Old 13th December 2023, 03:13 PM   #1
David R
David R's Avatar
Default My latest Keris
For someone without a special interest in such I do seem to accumulate pieces from this area.
I recently bought a stripped Keris blade from an online dealer, it arrived today, and now posted here for your perusal and comment..... The top piece is loose but does fit very closely, a pity and not mentioned in the sale description.
Next up I suppose is to dress it in a respectful manner.
Old 14th December 2023, 12:59 AM   #2
Hello David,
Looks like originating from the eastern Sumatran coast (including the Riau archipelago) to me.
Either classical Riau fittings or more generic Bugis-style fittings would go well with this blade.
Old 14th December 2023, 09:06 AM   #3
Jean
You should just glue the loose gonjo around the pesi, not a problem.
Old 14th December 2023, 08:39 PM   #4
I beg to differ Jean.
We do not glue gonjos.
We refix them with a key, if a key was used in the first place, or we use a nail punch with a relatively fine tip & punch the gonjo around the pesi so that we achieve a pressure fit.
Stylistically this blade would classify as Bugis, and usually Bugis gonjos are fitted by the punch method.
In any case, a gonjo is always a pressure fit.
Old 15th December 2023, 07:58 PM   #5
David R
David R's Avatar
Thank you! I did a bit of digging and found what you were writing about... In the process learning a lot more about Keris!
Old 15th December 2023, 09:01 PM   #6
There is a lot out there to learn, David.
If you like learning, the keris question can keep you occupied for a very long time, I've been learning keris now since 1953, for most of that time I have focused on Javanese keris, and in my opinion, I'm not even halfway through the Javanese course.
