Old 3rd September 2023, 07:33 PM   #1
C4RL
Default Yatagan blade, any info welcome.
Hello All, this is my first post seeking information from the knowledgeable folks on here. 👍
This is a Yatagan blade (that much I know!) that I pulled out of a house clearance trash bin many years ago. It was a lump of rust with the remainder of a horn handle in a terrible split & hairy state pushed off the blade with rust.
There was a brass embossed typical triangle on one side & the frayed remains of some fine brass wire, knowing nothing at the time (20 years ago) I sanded it by hand & presumed it was carbon steel, & made the oak handle you now see.
Roll on another 15 years or so & I read something that made me wonder if it might be pattern welded, a quick try with Ferric Cloride looked promising so after a few ferric & vinegar soaks in a bent pvc pipe this is where I am.
Please forgive the handle, but to be honest the original was ruined & if I hadn’t picked it up it would be in a land fill now!
Any info welcome.
Thanks.
C4RL is offline   Reply With Quote
Old 4th September 2023, 05:06 AM   #2
Hi Carl,
The central pattern on your blade resembles "Turkish ribbon," which has been discussed elsewhere on the Ethnographic Forum. Your pictures are very large. I will resize them. Perhaps you could post smaller ones next time so that they will fit on a single screen rather than having to scroll across. The recommended file sizes are listed in the "Manage Attachments" section of the Thread Post page.
This looks like a very good save. Nice old blade. BTW, I think the handle looks fine and appropriate for an old garbage bin find.
Old 4th September 2023, 10:49 AM   #3
C4RL
Thank's for your reply Ian, and sorry about the large images, I made the mistake of linking them which I realised afterwards isn't appropriate! Sorry.
I shall have a search for "Turkish ribbon". Thank you.
Old 5th September 2023, 12:58 AM   #4
Oh this Turkish blade is wonderful. The only addition I would make is that this could come from Turkey proper.
Old 5th September 2023, 08:53 AM   #5
C4RL
Thank you Battara.
After reading up on Turkish ribbon I have a question, I understand the stacking of the twisted bars & my blade has four quite distinct ones along the centre, but what is the composition of the bars that make the cutting edge & spine?
Having looked at other blades of similar construction the spine & edge bars look much plainer, am I correct in assuming this is welded up from the same steel/iron as the pattern bars but a much finer "mix"?
Because my blade was so rusty & required a lot of etching I'm guessing it's this that is showing as fine mix of random & some straighter lines?
Old 9th September 2023, 01:23 AM   #6
I would say yes to your question. In fact, it makes sense that it would be more horizontal laminations for stiffness and hardened steel (not iron).
Old 13th September 2023, 09:17 PM   #7
C4RL
Thank you.
