Old 9th September 2023, 01:54 PM   #1
Default Keping for sharing and discussion
Just won my first keping by a German auction house. It was described as klewang from South Mindanao, Zamboanga. 49,5 cm overall with a blade from 37,7 cm. Ferrule from iron. Pictures from the auction house.
Old 9th September 2023, 04:47 PM   #2
Hi Sajen,
Interesting looking blade. The scabbard style is circa 1960-1970 with peripheral nails holding the two pieces together, and the smooth surface with rounded toe. Maranao work I suspect, perhaps made in Zamboanga. The multi-pinned pommel is consistent with mid- to late- 20th C work also.
Old 9th September 2023, 09:48 PM   #3
Hi Sajen,
Hi Ian, thank you for your comment, I agree with you on all points. It's not a fancy or decorative piece but I suspect it's a real user.
Old 10th September 2023, 12:49 AM   #4
JeffS
JeffS's Avatar
Is the upturned point the main feature that indicates this is a keping? Hope to see it cleaned up.
Old 10th September 2023, 08:36 AM   #5
Hello Jeff,
Not necessarily but so far I understand is the spine rarley straight.
And yes, you will see it cleaned up!
Old 10th September 2023, 11:25 AM   #6
drac2k
Great catch Sajen; they must be rare as I can't remember ever seeing another one.
Old 10th September 2023, 12:06 PM   #7
Hello David,
Thank you, but it's not a great catch IMVHO. And I doubt that you have never seen one before, you rather didn't recognize it as "keping".
Our member Xasterix has introduced these knives for our attention in this thread: http://www.vikingsword.com/vb/showth...ghlight=keping
Most of them remember barongs and by ebay I've seen them described as barong.
Attached pictures of examples other members have shown them here.
Old 10th September 2023, 12:21 PM   #8
By the same auction two other kepings were offered. I have had a short discussion with Xasterix who gave me the tip to bid on the one I won because this one seems to be made for use instead of selling purpose.
Old 11th September 2023, 01:22 PM   #9
Hi Detlef,
Thanks for putting together this topi and adding to our understanding of what is basically a general purpose bolo of Muslim Mindanao. The information provided by Xasterix has been very useful in this regard.
The Tugaya craftsmen are renowned for dressing up old blades, and new ones for that matter, to sell to travelers. Now that we have seen the examples shown here, we should be able to identify them more clearly. While they are interesting blades, and might serve as a weapon, they are mainly used for routine chores rather than fighting.
Old 11th September 2023, 02:18 PM   #10
drac2k
Right you are Sajen, I have seen these before, but I never realized the subtle differences and I did assume that they were barongs. Is this a new blade form or an older one? The ones that I have encountered (now that I think about it), seem to be WW2 or newer.
Old 13th September 2023, 09:14 PM   #11
Hi Detlef,
Thanks for putting together this topic out and adding to our understanding of what is basically a general purpose bolo of Muslim Mindanao. The information provided by Xasterix has been very useful in this regard.
Thank you Ian,
And I would agree that the piece in question isn't a fighting blade but a multi purpose chopper.
Old 13th September 2023, 09:23 PM   #12
Hello David,
Like myself! I never have recognized them until Xasterix bring them to attention in this thread: http://www.vikingsword.com/vb/showth...ghlight=keping
I can't answer the question if kepings are older blades or if they occur after 1900, maybe Xasterix can answer this.
Old 14th September 2023, 12:56 PM   #13
David,
Two of mine at the bottom of post #7 in this thread are late 20th C items from Tugaya (Lake Lanao region). The seller purchased them in Zamboanga, but referenced the Maranao city of Tugaya as the origin of them. I had originally thought, like most of us, that they were just fanciful recently made barung.
I have several other keping examples that may date as far back as the 1940s but probably not pre-WWII. One was attributed to the Mandaya but is clearly of Moro manufacture with a brass hilt and scabbard.
Old 1st October 2023, 12:04 PM   #14
Here you go! It's 49,5 cm long with a blade from 37,5 cm. Blade is 5 mm thick at the spine behind the handle.
Blade don't fit inside the scabbard, I guess due to the shrinking of the wood. Blade is still very sharp and I guess that it was used, there are several nicks in the edge.
Old 1st October 2023, 01:01 PM   #15
JeffS
JeffS's Avatar
Cool - Definitely has it's own style. Thank you for the update.
