Old 13th December 2021, 10:27 PM   #1
Garlot
Default Shamshir identification
Just got a new shamshir (for quite a bargain ) and was hoping someone could help me identify it's origin.
The handle makes me think persian but I think the wire wrapping is mostly found on arabic/bedouin or syrian hilts. The blade is fairly plain with no inscription whatsoever, and the right langet is bent in.
I've seen an extremely similar sword sold long ago on the ashokaa arts website called an omani shamshir, but it had a way more fancier sheath.
Garlot is offline   Reply With Quote
Old 14th December 2021, 01:43 PM   #2
Hi Garlot.
Welcome to the forum! Let us know if you have any problems navigating the site or with posting pictures, etc.
I'm thinking that you have a Syrian saif made in the last 30-40 years, but this is not my area of collecting and I defer to the opinions of our Eastern experts.
Ian.
Old 14th December 2021, 01:59 PM   #3
mariusgmioc
mariusgmioc's Avatar
Hello and welcome to the forum!
I agree with Ian.
In my opinion too, this is not a shamshir but a saif. But since names are rather relative, you can take this as you want.
In my opinion a shamshir has a long, narrow and very deeply curved blade of mostly triangular cross-section.
https://en.wikipedia.org/wiki/Shamshir
Yours has a broader blade with a complex, fullered cross-section and a moderate curvature. I suspect the blade is of European origin (German/Prussian model 1811 Blucher ? or maybe even English pattern 1796 Light Cavalry Sabre ? ).
The hilt is very similar to the classic Persian hilts but not quite...
It may be Persian, but more likely Syrian. The wire wrapping of the hilt is less relevant as it probably has been added later to protect a damaged hilt.
PS: What material are the scales of the hilt made of? From the photos they appear to be resin.
Old 14th December 2021, 05:52 PM   #4
TVV
TVV's Avatar
To me this looks like an Omani/East African saif. The way the silver wire is braided under the guard is characteristic. The floral motive in the guard also looks Omani. And while certain parts, like the pommel cap may be be replacements to the originals, it very much looks like a 19th century antique to me. What are the dimensions?
Teodor
Old 14th December 2021, 08:36 PM   #5
Garlot
Hi Garlot.
Ian.
Thanks! I've been following this forum for a while but I decided to join since I have begun starting a collection.
I agree with Ian.
I should have used saif considering that's the word I'd use in my arabic mother language, but from my limited knowledge saif in the collection world refers more to stuff like omani kattara and arabian nimchas, although I'm aware it just means sword and is used for everything from kilijis to kaskaras among arab speakers.
I've seen wire or chain wrappings on a lot of similar swords with a variety of hilts, from reading another thread I think they're a feature common among swords used within arabic areas in the middle east.
The seller has said the hilt is elephant ivory, is there a way to make sure?
Teodor
89-90 cm with the hilt, 77 cm for only the blade, 3.3 cm wide, don't have a tool to measure the thickness but it's about 5 mm thick at the base and gets very thin at the end, maybe 2 mm.
Old 15th December 2021, 08:45 AM   #6
mariusgmioc
How to check wheteher is ivory or not?!
The colour, with orange hue is quite unusual for ivory. Even old and much handled ivory does not usually get that hue. It becomes yellowish but more towards tan or even coffee. Also the chips shown by the red arrow make me think it is resin.
The best way to identify elephant ivory is finding the Schreger lines. They are usually found in the areas shown by green arrows. However, this requires some experience. Check the internet and have a look at the different photos of Schreger lines:
https://www.google.nl/search?q=schre...EK&sclient=img
However, the Schreger lines are characteristic ONLY to elephant and mammoth ivory. Walrus, marine and hippopotamus ivory do not show Schreger lines.
Besides that, there are more destructive methods that I don't recommend, like rubbing it quickly with very fine sandpaper and check it whether it smells like "dentist" or like plastic, or applying a red hot needle to check whether nothing happens (ivory) or it starts melting (resin - albeit I have encountered resins that do not melt when tested this way).
Old 19th December 2021, 03:54 PM   #7
A.alnakkas
A.alnakkas's Avatar
Omani silverwork. Those tend to have imported blades. Scabbard looks like a later addition.
Old 20th December 2021, 12:54 AM   #8
In societies with significant Persian influence it would be called " shamshir"
In those with Arabic influence it would be called " saif"
Just like Yemeni and Omani daggers: even though they are almost indistinguishable, in Yemen they are " Janbias", in Oman they are " Khanjars". Thus, since this saber is obviously Omani ( braided silver wire) , it must have been called " shamshir" locally. Having been captured by a Yemeni fighter, it became a " saif", and when it was sold to a Turkish Agha, it became a " kilij":-)))
In Persia, any sword, - straight , curved, local blade, foreign blade, - is still a " shamshir". In Afghanistan there are no pulwars or pseudo-shashkas: all of them are " shamshirs".
In Russian there is no special word for "fighting" short-bladed weapons i.e. what in English is called a " dagger". So, they took a Georgian word for their national dagger, "khanjali", modified it to "kindjal" and since then every short-bladed weapon in Russian is just " kindjal". Kindjal- jambiya, kindjal- tanto, kindjal- kris, and even kindjal- kindjal:-) That is how they are often defined in catalogues and even academic books.
This is a Name Game of the lowest sort....
Old 20th December 2021, 02:46 PM   #9
mariusgmioc
Hello Ariel,
You may have noticed that I specified "in my opinion"...
And yes, I am aware of the name variations but I am also aware that at least some of us can be a little more specific by consistently using specific names for specific swords.
We are neither Turkish to call all swords kiliç, nor Persians to call them shamshirs, but we are international collectors and can use more specific terms for clarity.
Old 20th December 2021, 09:57 PM   #10
Peter Hudson
I did some work at http://vikingsword.com/vb/showthread...t=omani+swords on Omani Shamshiir The silver sword knot looks like typical to Omani style but looking at the scabbard it seems to be a replacement...and theres very little other silver work of Omani style on the weapon thus difficult to place. At reference I placed the Omani Shamshiir presented to Henry Morton Stanley by Sultan Bargash for comparison...
Regards Peter Hudson
Peter Hudson is offline   Reply With Quote
Old 22nd December 2021, 06:42 AM   #11
Hello Ariel,
Nothing was meant to contradict you; if you read it as an attack, I apologize, I did not mean to offend you or anybody. The " Name Game" was specifically addressed to to the " kindjal-tanto" type definitions.
My whole point was that names depend on the language of origin: shamshir, saif and kilic are all translated as "sword" in their respective places of origin and will change depending who wields them or where they were bought. Moreover, we all grew on the Stone's "Glossary" that still is a Bible of collectors, but has some questionable points. Khanda for example was described as a straight sword with rounded and widened point, Old Indian Basket handle and reinforced edges. Well, in the Elgood's Jodhpur book there are quite a few khandas that lack most or all Stone's criteria. I asked him for the reason, and his explanation was simple: these swords existed over hundreds of years in localities with different languages ( even contemporary India has 60 official languages with more than a million speakers each in addition to a multitude of local ones). What was called Khanda in Gujarat not necessarily was regarded as such in Odisha. Bichwa and Baku are the names of the same dagger in different parts of India.
Or take Morocco for example: they have 2 major national weapons, Nimcha and Koummya. Well, locally they are called Saif ( Arabic origin) and Khanjar ( Persian origin).
I am all for calling weapons by their correct names, but linguistic origins do not necessarily coincide with our "Stone- derived" education. Ottoman swords with typical Persian blades were locally called " Kilic adjemi": a mix of a Turkish word for "sword" and acknowledgement of its Persian feature.
Sometimes, a cautious approach is useful: Lebedinsky's term "pseudoshashka" was appropriate , but Lord Elphinstone visiting Afghanistan in the first half of the 19th century specifically noted that locally they were calles "shumsheers". Paintings of the battle between Nader Shah Persians and Afghanis ( 18th century) show that both used guardless sabers and frescos in Western Georgian churches show Georgian aristocrats ( 17th century) carrying real "shashkas". Calling Afghani "pseudo-shashkas" and, especially, guardless sabers from Central Asian Khanates "shashkas" and tracing their origin to Russian Cossacks is against elementary historiography, since there was not a trace of Russian presence in Central Asia at those times. But we still see this word on e-bay, in Russian books and articles.
Again, I am all for using correct names, but sometimes it is difficult because of our ignorance. Robert Elgood collected close to 40,000 entries for different " Oriental" weapons. I hope his future Glossary will correct some of our confused definitions. Just wish he would not limit himself to Indian weapons , but saved couple of thousands of entry cards for the Islamic ones, too:-)
Old 22nd December 2021, 01:30 PM   #12
mariusgmioc
No worries Ariel! We "know" each other from some time and even when disagreeing I don't think we take it personally. And I quite enjoy a good healthy disagreement from time to time.
I just wanted to clarify a little my position pertaining the name game. Of course we can call every small, single-edged-bladed weapon a "knife," and we would be correct.
However, we can be much more specific and confer much more information by calling each specific single-edged-bladed weapon kard, bichaq, karud (I know you particularly like this one) , choora, lawi ayam, puukko, tanto, etc. And if we do it, we'd rather be consistent.
Old 22nd December 2021, 03:37 PM   #13
I am all for it. As long as the names we use are their native ones and we use them correctly.
And, yes, karud is my pet peeve:-)
