Old 8th February 2023, 05:16 PM   #31
milandro
Cheers Kai,
I realise that the topic of staining is controversial .
Since I have never seen a Kris blade (Moro or otherwise) which has been stained with FeCl, I took the chance offered in this thread to see how one would have looked like.
Since Xasterix announced the staining (staining which was " to come" at that time) of this blade in FeCl and the intention to post pictures as a follow up : ".... I'll be doing an FeCl etch in the near future- I'll update this thread by then with clear and close-up pics ..."
I was wondering if this had happened and if we could partake of the results.
I have seen several pictures of blades stained in vinegar and, for comparison, would be very educative and informative for all to see the difference between the two (of course , Ideally one would have to see it on the same blade but also two similar one would be the next best thing)
Old 8th February 2023, 10:32 PM   #32
Yes, I may be the culprit in dissuading Ray to move forward...
We had some Moro blades treated with ferric chloride here in the forum (if not findable with a search, possibly in the defunct UBB forum). I'm going to PM you examples that I can't post here, Milandro.
Old 8th February 2023, 11:33 PM   #33
Post
Hello David,
Apologies for not responding earlier!
Well Kai, i think you really have to differentiate between etching and staining because they are not the same thing at all.
In most cases of intentionally treating pattern-welded pieces, both is happening during a single process like two sides of the same coin.
Pretty much all stains contain an acid which etches the surface and some resulting oxidation products result in discoloration of the bare metal.
Actually i don't think all that much etching takes place during the staining process with warangan anyway. Most of the etching with keris takes place during the pre-staining "cleaning" processes when either fruit acids or coconut water are used to remove rust and bring the blade to "whitened" condition.
Yes, the whitening step is responsible for most of the erosion, especially with the rub-in method. (The soaking method tends to remove more metal.)
However, the lime juice in the warangan mix provides organic acids resulting in an oxidation process while the arsenic reacts resulting in the dark color. Thus, we still have both processes working hand in hand (since the lime juice is necessary to get a correct stain).
I was not arguing that there is not nickel in the steel of this archaic Moro blade. But by my understanding the patterns created here are not done by the same process that is used to create keris with pamor.
Pamor can result from any kind of laminations, even if the contrast happens to be low. Also in Indonesian keris, the use of metal from different ores/treatments results in obvious (if often more subdued) laminations, especially with many old pieces. If the ores don't have increased nickel content, it may just as well be a higher phosphorus content or other trace element(s) in the alloy affecting their specific reaction characteristics.
There is not pamor used in this archaic blade as far as i know.
This example clearly exhibits typical pamor (easily comparable due to the smooth surface) of the same twisted type as seen on keris Jawa (or Lombok/Bali). Based on the thin pamor layers with very light color, I'm pretty confident that a XRF analysis will show an elevated percentage of nickel in this blade, indeed.
There may very well be some nickel content in some of the iron used though. But frankly i don't know. I am curious to know how you know this though. Can you cite a source for this information?
If it walks like a duck, and quacks like a duck...
At this stage, I don't have really started obtaining detailed measurements yet (quite tricky due to the small exposed surfaces, especially with more complex pattern-welded blades).
Aside from originating from the same roots, also all observed features resulting from blade forging and quenching as well as the very comparable reaction of pamor layers to etchant/stains, supports the hypothesis that at least the basic keris/kris smithing methods seem to be very similar all across the archipelago.
Old 9th February 2023, 01:57 AM   #34
Here's one Kai.
Old 9th February 2023, 10:10 AM   #35
xasterix
xasterix's Avatar
Hullo Milandro! Sorry it took me a while to get back. I didn't FeCl the kris anymore. As chance would have it, I was able to contact a descendant-relative of the original Maguindanaon owner, and upon realizing the value of that pusaka, they expressed that they would like to acquire it in memory of their ancestral lineage. As much as I want to keep it (who won't want to keep a twistcore, right), out of goodwill I let them acquire it from me. That's one less twistcore for me, but at least a family reclaimed its pusaka.
Anyhow- I've been experimenting a bit, and my current preference is a mix-
1. Mirror polish then FeCL, stabilize
2. I immerse a white vinegar-filled tube with old brass for around 2 hours
3. I dip the blade for around 30 mins (as a second etch), stabilize
So far I'm pleased with the results. It doesn't show up that clearly in my pics, but there's a golden tone to the etch in certain places (due to the brass residue). Here's some pieces I did that progression with.
Old 9th February 2023, 01:50 PM   #36
milandro
Hello Xasterix,
thank you very much for getting back to this thread with such relevant information and very well done for returning the acquired kris to the family of the original owner. You are a gentleman.
Anyway.
Thanks for sharing your experience and your personal recipe.
I am considering all options for my one Moro blade (which I did publish elsewhere in another thread but I can add a picture here for completeness of the discussion).
I don't think it has a twist core or any other major feature , yet, I think that giving it the chance to show the hidden secrets (so to speak) may be a nice touch.
I am going to consult a local master bladesmith , hoping that he can provide some insights from a " de visu" exam of the blade.
Old 9th February 2023, 02:44 PM   #37
xasterix
xasterix's Avatar
Hello Xasterix,
Anyway.
Thanks for the kind words Milandro! I'm betting that your kris is laminated, and that the hardening at the edges will be marked neatly once it's etched (as to how dark, light, or contrasted, that'll depend on your etch media and strength). Good luck, and let us know how it goes!
Old 9th February 2023, 08:05 PM   #38
Hello Xas,
Be careful with your blades, I see brown corrosion by your kris, this is what Kai mentioned before about etching with FeCl.
Old 9th February 2023, 08:44 PM   #39
kino
kino's Avatar
It’s honorable of you to have the Maguindanaon family have their Pusaka back.
What’s the purpose of adding the brass to the vinegar?
Old 10th February 2023, 01:12 PM   #40
xasterix
xasterix's Avatar
Hello Xas,
Hullo Detlef! Thanks for the heads-up- but that's no corrosion don't worry- it's the "effect" of etching with white vinegar + brass residue =) it gives a different tinge to the etch which I fancy (but I understand it's not for everyone's aesthetic). Here's some more pics.
Old 10th February 2023, 01:15 PM   #41
xasterix
xasterix's Avatar
Thanks sir Albert =) oh that's just an experimental mixture of mine to add some random brass-ish color to the etch. I noticed that brass, when soaked on white vinegar, leaves residue. It's etched unto any dunked blade afterwards. It's easy to lighten up or remove with some fine steel wool.
Old 10th February 2023, 01:16 PM   #42
xasterix
xasterix's Avatar
It also affects the color of other metals, including silver I think- notice how the asang-asang became gold-ish, same color as the etched residues on the blade.
Old 10th February 2023, 01:39 PM   #43
Hello Ray,
It looks like you're essentially electroplating the copper from the dissolved brass onto the asang-asang.
On the blade, your results still do look suspicious to me. When I've seen effects from "contaminating" metals/alloys, the "deposit" seemed to be much more evenly distributed - at least if the blade was regularly moved in the etching solution to avoid erratic results.
Old 10th February 2023, 03:36 PM   #44
xasterix
xasterix's Avatar
Hello Ray,
Thanks very much for providing me with the formal term!!! The problem was that I did not regular move the blade in the mix, hence the erratic distribution.
