Old 1st August 2020, 10:55 AM   #1
Hefezola
Default Moro Swords
Sharing some of my grails. I'm into collecting moro swords.
If anyone could share more regarding these grails will be much appreciated.
Hefezola is offline   Reply With Quote
Old 2nd August 2020, 12:47 AM   #2
Please do share images as time allows.
Gavin
Old 2nd August 2020, 05:20 AM   #3
Hefezola
Default Sorry
I didn't noticed that images where not uploaded due to its size.. Will repost soon..
Old 2nd August 2020, 05:30 AM   #4
Hefezola
Default My Grails
Here it is... Probably the photos weren't been uploaded in the original post due to size issues.
Old 2nd August 2020, 09:31 AM   #5
Hello Hefezola:
Thanks for sharing your kris and barung. The kris appears to be a broad-bladed example from the Sulu Archipelago, dating from mid-20th C I would think. It is missing its other stirrup, or it is a very unusual single stirrup example with the stirrup on the back side of the blade (I have never seen that before, so I think it is probably missing the other one). The hilt is a horse hoof style commonly found on mid-20th C examples.
The barung are all Sulu as well (probably Tausug) and likely date from the 20th C. One is missing part of its kakatua pommel, but it is 20th C too.
Each of your swords has been cleaned very well and I like the subtle etching that you have given them--the patterns are clear. Did you use nitrol or acetic acid?
Old 2nd August 2020, 07:22 PM   #6
Cthulhu
Cthulhu's Avatar
Very pretty pieces, and as Ian says, showing a lot of lovely patterning.
I'm particularly fond of the half-waved kris form (rantai I believe it's called), so I'm envious.
Cthulhu is offline   Reply With Quote
Old 3rd August 2020, 07:09 AM   #7
Hefezola
Originally Posted by Ian
Hello Hefezola:
I used vinegar to clean some rust then cleaned it. . I used 60%water 40% ferric Chloride acid solution for etching...
Thank you for your inputs...
Is there in any way I could do for etchibg where patterns and lines come out boldly?
Old 4th August 2020, 04:48 PM   #8
There most likely is, but as far as i know a bold and contrasty display is not traditional to these weapons as it would be for, say, a Javanese keris.
Old 5th August 2020, 03:51 AM   #9
I think they are fine as they are.
Old 6th August 2020, 06:27 PM   #10
Hefezola
Default I think so too
Same here... Was thinking og redoing everything... 😂 I think they are fine as they are
Old 8th August 2020, 07:32 AM   #11
Yep. Just fine etching for me too.
Old 9th August 2020, 07:31 AM   #12
Here are some of my Philippine holy grails:
