Old 10th March 2024, 10:17 PM   #31
Pendita65
The Fountain of Knowledge has spoken, and yes a good choclate cake hmm could do with a slice now.
Regards, Martin
Pendita65 is offline   Reply With Quote
Old 10th March 2024, 10:53 PM   #32
milandro
indeed, as I suspected, there was a reason set in the forging methods.
Again then the question arises on the weapon being made to be actually used as a weapon ( the fuller make the weapon lighter and the consequent risers make it more robust to hitting other blades) . If the only purpose was to create a decoration item and there is a lot of decoration content (let alone a symbolic one) in a keris with a pamor along such a long blade, why would they have gone through the forging process which is highly suited to create a weapon apt to be used in combat against another blade?
Old 10th March 2024, 11:01 PM   #33
Not just logical Detlef, actual as well:-
think of a chocolate cake
nice, thick, rich, moist choccy cake
tastes great
now Grandma slaps thick, high qual Belgium chocolate icing onto it
she adds the thick, freshly whipped cream
then some maraschino cherries
looks fantastic
blows away the diet with one slice
little Teddy sees that cake
Little Teddy loves choccy icing
and cream, and cherries
Little Teddy got no weight problem
he takes a spoon to Grandma's choccy masterpiece and removes all that enhancement
what everybody else is left with is unenhanced chocolate cake
same as keris:- scrape off the pamor, what you got is plain old garden quality steel.
Old 11th March 2024, 12:14 AM   #34
Milandro, the reason is not really in the forging of the blade, it is in the carving of the blade.
Just about all the features you see in a blade are carved in.
Everybody unfamiliar with the process always thinks in terms of forging, but it is the cold work that gives the keris its features and that uses time.
I have made a few keris using traditional Javanese methods, that means no electric tools, only the traditional tools that were in use until very recently when makers began to use angle grinders, and die grinders so forth.
Working by myself with no striker, I was able to make the forging for a keris blade using pamor wos wutah in about 4 days --- using a striker cuts that time in half --- but to carve the blade, a simple straight blade, tilam upih or similar would take me around 10 to 12 days, something like a sinom robyong would take 14 to 16 days.
Old 15th May 2024, 11:25 AM   #35
oariff
tastes great
looks fantastic
Hi Alan,
Now would this blade be pamor or a blade that went wrong?
From Peninsular Malaysia perhaps?
Length: 56 cm from Tip to base of Ganja.
Cheers.
oariff is offline   Reply With Quote
