Old 1st January 2024, 12:05 PM   #1
CutlassCollector
Default Lacaille Pistol
Hi all,
I'm looking for a bit more information on this percussion pistol. Firearms are generally outside my area of interest but this looked good quality and had no bidders so I decided to go for it.
All I could find on the web was Jacques Lacaille, working in Blois, central France, 1775-1829. There are no other marks except the inscription on the barrel. Anyone have a full translation for that? There appears to be a word missing at the start.
From the date, I assume it is a conversion from flintlock, would that be correct?
There are some interesting features like the animal carved hammer head and the mouth of the barrel is slightly flared, you can just make that out in the pictures. The ramrod has a number 5 stamped on it.
The barrel is rifled with grooves around the entire circumference which I found surprising for this era.
Any comments welcome.
Happy New Year everyone.
Old 1st January 2024, 12:35 PM   #2
Fernando K
Hello
It does not seem like a spark conversion, but is originally from percussion. What it may be is that a previous spark gun was used, threading a bombette or mascot to thread the chimney. The missing word may be the year of construction, but it would deserve a better photograph to appreciate it. The rifling of the barrel is known as "microrifling."
Affectionately
Old 1st January 2024, 01:54 PM   #3
Maybe it is a different Lacaille; even his son. By the way, you know these names on barrels are usually not those of gun makers but of suppliers, the so called fourbisseurs.
You should try hard to get a more clear picture of the inscription .
Happy new year to you too.
Old 1st January 2024, 03:49 PM   #4
CutlassCollector
Originally Posted by Fernando K View Post
Hello
Thanks Fernando K and Fernando. So I guess a later date makes more sense and possibly a later member of the family or even supplier.
I'm afraid even under bright light and magnifying glass the first word (or date) is reduced to a few unconnected marks.
The inscription reads : ...... Par Lacaille Ainé ŕ Blois as far as I can tell.
Rifling goes back centuries but there is not much information on micro rifling. Does anyone have any knowledge about when it was popular in the 19th century?
Old 1st January 2024, 08:39 PM   #5
Fernando K
Hello
Microrifling was used in luxury weapons, mainly in France, by BOUTET, and at the end of the 18th century and part of the 19th century, by the Versailles manufacture. There are also some Italian regulation pistols, with the "crushed bullet" method.
Affectionately
Old 2nd January 2024, 11:04 AM   #6
corrado26
corrado26's Avatar
The complete signature on the barrel reads "Fourni par Lacaille......" It follows that Lacaille was not the manufacturer, but probably just the dealer who sold the pistol. As a gunsmith, he would most likely have inscribed his name on the lock plate - as was common practice.
One more word about hair pulls: They are by no means an invention of Boutet or only appeared towards the end of the 18th century. As early as 1550, the Augsburg gunsmith Augustin Kutter was cutting hairlines into barrels.
Old 2nd January 2024, 11:13 AM   #7
CutlassCollector
Hello
Affectionately
Thanks Fernando K, much appreciated and opened up further reading for me.
Old 2nd January 2024, 11:27 AM   #8
CutlassCollector
Hello corrado and thanks for that - I was hoping that someone would have seen that inscription before. So now it reads.
'Provided by Lacaille the elder of Blois'
Fernando, I did not know that about the fourbisseurs and you were right. It makes me think that the first word has been intentionally removed to imply the more famous Lacaille gunmaker.
Which would be a strange sort of vandalism as it does seem like a quality pistol.
Old 2nd January 2024, 12:14 PM   #9
Originally Posted by CutlassCollector View Post
...'Provided by Lacaille the elder of Blois'...
... And what French letters are written that brought to the 'elder' conclusion ?
Old 2nd January 2024, 12:37 PM   #10
CutlassCollector
Hi Fernando,
I'm just going on google translate for Ainé - but correct me if that is wrong!
Old 2nd January 2024, 12:40 PM   #11
Hi Fernando,
Correct .
So, the 'younger' (son ?) was already operating at the time. Interesting.
Old 2nd January 2024, 01:25 PM   #12
corrado26
corrado26's Avatar
Lacaille l'ainé was Lacaille, Michel Charles *1799 and working at Blois in 1847; he was the son of Lacaille, Michel-Leclerc. (l'ainé is the French word for "the first born").
Old 2nd January 2024, 02:25 PM   #13
A prize for Udo, the best .
Old 2nd January 2024, 03:17 PM   #14
CutlassCollector
Thank you, Udo, such good information!
But that seems to indicate a connection with Lacaille as gunmakers rather than suppliers. Perhaps they were both?
I am wondering if the lack of a makers name on the lock plate is an indication that it has been converted from flintlock to percussion. I don't know how to tell. Does the plate get replaced? The wood to metal fit around the lock is certainly not as good as the other side.
Old 2nd January 2024, 05:16 PM   #15
corrado26
corrado26's Avatar
The arrow marks a place on the lock plate that looks as if the screw hole for the screw of the former battery spring was located there. This would prove that this is a former flintlock pistol that was converted to the percussion system. It would be conceivable that in this case the signature of the lock plate was removed after it had been softened.
Old 2nd January 2024, 06:43 PM   #16
Fernando K
Regarding what Corrado says, which is a modification of the spark key, you cannot clearly see the plug of the threaded hole of the frizzen spring. Nor can it be seen where the hole in his spike would have been. A better photograph would be needed, and above all, of the inside of the key. In addition, the threaded hole in the frizzen would be missing, which would have to be seen. Additionally, if it is a spark modification, the method followed for placing the bomblet or mascot, for placing the chimney, should be seen on the barrel.
Old 2nd January 2024, 06:47 PM   #17
You will also pardon me Udo, but i find it hard to process that this pistol has a converted system .
Old 3rd January 2024, 07:07 AM   #18
corrado26
corrado26's Avatar
What I wanted to say is, that this pistol eventually has been converted
Old 3rd January 2024, 10:41 AM   #19
CutlassCollector
Hi Udo, now I understand and I have examined that area closely and there is no sign of a previous screw hole.
I think that my lack of knowledge in this area has hindered the discussion! but I have learnt a lot and added a beautiful pistol to my collection.
So, gentlemen, thank you all for your interest and for sharing your knowledge.
CC
Old 3rd January 2024, 10:55 AM   #20
