Old 31st July 2021, 11:26 AM   #1
Peter B.
Peter B.'s Avatar
Default Unknown sickle
Hello all together.
I'm new to the forum as a member and I would like to thank for all the usefull informations I found here till today as anonymous reader.
I'm living in Germany and I'm mainly interested in african and indonesian weapons.
To start here I want to show a sickle shaped weapon or tool which I have never seen before. I have no idea what it could be. I would be glad if someone can help to identify this item.
I bought it some years ago at a weapons fair; I found it in a box with indian stuff, all of it defect and mostly scrab. This was the only thing there that was in a nearly reasonable condition.
But to me it looks not as from India.
The sickle is very heavy, it weights nearly 1kg. It is 51cm long and the sickle-part has a triangular cross-section with 1cm wide at the back. If it is a tool, than you can use it only like an axe, but not as a sickle .
All ideas about origin and usage are welcome.
Thanks and best regards
Peter
Peter B. is offline   Reply With Quote
Old 31st July 2021, 12:47 PM   #2
Look very much African.
Old 31st July 2021, 03:48 PM   #3
Pieje
Pieje's Avatar
Looks like a Tutsi or Shi sickle sword (Congo, Rwanda)
https://ertribal.com/index.php/triba...umuhoro-rwanda
Pieje is offline   Reply With Quote
Old 31st July 2021, 04:32 PM   #4
Peter B.
Peter B.'s Avatar
Thanks for your answers.
African was also my first idea because of the bend tang at the bottom of the grip - a typical african way to fasten the grip to the tang. But maybe someone elsewhere had the same idea...
Sure it looks similar to a Tutsi sickle, but I have never seen such a form. The Tutsi sickles I know have allways the ?-shape at the upper part and a flat profile there.
Old 2nd August 2021, 08:23 AM   #5
Peter B.
Peter B.'s Avatar
No more ideas on this strange item???
Old 26th July 2024, 10:23 AM   #6
Peter B.
Peter B.'s Avatar
I did some more research and found a few more images on the web, all labeled as Indian.
In a Russian article about Indian weapons, I found a drawing of a similar object with the following explanation:
"Figures 72 and 73 are objects used for collecting the sap and fruit of the Palmyra palm."
I can easily imagine it being used for this purpose.
