Old 7th April 2020, 05:25 PM   #1
CharlesS
CharlesS's Avatar
Default The Rare and Artistic Sinhalese Patisthanaya
First, and foremost, my best wishes for well being and good health to my fellow forum members!
The patisthanaya is a polearm from the Sinhalese people of Ceylon/Sri Lanka. It would appear to have a lot in common with a European partizan. While their iron and steel heads can take many different forms they always form some degree of a "trident" as a common denominator. There are also elongated bolsters running down from the head and fastened to the haft on many examples. Their hafts are often painted in red, gold, and black geometric designs and circles, a form and colors apparently associated with the capital city of Kandy.
This example is especially nice as it features brass inlay atop chiseled work(smewhat like we might see on a piha kaetta) along with delicate floral motifs chiseled into the blade and sleeve. Note the unusual way the bolsters are mounted and fitted under the sleeve. You will also see mysterious holes to each side of the sleeve where apparently some other attachment was mounted...perhaps one of our forum members may know what was there???
I have attached a pic of my others so that you can see the variations and commonalities in blade types.
These are certainly one of the ethnographic world's most unique and flamboyant polearm types.
Dimensions:
Overall height: Just under 7ft.
Blade and sleeve(including extended bolsters): 16in.
Blade alone: 9.25in.
Width of the "trident": 3.25in.
Old 8th April 2020, 12:44 PM   #2
Gustav
Hello CharlesS,
a beautiful patisthanaya.
Regarding the holes - see one example sold by Peter Dekker,
Also an interesting article about Sinhalese lacquer work:
https://www.mandarinmansion.com/arti...e-lacquer-work
Old 8th April 2020, 02:58 PM   #3
DhaDha
I wish I knew more about these. Just beautiful.
Cheers
Old 8th April 2020, 08:48 PM   #4
CharlesS
CharlesS's Avatar
Excellent info Gustav. I feel sure you are right. I do wonder why there would essentially be two "guards" right next to each other, but your pics make sense. The chiseling work on the steel guards is typically impressive!
Thanks for your input!
Old 20th April 2020, 05:12 PM   #5
kino
kino's Avatar
The pole arms are indeed flamboyant. The shield is equally beautiful. Is it hewn from wood or is it leather?
Thanks for showing these.
Old 29th April 2020, 12:13 PM   #6
CharlesS
CharlesS's Avatar
Hi Kino,
Thanks for the comments. The shield is lacquered hide. The lacquer has "crazed" and lost its luster over time.
Old 3rd May 2020, 02:51 AM   #7
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Dear Charles,
Can you throw some light onto the situation with this weapon … In your opener you said these two weapons were virtually of the same name and clearly they are the same design. Who was first onto the battlefield with the Partizan .. The Sri Lankans or the Portuguese. Assuming that the Portuguese were there as the first of the Europeans? No one has ever stated the clearly obvious fact that the two are originally the same weapon and that the Sri Lankans simply copied the weapon....
Old 3rd May 2020, 09:25 PM   #8
And if I may make a reasonably proper reference A to this subject I would choose the one hereunder...and from the same stable as noted by Gustav above.
Reference.
A. https://www.mandarinmansion.com/item...e-patisthanaya.
Old 16th June 2020, 05:36 AM   #9
Prasanna Weerakkody
Prasanna Weerakkody's Avatar
Excellent example of a Patisthana. I am from Sri Lanka and these are always a pleasure to see for me.
These patisthana with second set of wings are believed to be guard arms for artillery and from what I gather from old locals is that the second set of wings were for attaching a lit match fuse cord and used to fire cannons.
I am also very curious about the shield in the last image. does that have any reference that it is from Sri Lanka.
Best Regards
prasanna
Prasanna Weerakkody is offline   Reply With Quote
