Old 29th July 2022, 12:15 PM   #1
wheellock95
Default Miniature toy petronel info
I just acquired what I believe to be a toy petronel, dating from the 17th century but that is about everything I know about it. Does anybody know what half the 17th century this could date from judging by the shape of the pommel ? Look forward to hearing any information.
wheellock95 is offline   Reply With Quote
Old 29th July 2022, 12:55 PM   #2
Raf
Raf's Avatar
Congratulations on a very rare example. From the attached you can see that it once had a fully functional matchlock firing mechanism , now missing. Looking on the PAS database you will see plenty of other examples which usually have only the flash pan for manual ignition. The petronel form seems to have persisted probably into the eighteenth century but I am confident that your example is certainly early seventeenth century although you could argue the ball but makes it possibly late sixteenth century.
Old 29th July 2022, 01:03 PM   #3
wheellock95
Wow that’s incredible. All of the other examples I have seen have the same shaped pommel as the one you pictured but I haven’t seen one with a round ball but before. late 16th century would be quite amazing
Old 30th July 2022, 08:05 PM   #4
Fernando K
hello
I think this is a toy and for that reason, it is missing the lid of the bowl (bread)
affectionately
Old 30th July 2022, 08:13 PM   #5
wheellock95
Yes it is a toy as I stated in the title
Old 31st July 2022, 12:50 AM   #6
wheellock95
Originally Posted by Fernando K View Post
hello
affectionately
I’m unsure what you mean by it is missing the lid of the bowl(bread)
Old 31st July 2022, 01:20 PM   #7
Raf
Raf's Avatar
I think Fernando K may mean a lid to the flashpan. To be clear the missing matchlock mechanism is exactly the same as the example I posted. The screw for the trigger return spring is present and the two holes for mounting the mechanism can be clearly seen . In principle its the same as any European matchlock but the form seems to be unique to these toy pistols. The second image shows the more frequently found example with a fishtail but and ring and dot decoration. Early seventeenth century in form but I suspect made over a much longer period .
if anyones wondering about the strange shape of the end of the barrel on the second example this is actually the end of the ramrod which is reversed and screwed into the barrel
Old 31st July 2022, 01:42 PM   #8
corrado26
corrado26's Avatar
In one of my drawers I found a toy miniature of a matchlock pistol unfortunately missing the cock. It is 77 mm long and made of bronce. The former owner once told me that this item has been found in the mud of the river Thames near London.
Old 31st July 2022, 02:13 PM   #9
Raf
Raf's Avatar
The ball but on this one looks completely wrong.
Old 31st July 2022, 03:08 PM   #10
wheellock95
Corrado did you get yours from the original finder as I see someone online is selling re casts of an original that are identical to your example ?
Old 31st July 2022, 03:39 PM   #11
corrado26
corrado26's Avatar
I got it some years ago from a collector friend, but do not know where it came from, sorry.
Old 31st July 2022, 03:57 PM   #12
wheellock95
Raf, would these more complex toy petronels have been quite a high end toy at the time ? As I can’t imagine these being cheap when first produced ?
Old 31st July 2022, 09:16 PM   #13
Raf
Raf's Avatar
A lot of the early ones are river finds from the Thames. Maybe a more affluent market. An image from Noel Hulme- All the Best Rubbish.
Sound advice
Old 1st August 2022, 08:23 PM   #14
wheellock95
Yes I’ve heard that they have found some in the Thames. My example was found in a field near Newbury, Berkshire in England. I am also in the process of purchasing one found in Scotland so it seems they were produced all throughout the UK.
Old 11th August 2022, 11:47 PM   #15
wheellock95
Raf I believe there is less shot half way still stuck in the barrel, is there a way to try and get this out ?
Old 31st August 2022, 10:49 PM   #16
ausjulius
To remove the stuck ball.. If it is lead you can use a special tool to remove the stuck lead ball it is like a corkscrew on a cleaning rod.. But these are made only in large sizes.. I dont know the bore size.. If its lightly stuck in a small bore you can take an aircompressor nozzle make a tight seal on the touch hole and fire a shot of compressed air down the barrel.. It will work especially if you put some fine machine oil or wd40 down first. Put a little at both the touch hole and the muzzel and then send the air down.. You can also loosen it by putting some cleaning liquid down and boiling the gun in how water then oil.. Then compressed air.. Keep you eyes clear of the muzzel....
