Old 25th January 2024, 06:02 PM   #1
Araņa_del_Sol
Araņa_del_Sol's Avatar
Default Mandara (???) dagger
I recently acquired this dagger that is giving me Northern Nigeria/Cameroon Mandara mountains vibes but I'm not entirely certain. If anyone can provide a more definitive ID that would be appreciated. Thanks in advance for any insights.
- ADS
Araņa_del_Sol is offline   Reply With Quote
Old 26th January 2024, 10:56 AM   #2
milandro
it looks like you have an Hausa dagger, it may be an early 20th century piece or later, very difficult to date such things.
they come from a number of countries where the Hausa culture has spread
see a similar piece
http://www.vikingsword.com/lew/w0048/w0048.html
Old 28th January 2024, 01:09 AM   #3
Araņa_del_Sol
see a similar piece
Hi, thanks for your reply and resource, the Hausa are a good suggestion, it would not surprise me if this dagger is of Hausa origin. Yet, the dagger has a number of differences with typical Hausa daggers most notably in the scabbard and in the design of the hilt which gives me pause.
- ADS
Old 28th January 2024, 11:27 PM   #4
Hello ADS,
You are correct IMHO, it's a Mandara dagger, see the attached picture taken from this link: *******************************gallery?...-cameroon-32cm
It's for sure not Hausa, sorry Milandro.
Old 29th January 2024, 12:52 AM   #5
Detlef and AdS,
Two very similar knives. Double-edged blade, central rib, and the presence of a waist. Same style of hilt. Looks like a strong ID. Thanks Detlef.
Old 29th January 2024, 07:53 AM   #6
Martin Lubojacky
I bought cca in 2009 in a small town Rhumsiki in the Mandara mountains in northern Cameroon very simmilar knife (not only central rib, but also the lower part of the sheath). http://www.vikingsword.com/vb/showth...=Mandara+knife
Old 29th January 2024, 02:25 PM   #7
Detlef and AdS,
Hi Ian,
Thank you but the thank has to go to our member Wodimi, he is the owner of a great research site: *******************************gallery?...word-and-knife
I only have seen that the Hausa attribution was not correct and have searched a little bit on his site and found that the Mandara attribution seems to be correct.
Old 29th January 2024, 02:33 PM   #8
Originally Posted by Martin Lubojacky View Post
Hello Martin,
Yes, it's a dagger from the Mandara mountains but from a different tribe, it's from the Kirdi tribes when I follow Wodimis attribution. See the example from his site.
Old 29th January 2024, 09:32 PM   #9
TVV
TVV's Avatar
To be fair to everyone in this thread, identifying knives from West Africa and the Mandara mountains is not an easy task. Outside of the 70s Wente-Lukas book, which I do not have, there really is not much published on the subject. Zirngibl focuses on prestige and rarer items. Other books may have an example or two, but often times we will see knives simply classified as Hausa, Fulani or simply Kirdi, which to my understanding is a somewhat derogatory term used by Muslims to describe all the pagans in the Mandara area.
The best source are probably the Quai Branly online collections, but finding the right match, if one even exists there, requires a lot of browsing. It is always very valuable when someone like Martin who collected in the field can post examples that are at least somewhat similar.
Old 30th January 2024, 02:01 AM   #10
Araņa_del_Sol
Thank you Detlef, Martin, and everyone who responded, I appreciate the picture references and additional information.
- ADS
