Abstract
An iron sword from an Iron Age megalithic burial at Thelunganur in Tamil Nadu, India, was examined using metallographic techniques. The sword was made of ultra‐high‐carbon steel with a fairly uniform microstructure consisting primarily of fine cementite particles in a ferrite background free of notable non‐metallic inclusions. The morphological control, however, was not perfect and frequently allowed cementite to precipitate in the form of a network along austenite grain boundaries. It was also observed that carbide particles of varying size and shape often caused microscopic layers to develop, forming a visible pattern to the naked eye on the polished and etched surface of the iron sword. This pattern likely inspired the later development of various surface markings such as the damask. This paper presents a detailed account of the analytical data to show that the iron sword under consideration was an early example of high‐carbon steel employed in the manufacture of a functional object where the divorced eutectoid transformation technique, rediscovered recently, was used for the control of cementite morphology. It is also proposed that technologies for making and handling high‐carbon steel were in existence at a much earlier date than previously supposed. INTRODUCTION Carbon concentration and its distribution pattern constitute two key factors that determine the functional properties of an iron sword, which can be optimized by taking the balance between strength and ductility. The selection of raw materials therefore plays an important role in the establishment of a particular sword‐making technology. If high‐carbon steel were used to take advantage of its high strength, it would be necessary to improve the low‐impact resistance arising from its high carbon concentration. India was famed for the early production of a special high‐carbon material termed crucible steel. In his survey research on traditional Indian crucible steel, wootz, Bronson (1986) concluded that it was produced by a wide range of processes, not only just as super steel but also as a material for common use. Despite its fame gained as the raw material for Damascus blades, Bronson noted that crucible steel was not a material of choice among warriors, primarily due to its brittleness. This brittleness arises from its high carbon concentration, which is generally > 1%. (Chemical compositions in this paper are based on weight fraction.) Such high‐carbon steel contains a substantial amount of iron carbide (Fe3C), termed cementite, which is brittle even at temperatures up to its melting point. This brittleness poses serious difficulties in fabrication or service and cannot be overcome without a high level of technological sophistication. Raw materials similar in carbon levels to Indian crucible steel were produced elsewhere in the world using a variety of techniques, most of which involved the use of cast iron in one way or another. Such high‐carbon materials were then employed as intermediaries to be made into finished items with processes that caused a substantial reduction of their carbon level (Park 2004, 2005, 2008). Evidence was found, however, that the technology for processing high‐carbon steel in India was rather unique and focused on controlling the shape, size and distribution of the cementite phase (Park and Shinde 2013b). In a certain sense, therefore, the discovery of proper techniques for handling such high‐carbon materials signifies the beginning of crucible or other high‐carbon technologies, and Indian ironworkers should thus also be recognized for their in vention of such processing methods. Bronson (1986) traced the beginning of Indian crucible technology to the second century ce , at the earliest, by refuting the prevailing hypotheses of earlier dates based on certain classical sources of the 5th‐century bce onwards. He also rejected Hadfield's interpretation that some of the iron objects excavated from the Sirkap site at Taxila, Pakistan, were made of crucible steel (Marshall 1945). In a subsequent review article drawing on an extended body of literary and archaeological evidence, Craddock (1998) reinforced most of Bronson's conclusions. Craddock, however, regarded the Taxila iron objects examined by Hadfield as an example of crucible steel, and suggested that crucible processes were practised by the first centuries of the first millennium ce . On the other hand, recent studies (Srinivasan 2007; Srinivasan et al . 2009), based on the investigation of crucible fragments and metal particles recovered from ancient sites in Tamil Nadu (Rajan 1997), proposed that the crucible process was likely practised as early as the mid‐first millennium bce . Despite substantial debate over the origin and production of Indian crucible steel, little is known of thermomechanical treatments developed for the fabrication of such high‐carbon materials into finished products. Much work (Verhoeven and Peterson 1992; Verhoeven et al . 1996) has been done on Damascus swords to understand the mechanisms responsible for the emergence of their unique surface patterns. However, the information from such research cannot be used to infer technologies practised in Indian antiquity. In this respect, the recent work of Park and Shinde (2013b) is significant as it reported on a small piece of unprocessed high‐carbon steel and small finished items evidently made from such a high‐carbon material. In addition, they produced radiocarbon data placing the date of manufacture to the last few centuries of the first millennium bce . The objects these authors examined, however, were ordinary items weighing approximately 10 g, or less. Their data, therefore, cannot be extended to address the technological and chronological aspects associated with the use of high‐carbon steel in the manufacture of important functional items, such as swords. Similarly, the analysis of a Sasanian sword dating to the sixth to seventh centuries ce (Lang et al . 1998), one of the earliest examples of such products thus far examined, is also far from sufficient. A unique opportunity to resolve this lack of information is provided by an iron sword (Fig. 1) recently recovered from an Iron Age megalithic burial site at Thelunganur in the Salem district of Tamil Nadu, India (Fig. 2). The site can be dated to the sixth century bce or earlier based on typological grounds (Rajan 2004; Rajan and Yatheeskumar 2012), indicating that the sword could be an early archaeological example of a high‐carbon material successfully processed into a finished product. The results presented below are expected to shed a new light upon the discussion of Indian high‐carbon steel in terms of its technology and chronology. ================================================= SUMMARY AND CONCLUSIONS The metallographic examination of a double‐edged iron sword recovered from a ritual context of an Iron Age megalithic site at Thelunganur in Tamil Nadu, India, showed that it was forged out of high‐carbon steel with a carbon content of 0.9–1.3%. The specimens examined were clean and free of any notable non‐metallic inclusions. Their microstructures were fairly uniform and consisted primarily of fine spherical cementite particles in the ferrite background. The high carbon content, absence of slag inclusions and uniform microstructure—rarely obtained in bloomery smelting—are features characteristic of crucible steel produced from a fully molten state. In addition, the formation of ferrite bands in one specimen given the proper thermal treatment confirms that the material examined was the product of a solidification reaction. It may therefore be suggested that the blade under investigation could possibly be one of the earliest examples of a crucible steel product. More importantly, the carbide phase precipitated in the form of fine spherical particles provides clear evidence of special thermomechanical treatments applied in the processing of such a brittle material for fabrication. The treatments likely involved the divorced eutectoid transformation technique, which was rediscovered in the 20th century ce for the effective exploitation of high‐carbon steel. The shape and size of cementite were not perfectly uniform, which in some cases caused a laminated structure to develop in the microstructure, creating colorful patterns visible on the polished and etched surface. This pattern, once noticed, may have inspired the later development of varying patterns leading to the famous damask. The above results show that technologies needed to facilitate both the production and the processing of crucible or other high‐carbon steel were largely established in the Thelunganur region of Tamil Nadu by the time the sword was made, approximately around the mid‐first millennium bce . The application of such technologies, however, was apparently not always perfect and might often end up with a tragic and premature failure of crucible steel products. https://onlinelibrary.wiley.com/doi/...12503-fig-0001 Only put the intro and conclusion of the link here. But its very well researched article. Last edited by Milogow360; 27th July 2020 at 11:47 PM. |
Miloglow360,
Thanks for posting about this interesting article. We like to credit the original authors of the works we cite, so here is the relevant citation: Park J-S, Rajan K, Ramesh R. High-carbon steel and ancient sword-making as observed in a double-edged sword from an Iron Age megalithic burial in Tamil Nadu, India. Archaeometry 62:68–80, 2020. (available online here) I have attached larger images of the sword, which appear as Figure 1 in this article and have the following description. Figure 1. |
Very interesting, thanks. But, unfortunately, there is not so clear with the definition of the time period. In the case of the definition time of the burial ground, the author refers to his own articles, and radiocarbon analysis shows only delirium.
![]() I'm sure this is an absolutely reliable study, but in some questions we need to be careful. https://frontline.thehindu.com/cover...le30255049.ece https://en.wikipedia.org/wiki/Indigenous_Aryans
#4 | |
If it's a megalithic culture of S. India it's pretty old. Crucible steel production is known in early on S. India and Sri Lanka. Just not in the manufacturing of something like a sword however, until now. Recently they found a iron dagger, riveted copper hilt as well. With sheets of metal riveted together to form the hilt. The first one is a recently found copper hilt with rivets. The rest are from an early dagger found dating 6th century BC without rivets, but similar hilt design. https://punemirror.indiatimes.com/pu...w/68339114.cms The hilt design is old as seen from the 2nd-1st Century BC warriors. I havent seen the hilt design again after 1st Century AD+, at least not in India. Last edited by Milogow360; 2nd August 2020 at 10:51 AM. |
This might be interesting to some as well. Early Iron weapons are showing up in megalithic sites in the South. It's currently a developing topic.
The hilt design in one of the swords has a similar shape to the daggers above, and the relief, statue already posted. “Even as the survey had begun for excavation, the Centre has decided to set up a museum at Adichanallur at least now, which would tell the world about the ancientness of Tamils and their civilisation. The carbon dating conducted on the products recovered from this site in Florida labs had proved that it was at least 2,900-year-old civilization. If the excavations are done properly, the world will be surprised to see how advanced ancient Tamils’ life was,” says Mr. Kamarasu. https://www.thehindu.com/news/nation...le30716873.ece Carbon dating of samples excavated from the Adichanallur site in Thoothukudi district has revealed that they belonged to the period between 905 BC and 696 BC. The March 18, 2019, carbon dating report of samples that were sent to Beta Analytic Testing Laboratory, USA, was submitted to the Madurai Bench of the Madras High Court on Thursday. https://www.thehindu.com/news/cities...le26737779.ece Last edited by Milogow360; 2nd August 2020 at 12:43 PM. |
Thank you again. But the question is how old are weapons made of high-carbon steel. Ultra-high-carbon steel. Forged into a long sword.
#7 | |
The other megalithic dagger examples I gave with hilts designs that are classical as well. |
Oops... I got it. The sword was found by a non-archaeologist (one of the authors - R. Ramesh) at the bottom of some "pit" without any research of this pit itself or the accompanying material (we were only told about "an urn enclosed with a capstone"). But since the megalithic burials in this area "dated to the sixth century BCE or earlier" so this pit was dated to 6th century BCE too. How graceful.
The article does not meet the standards of scientific archaeological research, although one of the authors (K. Rajan) is a respected archaeologist. Just pit, just sword, just an archaeologist-enthusiast, but as result we have the oldest sword made of wootz. Just very sad. Hope I am wrong.
