Old 24th August 2023, 04:07 PM   #1
carlos
Default Antique buthanese dagger?
I just adquire this piece, my first impression is dagger is from Buthan, maybe 19 th century? blade 35 cm and handle 10 cm. The sheath has a piece of ray skin
Any information will be wellcome!!
Pictures are from Seller.
Thanks in advance
Carlos
Old 25th August 2023, 12:52 PM   #2
werecow
werecow's Avatar
Yes, I think you are correct about the country of origin; a Bhutanese "dozum". I can't comment as to the age, though; I believe they are still made to this day.
Old 25th August 2023, 03:23 PM   #3
Hello Carlos,
I am not a specialist but this is a great antique dagger, for sure 19th century, congrats! Are the mounts from silver or iron?
Old 25th August 2023, 03:30 PM   #4
Bob A
How does one separate Bhutan from Tibet as an originating site in this case, and in general?
Old 25th August 2023, 03:50 PM   #5
Tibetian daggers looks different. For Bhutan daggers look for example here:
https://www.bukowskis.com/en/lots/13...e-dagger-dozum
https://www.antiques-atlas.com/antiq...ife/as1016a159
https://www.mandarinmansion.com/item...utanese-dagger
These daggers are called "dossum".
Old 26th August 2023, 01:08 AM   #6
Thanks in advance
Carlos
Carlos,
I'd be more likely to place this in the 1950s, early People's republic.
Likely Yunnan made for export to finance the state.
https://www.swordsantiqueweapons.com/s059_full.html
Old 26th August 2023, 01:20 AM   #7
Montino Bourbon
Montino Bourbon's Avatar
Default you should try etching it.
an older piece would probably have hairpin lamination. It would be worth etching this to see if it is made that way.
Old 26th August 2023, 01:37 AM   #8
I'm with Gavin - the fullers appear to be made with some sort of rotating tool.
