I've just acquired new pandat/tangkitn for my collection. Does anyone have any idea about this blades. Thank you
Beautiful; is that silver inlay on the blade ?
No, I just really like the sword.
Hullo Cakszz !
![]() The blade has swastika motif bounded by leaf-scroll motif at the ends (common in SE-Asia). Also see: http://www.vikingsword.com/vb/showpo...85&postcount=1, item #3 Best, |
#7 | |
#8 | |
Hello Cakszz,
Have you tested the inlay for silver? I'm wondering if it might be some other alloy. Just curious of its provenance: Did you acquire this locally or from Kalimantan Barat? Regards, Kai |
#9 | |
Regards, Kai |
Wonderful blade! I didn't know that this motif was common in Indonesia, I usually see this on Balinese blades.
The metal inlay looks like silver! Please show pics of the whole piece. |
What’s the best way of removing the red rust from this blade without compromising the silver inlays?
Kino, i'm not really seeing much red rust on this blade. If there is some minor surface rust i would go at it with some WD-40 and a toothbrush.
The pattern in this motif is common in South East Asia, with links to both Hindu and Buddhist culture.It is an endless swastika pattern, a solar symbol intended to provide good luck and protection.
#15 | |
This looks like red rust to me. Photo is blurry. |
#16 | |
Could EDTA gel work maybe?
See: https://www.youtube.com/watch?v=WhzNttK_-ko He says it works on a tulwar with koftgari: https://www.youtube.com/post/UgkxPCh...NeHHJ0hiXzBMGr Quote:
Just for another example of this pattern, I have a wedung with a very similar inlay, though it's brass rather than silver.
Thanks, Leif |
#18 | |
I would try spraying on WD-40 and really letting it soak in for a bit before brushing. As for steel wool, 0000 or even 000 grade should not cause any damage, at least not in my experience. As always, work slowly and carefully. |
#19 |
That's a rather strange wedhung. I have seen these inlay patterns on what people mistakenly call "Balinese Wedhung", but never on a true Javanese wedhung. Your blade is not quite correct for a Javanese wedhung. It shows no wideng for instance and the shape blade profile is close, but not quite right to Javanese forms. But the sheath is clearly from a Javanese wedhung. Were these married at a later date with the blade possibly being from Bali? Do you have any info on its origin?
#20 | |
It's certainly possible it was a kind of cross cultural piece. I can add some more pics if you'd like to look at them later. Thanks, Leif |
#21 |
Here's a few more pics of my weird Wedhung.
Thanks, Leif |
