Old 22nd January 2024, 04:04 PM   #1
Default Straight Palemabng Keris
The recent Palembang keris threads reminded me to ask; (Mods, can you please fix the title and delete this in brackets)
Can those with NON luk types look to their collections and note here what the longest examples of Palembang Keris with "straight" blades are?
Just the blade length from gonjo to type, stright types only. A width at the widest point may be of interest too if it isn't too much trouble.
With thanks
Gavin
Old 22nd January 2024, 06:26 PM   #2
PeterP
Hi, mine is 43cm long and 9cm wide, which I guess is pretty long for a Palembang keris.
PeterP is offline   Reply With Quote
Old 23rd January 2024, 01:28 AM   #3
Thank you Peter. That is a decent length for the type.
The 9cms is across the gonjo, what is the broadest point in the blade?
If a single photo of the blade is available, I'd like to view it please.
Old 23rd January 2024, 02:38 AM   #4
Wink
Hello Peter,
A blade length of 43cm is definitely in the (very) upper range for Palembang and neighbouring regions.
Old 23rd January 2024, 07:01 AM   #5
PeterP
This is my Palembang blade.
Old 23rd January 2024, 01:28 PM   #6
Hello Peter,
What's the end limit for them Kai?
Two emails sent some time ago too?
Gavin
Old 23rd January 2024, 04:14 PM   #7
Hi Gavin. This one is 16 inches (40.6 cm).
Old 25th January 2024, 06:40 AM   #8
Interesting cross section of the type with just two images.
One with the pronounced medial ridge, the other more oval section of the Sumatran Anak or Panjang form.
Does anyone know the Sumatran terms for these variations, if there is one at all?
Old 28th January 2024, 05:01 PM   #9
Post
Hello Gavin,
The last two pics from David show a keris apparently locally crafted in typical Jawa style (including the tikel alis). Actually, both keris shown so far are.
Keris Palembang (and Lampung) tended to follow closely standard Jawa or Sunda patterns.
Sumatran Bangkinang blades typically exhibit a rudimentary tikel alis; their cross section tends to have thicker proportions in the lower half of the blade.
Old 28th January 2024, 05:13 PM   #10
Wink
Hello Gavin,
I don't have representative statistics and certainly not enough data on the extremes - let's see what record size we might find here.
My largest Palembang/Lampung blade is just short of Peter's example. I have another keris from Sumatra: Without scabbard; blade appears consistent with Palembang but needs more scrutiny; length about 43.6 cm (over 17").
Old 29th January 2024, 02:11 AM   #11
Thanks Kai,
I'll throw a known 45.5 long blade in to the mix.
Straight, high medial ridge and slightly swollen though the belly.
