Old 29th June 2006, 10:57 PM   #1
James D.N.MacKenzie
Question Qajar brass shield
Dear Collectors
I recently bought this brass shield, described by the auctioneer as "A Turkish Qajar brass shield, 19th century, embossed with a crescent and engraved with maidens and animals, 69cm diameter"
I have never bought a shield before and knew/know nothing about it besides that is is quite beautiful and I fell in love with it from the moment I saw it. Had to have it.
If anyone can give me more information, period, area it would have come from, etc, etc, I would really appreciate it.
Many thanks
James D.N.MacKenzie
SAM - Southern Africa Militaria
http://southernafricamilitaria.com
James D.N.MacKenzie is offline   Reply With Quote
Old 29th June 2006, 11:42 PM   #2
Rivkin
I am not a specialist on Iran, but this seems to be XIXth century Iran Qajar persian; as most "revival pieces" somewhat ceremonial/nationalistic/Shia example.
Old 30th June 2006, 03:23 AM   #3
Andrew
Andrew's Avatar
Rivkin, what about this particular shield strikes you as nationalistic? I know very little about these things, but I don't really get that impression.
Old 30th June 2006, 04:07 AM   #4
Rivkin
What I meant is that the whole movement of "revival" was somewhat nationalistic, surrounding the foundations of persian unity, unlikely combination of Safavi-influenced Shia traditions with Shahname. I don't want to pretend to be an expert on this one.
It is all connected to the ideology of Persian Empire: what it is based upon and who is considered to be part of it. I can give you an example - despite almost uninterrupted rule or turkoman and turkoman related leaders their rule was never seen as turkish occupation or domination, despite the fact that persians per se were confined to mostly ulema (islamic "priesthood" of a kind) and some non-military, non-trade and non-industry related goverment jobs. At the same time a short period of Afghan control over Persia is considered to be an occupation by Afghani. In my opinion it is based on some shared values, i.e. since Safavids Persia was perceived as a Shia state with a "remembrance" of its pre-islamic past; the tribes that shared this, with no regard to their language or history would at some level be considered Persian, the tribes that were Sunni or Najes would be considered on some level outsiders.
If you ask Talysh (i.e. persian speaking tribe from Azerbaijan) he will tell you that Persian Empire has to be rebuilt to unite the Shias and restore the old culture of Shahname. If you ask Lezghi (neighboring mostly Sunni tribe that is very proud of its old caucasian traditions rather than persian culture) whether he likes Persian Empire to be restored he will most likely react extremely violently.
Qajar Revival, Passion plays is probably something most symbolic of such "Persianism".
Old 30th June 2006, 10:09 AM   #5
erlikhan
erlikhan's Avatar
Hi.are you sure this is Persian,even from Iran at all? It has a crescent (it must be),same form of which I have seen many times on Indo-Persian shields(especially hide ones). Persians don't use crescent as far as I know. North and South Azerbaijan(Northern Iran) use it but as a Turkish national symbol so it is not expected to be used on a persian revival work,not?But the main point is not necessarily the existence of an supposed crescent,and not who use that symbol and who doesn't. The shield must be Indian or Indo-Persian in origin.Earliest the end of 19th c. or early 20th made for ordinary private guards of somewhere or even for tourists, -if not- much newer, first of all considering the low quality and fastest method of chiselling ,and as the material is brass instead of iron,which is harder to work,but which looks heavier,more respected and real. Plus the figured guy's style looks more Indian than Persian with arm bands or tattoes,naked,big earrings and several necklaces going down till his belly.
regards
erlikhan is offline   Reply With Quote
Old 8th July 2006, 03:04 PM   #6
James D.N.MacKenzie
Gentlemen
Thank you all for the bits of information.
I am still not sure what I have but after some internet research I am also inclined to think it is Indo-Persian. This shield has to be the largest one I have found on the internet. It is pretty heavy too.
Once again, thank you all for your input.
James D.N.MacKenzie
Old 9th July 2006, 10:36 AM   #7
Aqtai
Aqtai's Avatar
Hi James,
Congratulations on getting a very nice shield.
Try posting on this forum as well, Manoucher the main moderator is a bit of an expert on all things Iranian.
Click on the link:
http://forums.swordforum.com/forumdi...php?forumid=13
H.G.
Aqtai is offline   Reply With Quote
