Old 27th May 2021, 08:03 PM   #1
francantolin
Default Gurade sword with nice french blade
Hello dear members,
I wanted to share with you the pictures of this ethiopian gurade sword,
made with a french blade,
Manufacture Impériale de Chatellerault 1856 Cavallerie mod 1829,
the blade was rusty/ almost black,
I cleaned it/ sand it a little it , a nice pattern ''came out'',
I haven't seen a lot of european military blades with this kind of damas steel,
not usual !
am I right ?
Old 27th May 2021, 08:20 PM   #2
Gonzoadler
Gonzoadler's Avatar
I'm not sure if it is damascus, I think the steel is just folded for refinement.
The hilt is made of rhino horn.
Good sword.
Robin
Gonzoadler is offline   Reply With Quote
Old 27th May 2021, 09:04 PM   #3
David R
David R's Avatar
Until "fluid cast steel" became common, most if not all blade making involved a certain amount of folding and hammering. Shear steel was a the norm for a decent blade for a very long time. https://www.merriam-webster.com/dict...Dshear%20steel
Old 28th May 2021, 01:41 AM   #4
Will M
Will M's Avatar
The odd appearance of the blade surface is from corrosion. Water trapped with the blade in a scabbard does exactly this. It can become fairly deep and you will continue to see it even after later use without a scabbard. Originally the blade was polished and water would puddle making this type of pattern for lack of a better term . These French blades are not folded steel.
Old 28th May 2021, 09:15 AM   #5
Duccio
Duccio's Avatar
The blade is certainly very beautiful and interesting, but I like to emphasize the beauty of the hilt and the fact that it is in perfect condition, which happens very rarely!
Congratulations, a truly beautiful object.
Duccio is offline   Reply With Quote
Old 28th May 2021, 10:12 AM   #6
francantolin
Thank you all for your messages,
I'm not sure about damascus but I don't think humidity and water can make this ''pattern'' so deeply ''engraved'' in the blade,
I sanded it ( 400 and 600 grain ) and it's still like that
as David said I think it has a high carbon amount and was folded and hammered many times.
For the hilt, a nice surprise, ( with a nice knob)
a chief leader sword ?
Kind regards
Old 28th May 2021, 12:58 PM   #7
Iain
Iain's Avatar
Kind regards
Water can and does make this sort of corrosion, seen it many times from storage in poor conditions in leather scabbards.
A nice sword though!
Old 29th May 2021, 06:58 AM   #8
Kubur
Kubur's Avatar
No this blade is not damascus... Well you have a beautifull 19th c French blade and a terrific rhino hilt, what do you want more?
I wish to have the same.
Old 29th May 2021, 07:26 AM   #9
francantolin
Just for share,
and for knowledge
THANK YOU !
