I was pretty pleased to win this Atayal knife yesterday on Ebay. It came out of a lot from Japan. I've cleaned up and organized the Ebay photos a bit. I think this would be late 19th or early 20th C. The darkened area on the back of the scabbard is interesting, it looks intentional but not particularly decorative. That would be the part of the scabbard visible from behind per the style of dress/carry in the attached photo. Perhaps for stealth?
My plan to attack the rust is to start with white vinegar soak followed by sand paper, please let me know if there is a more recommended method. I am also wondering about repair/stabilization options for the rattan on the handle. |
Nice catch Jeff. These are not easy to find.
Here are some I have had. They vary considerably in size, from knives up to full sword length. Blackening on the back of the sheath of the largest one is also present.
#4 | |
According to the seller this one 63cm OAL and 71.5cm in sheath. |
Hi Jeffs,
White Vinegar yes, but domestic steel wool rather than sandpaper. Even a firm rubbing with a rag will often surfice if the rust is not too bad. Very nice knife by the way. Stu |
Hi Jeff,
The loop on the scabbard came with it and appears to have some age and wear. As far as the rattan, I would simply give it a light oil to moisten it up again. The rattan dries out in our climate and gets brittle over time. |
#7 | ||
One would think there would be a bit more common practice within a tribal group. |
Here are some of the photos in case of interest
#9 | |
Scotchbrite is quite abrasive. I would not use that unless the rust is stubborn. But anyway keep resoaking with White Vinegar and use steel wool, which should polish rather than scratch the surface. Stu |
#10 | |
Exercise patience, weeks or more or patience if you need to. Get yourself a good bronze brush too, it will help the process along... keep away from abrasive products unless you are very certain in what you are doing and can fully subdue the results with a proper polish. Gavin |
Hello - here is a 5 day update and request for advice. I've been doing vinegar soak followed by brass brush and Rhodes Grade 00 steel wool about 3 to 4 times a day. It has been in and out of white vinegar continuously this entire period. Definitely an exercise in diminishing returns, a few very stubborn rust spots as seen on the photos remain. Overall the surface is covered in pits, I wouldn't classify them as particularly deep but very widespread. If I continue on this path I will end up with the stubborn rust spots removed but the overall blade quite rough from pitting. Again I'm inclined to move to sanding, starting at maybe 320 to subdue the pitting and moving up incrementally to 1500 grit for polish.
#12 | |
Keep going with the vinegar soaking.....it will shift the rust, but GIVE IT TIME. If you have a piece of rigid brass (sheet or bar), you could use that to loosen the caked rust. Use it like a wood chisel. Brass is softer than steel so will not scratch it. It looks to me as if there is still rust in those minor pits also. Stu |
#13 | |
#14 | |
I should have said that if you have a spent brass cartridge case somewhere around 303 cal, squash the open end and use that. Handy tool which I use often in this situation. Stu |
Here we are now. The bumped contrast makes the pits seem darker than they are to the eye. Except for a couple small spots I believe the rust is completely gone now, perhaps one or two more soaking rounds. Note the blade on the open scabbard side has much more extensive pitting, you can see the outline of the staples. The question is, what next?
Also, please see the scabbard photos. What options are there for repairing the cracks? I've been feeding the wood oil for several days but the long thin crack at the foot of the scabbard is not closing. The crack series along the staples have wider gaps but seem more stable. |
Hi Jeffs,
Good job IMHO. I think you have now reached the stage where you need to decide how far you want to go. Bear in mind that the knife has age so unless you want something which looks "shiney new" I personally would not go any further with the blade (just my opinion) Some like to "restore" to the extent that all of the age patina is gone. Regarding the scabbard, I would stabilise that long crack with a suitable wood glue, other wise there could be a risk of total breakage. The small cracks along the edge are probably age cracks, so I would leave as is. Note the above is my opinion and no doubt others will have different suggestions. Stu |
#17 | |
#18 | |
Depends on how dry the wood is after you have oiled it. I would use PVA wood glue if the wood is dry enough. Apply glue and then clamp the crack together and allow time for glue to dry. What is your plan regarding the rust on the staples? If you are able to remove them from the scabbard easily then maybe they should be soaked in vinegar also. I have never owned one of these knives so don't know how the staples are fitted. If they can not be removed easily then maybe rub some vinegar on them with a rag. A word of caution....If you do remove the staples make sure you number them so they go back in the same place. They look to vary in length. Stu Last edited by kahnjar1; 29th September 2020 at 06:25 AM. |
#19 |
JeffS, I've been reading about your progress in the cleaning of your very nice and rare sword, and the only advice that I feel qualified to give you is"DO NOT REMOVE THE STAPLES."They will break, the wood will splinter and they will never go back in the way they came out. I would gently use the brass casing first and then sandpaper; make sure that the metal strips are supported from the underside as you softly apply pressure from the top.
#20 | |
#21 |
I agree with Drac. I had not thought of the staples being brittle. Leave them in and support from underneath.
Stu |
#22 |
Here it is after finishing rust removal, oiling dry stuff and fixing cracks. Also, below is a close-up of blade detail. It looks like a layered construction versus an inserted edge to my novice eye. I find the perpendicular gaps interesting that track some of the layers.
#23 |
Hi JeffS,
What a difference!! Great job if I may say so. ![]() Stu |
#24 | |
#25 | |
Stu |
