Old 18th November 2021, 12:53 PM   #1
algrennathan
algrennathan's Avatar
Default Clip point Filipino sword
Just wanna ask. Are clip point bolos endemic to a certain province in the Philippines, or were they widespread all over Luzon during the revolution. Just asking cause I'm just a but puzzled. There seems to be no standard configuration for these. Some appear in Pangasinan hilts, sometimes Tagalog, other times Ilocano. By the way I am referring to a fighting blade not some farmer implement.
algrennathan is offline   Reply With Quote
Old 18th November 2021, 06:18 PM   #2
Hello Nathan(?),
Yes, clip point blades are quite widespread - there are some in the Visayas, more so throughout Luzon.
I believe Xas can show some nice examples...
Old 18th November 2021, 08:26 PM   #3
algrennathan,
Welcome to the forum and thanks for posting this question.
Just to clarify what you mean by "clip point." Are you referring to blades where the spine angles abruptly downwards towards the edge, but nevertheless has an acute point? Or are you referring to a blade which essentially has a blunt end, as if the point has been cut off?
To illustrate with a figure from Cole's early 20th C paper on the Tinguian people of northern Luzon. Are you referring to blades such as shown in #2, or blades like those in #5 and #6? Blades like those in #2 are very common throughout the Philippines, while those like #5 and #6 are less common but also found widely.
Old 18th November 2021, 09:13 PM   #4
Hello Ian,
I for one was referring to something like #2 (there are many different variations) - that seems to vibe with the OP referring to a fighting blade, I believe.
Old 19th November 2021, 12:22 AM   #5
Hi kai,
Yes, that was my interpretation of the question also. There are many versions of the sinan bartolome in Luzon that cut across ethnic groups and have prominently clipped blades. There are also the imitation 'Bowie" blades made widely for local and foreign use.
However, there are some fighting versions of the second type, including the "katana" of the Aeta in Central Luzon (as made by local Pampangans).
Ian.
Old 19th November 2021, 02:57 AM   #6
algrennathan
algrennathan,
Hi Ian.
Yes, I was referring to no. 2. Can you tell me more about this blade shape?
Old 19th November 2021, 10:49 AM   #7
xasterix
xasterix's Avatar
Hello Nathan(?),
Thanks for the redirect Kai! Unfortunately I'm still expanding my knowledge in this topic as well. Although I've noticed even Mindanao has clip point blades too they're just not as easily recognizable (nor as common) as Luzon and Visayas clip points.
