or definitions
Old 18th April 2024, 09:28 PM   #20
awdaniec666
Kosa bojowa i pika (Engl.: War scythe and pike)
Old 18th April 2024, 09:37 PM   #21
awdaniec666
Lanca ułańska
Note: Shown lance is an Austrian model equivalent from the late 18th century.
Old 18th April 2024, 09:47 PM   #22
Radboud
Great post, thank you for sharing your knowledge.
Old 11th July 2024, 10:09 PM   #23
awdaniec666
Error correction for Czekan:
Toporek is not a synonym. Toporeks had more massive axe heads and were more focussed on force, whereas Czekans were probably intended to achieve a cutting effect. Below are two examples of typical Polish Czekans according to the consensus. The one with a handle is attributed to Sobieski, the one without a handle is stylistically identical but from an auction. But other forms were also common, also with hammer. For example, Hungarian "Fokos" were probably used a lot. Much rarer than Polish sabres, but somehow not so sought after by the average collector at the moment. Unfortunately, this is a topic that has received little academic attention. Recently I found sources in which the terms Nadziak and Czekan were used synonymously - what can one say. You want to hold on to knowledge and some time later you come across new findings. A general editing function for your own posts in this forum would be useful
Old 18th July 2024, 10:19 AM   #24
Jacenty
What would you call this sabre?
Polish-Lithuanian?
Polish-Hungarian?
Hussars?
Jacenty is offline   Reply With Quote
Old 27th July 2024, 11:42 AM   #25
awdaniec666
Hi Jacenty. This is a Polish-Hungarian sabre. The Hungarians like to call it just "Hungarian". This is depicted in the third of forth post here - please keep in mind the depicted specimen are just examples and there are many variations. Sabres of this type have few things in common: Almond pommel, more or less straigh or slighty forwand bend grip, long cross guard and (typically) Styrian/Genoese/Hungarian curved blades.
