Old 9th June 2023, 12:12 PM   #1
Yvain
Yvain's Avatar
Default Takouba with old european blade
Hi all!
Today I received this takouba that I won at an auction some weeks ago! As you can imagine, I'm very pleased with it. The mounts are in an older style (late 19th century perhaps), but the most interesting part is the blade.
It seems to be an older european blade that was locally "sandwiched". On both face, the blade bears a wolf of Passau, and the inscription "SAHAGVM". Alfonso de Sahagún was a Spanish smith from the second part of the 16th century, but his signature was copied a lot, including on some Passau blades. The general shape of the blade, fuller, and marks makes me think that it could be from the second part of the 16th century, or perhaps early 17th century.
Some similar blades : https://www.antique-swords.com/AA96-...-Mortuary.html
https://www.olympiaauctions.com/sale.../view-lot/118/
https://collection.maas.museum/object/249330
Anyway, I’m really happy about it! (And sorry for the not so good pictures, I'm preparing for moving out and don't have much space)
Old 9th June 2023, 01:12 PM   #2
Lee
Lee's Avatar
Thumbs up Very nice old warrior!
Very nice! If you slap the flat of the blade against your thigh and find it 'springy' (that is, it vibrates for a moment) that would argue for it being the old European blade it certainly appears to be, rather than an antique local copy that would very quickly dampen out the vibration.
Look for: Briggs, Lloyd Cabot, "European Blades in Tuareg Swords and Daggers," The Journal of the Arms & Armour Society [U.K.] Vol. V. No. 2. (1965), p. 37 - 92.
Old 9th June 2023, 03:21 PM   #3
Yvain
Yvain's Avatar
The sandwiched ricasso dampens the vibrations a bit but the blade is springy and behaves correctly for a European piece. (I also don't think I ever saw a locally made takouba blade with this shape, but it could have happened indeed). I have the article you mention, I will have to search for it on my computer!
Old 9th June 2023, 04:28 PM   #4
TVV
TVV's Avatar
Congratulations, looks like an old European blade indeed. The sandwich construction was used for older blades that had been remounted multiple times causing wear to the tang.
Old 10th June 2023, 12:15 AM   #5
Yvain
Yvain's Avatar
Indeed TVV, I have another one like this. Though in this case I think the main goal could have been to lengthen the blade, as the "sandwich" part doesn't hide the beginning of the blade
Old 10th June 2023, 03:23 PM   #6
I agree with the consensus here, this appears to be a European blade and has suffered the torments consistent with the Sahara, with these blades that came into this sphere through the 19th century through Mediterranean trade. These circulated for many generations and went through many alterations in their repeated remounting.
The 'Passau' wolf seems well executed and consistent with the standard configurations typically used in Solingen work. The SAHAGUM was one of the many also consistent names etc. used spuriously in Solingen implying the work of makers in Toledo.It seems blades using this name were typically destined for North Europe, but obviously these like others often ended up in varying circumstances.
The 'sandwiched' metal applied at the forte is a strengthening application commonly used in the Sahara for blades often remounted as Teodor notes, if I recall termed 'adabal'. The rebated point of the blade is also to tribal preference and in accord with the slashing cuts used by Tuareg tribesmen.
The blade has fared well relatively with the markings as these were typically scoured often in sharpening using stones and such rugged methods. The new reddish rust may be from moisture arising in its location for a time especially if scabbarded. Its always hard to tell from photos but the metal seems otherwise unusually bright.
Old 10th June 2023, 03:39 PM   #7
Marc M.
Hi Yvain
Nice takuba and a good european blade. Best to remove the active rust.
Marc
