Old 16th August 2021, 12:53 PM   #1
h0ll0wman
Default Neglected antique kris restored
I just got this kris today. It was in bad condition. The blade was heavily rusted, the hilt is wrapped in rubber, and the scabbard has a missing metal ring. After hours of restoring this kris, here it is now with beautiful lamination patterns. The hilt and scabbard still needs to be restored.
h0ll0wman is offline   Reply With Quote
Old 16th August 2021, 06:23 PM   #2
David R
David R's Avatar
That was fast.....
Old 16th August 2021, 09:51 PM   #3
Indeed! Nice kris, please let us see it again when you have restored hilt and scabbard. How you have cleaned in short time the blade? And what you have used as etchant? Nice pattern.
Old 17th August 2021, 01:17 AM   #4
Hi h0ll0wman,
Nice kris. I think the blade is probably Sulu in manufacture, and likely from the late 19th-early 20th C. The longitudinal insert is not twist core but has nice laminations. The hilt is atypical and similar to Visayan-influenced styles I have seen previously from Moro pieces originating in Zamboanga. The wrap-around metal (is it aluminum?) on the pommel is likely held in place with small nails and from that area I believe. The scabbard is of a Mindanao style also. Your etch looks like ferric chloride--is that what you used?
Old 17th August 2021, 02:15 AM   #5
h0ll0wman
Hello Detlef. Thank you. I soaked it in vinegar first for a couple of hours. I then used sand paper for the heavy rusts. 100-400-600-1000- and finally 1500 grit. As for the etchant I used ferric chloride
Old 17th August 2021, 02:18 AM   #6
h0ll0wman
Hi h0ll0wman,
Thank you for the information Ian. I thought it was twist core at first, but still the lamination pattern is beautiful. I am not sure if this is the original hilt and I am thinking of having it replaced. The metal on the scabbard feels and looks like aluminum. Yes you are correct that I used ferric chloride for etching.
Old 17th August 2021, 06:05 AM   #7
The scabbard and blade looks Maguindanao to me, and maybe the hilt as well. But the wrap was done later and the aluminum mounts might have replaced silver mounts.
Old 18th August 2021, 01:24 AM   #8
h0ll0wman
Thank you for this sir. I think I shall retain the hilt and have it wrapped in silver.
Old 1st September 2021, 07:15 PM   #9
mross
That looks really nice.
Last edited by Ian; 4th September 2021 at 01:18 PM. Reason: While José no doubt appreciates the referral these suggestions are better transmitted via PM
