Old 22nd March 2020, 09:15 AM   #1
aspalathos
Default Halberd or partizana?
Hello did someone know what is it, I have it for some tiime . Was it decorative or maybe something for battle.
aspalathos is offline   Reply With Quote
Old 22nd March 2020, 11:58 AM   #2
This sure is not a decorative piece but the real thing, Aspalathos; only that it suffered a lot of damage, starting by the removal of the side straps and apparently some smash of the blade side wings. A pity it is in so bad shape.
Old 23rd March 2020, 12:09 AM   #3
Yvain
Yvain's Avatar
As I mentionned in the other thread, I'm pretty sure it was a fonctionnal item, obviously pre-1850 (due to the structure of the steel), but likely much older, probably found in an excavation.
To me, it kind of looks like an "épieu", or "spear" in english, with its leaf blade, strong midrib, and lugs; not an halberd or a partisan in my opinion though. Epieux were mostly used to hunt but some saw use in combat (as described in Froissart' Chronicles for example). The faceted socket reminds me of some specimens from the XVth century, but it could of course be much later.
Old 23rd March 2020, 09:25 AM   #4
Lansquenet59
Lansquenet59's Avatar
I am thinking of a weapon of war, because there are the pieces of fasteners on the sides for the wooden shaft (the splints as we say in French). Even if they are cut, we imagine their extension. It was a reinforcement to avoid the iron being cut by a heavy blow of horseman's sword ....
Lansquenet59 is offline   Reply With Quote
Old 23rd March 2020, 10:53 AM   #5
Originally Posted by Lansquenet59
... because there are the pieces of fasteners on the sides for the wooden shaft (the splints as we say in French) ....
Also called side straps, as per post #2 .
Old 23rd March 2020, 02:26 PM   #6
Lansquenet59
I understand better now
Old 23rd March 2020, 04:42 PM   #7
aspalathos
Gentlemens, thanks for the reply.
Old 23rd March 2020, 10:32 PM   #8
Philip
Philip's Avatar
Default what to call it?
Mario Troso, in Le Armi in Asta delle Fanterie Europee 1000-1500 (Pole arms of European infantry) provides a very good classification of such weapons. On page 105 he illustrates several examples, all of which are characterized by dual lateral projections or lugs between the socket and blade, these can be either pointed or with squared ends.
Names for this type of weapon include Spiedo da guerra, Knebelspiese, winged spear, or épieu de guerre.
There are further examples on p 106, two are large examples with perforated triangular wings or lugs., George C Stone, in his Glossary... of Arms and Armor pp 122-23, identifies this type as a "Bohemian ear spoon" It is interesting that the entry for this item follows that for "Boar spear" -- one example of that group, in the Metropolitan Museum of Art, has a pair of fixed lugs on the socket as well, which establishes a conceptual link between weapons designed for sport as well as war.
Old 28th March 2020, 01:56 AM   #9
BUCC_Guy
BUCC_Guy's Avatar
Appears to be a late 16th to early 17th c. halberd type often attributed to Austria.
The form is the same, but the rear hook, axe, and langets have been removed.
See here for a very similar example.
http://www.antiqueweaponstore.com/Et...ca.%201600.htm
BUCC_Guy is offline   Reply With Quote
Old 28th March 2020, 03:11 AM   #10
CSinTX
CSinTX's Avatar
Looks like you nailed it!
Old 28th March 2020, 01:33 PM   #11
We could see that aspalathos example was damaged but ... not to such an extreme point.
Old 28th March 2020, 02:08 PM   #12
Lee
Lee's Avatar
Wink
So, once upon a time long ago, someone may have had an old halberd and wanted a boar spear...
Old 28th March 2020, 02:16 PM   #13
Old 29th March 2020, 06:14 AM   #14
Philip
Philip's Avatar
Those projecting lugs make it ideal for the purpose of poking piggy and minimizing the danger of him being run clean through and coming up to tusk the hunter. Great suggestion, Lee!
Old 29th March 2020, 01:39 PM   #15
Oh i see, Filipe. Shame on me. I took it that Lee's entry was only to offer a little humor .
