Old 14th November 2019, 11:06 AM   #1
Cerjak
Cerjak's Avatar
Default A swivel cannon For comment
The peculiarity of this gun is that the touch hole normaly on te top of the breech is located in the side of the barrel with a pan.
It might help to determine the origin and may be the production period.
Over all 140 cm and 102 cm of barrel.
Caliber :37.4 mm
Weight 17.2 kg
any comment on it will be welcome.
Old 14th November 2019, 01:26 PM   #2
Fernando K
Hi Cerjak
I can't say anything, but I wonder if the barrel is bronze or iron. In the first case, I would explain that the bread is melted at the same time as the barrel, and explain why the ear is at the side-
Affectionately
Old 14th November 2019, 01:51 PM   #3
Kmaddock
Kmaddock's Avatar
HI Cerjak
The shape of the pan and the flared muzzle looks very similar to that on an Indian Jezail musket
looks interesting, congratulations on acquisition
Ken
Old 14th November 2019, 03:51 PM   #4
Cerjak
Cerjak's Avatar
Hi Cerjak
Affectionately
Dear Fernando.
the cannon has a very deep patina and it is difficult to be certain if it's iron or bronze. Traces of green oxide (at the junction of the handle and cannon) can be seen, which would also look like bronze. By scratching the surface maybe I'll have a chance to see.
Best
Jean-Luc
Old 14th November 2019, 03:55 PM   #5
Cerjak
Cerjak's Avatar
Originally Posted by Kmaddock
HI Cerjak
Ken
Hi KEN
Thank you for your comment ,it is exact that there is similarities to Indian Jezail barrels.
Best
CERJAK
Old 14th November 2019, 04:13 PM   #6
GIO
GIO's Avatar
[QUOTE=Cerjak]Dear Fernando.
You can try with a magnet
Old 14th November 2019, 04:18 PM   #7
Cerjak
Cerjak's Avatar
[QUOTE=GIO]
Originally Posted by Cerjak
Dear Fernando.
Exact it is the easier way to determinate if it is or not Iron.
Old 14th November 2019, 04:35 PM   #8
Will M
Will M's Avatar
I would think originally it had a flintlock mechanism. The wood appears to be later without a way to mount a mechanism.
Old 14th November 2019, 04:55 PM   #9
Cerjak
Cerjak's Avatar
yes it could be a possibility
Old 14th November 2019, 06:25 PM   #10
Cerjak
Cerjak's Avatar
It is a Iron barrel .
Old 15th November 2019, 12:03 AM   #11
thinreadline
thinreadline's Avatar
the touch hole is identical to that on my Indian wall gun
Old 15th November 2019, 01:03 AM   #12
Fernando K
Hi Cerjak
In my modest opinion, and if you want to continue the research, it could be determined through a study, if the barrel has been formed by forging, or by function, that is, if it is wrought iron or cast iron. I think it's with X-rays
Affectionately
Old 15th November 2019, 08:44 AM   #13
I note a set of fixed front and rear sights. They look like they are shorter than the band that is around the barrel to fit the trunnions and swivel pin. It does make me think it's a repurposed musket.
Also, what is that smaller diameter pin forward of the main swivel pin supposed to do? looks like it would prevent swivelling or downward elevations.
Old 15th November 2019, 06:49 PM   #14
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Please see #5 at http://www.vikingsword.com/vb/showth...t=camel+cannon
Could this also be a camel gun? A lot of indication of something Indian going on here ...My camel gun is very similar. Take all the woodwork to one side and the barrel could easily be from a camel gun...
Here is a camel gun below usually fired from a crouched position or dismounted.
Old 15th November 2019, 07:10 PM   #15
Found a few camel guns while looking around. the last one seems a bit too modern tho. The sepiatone one appears to show sights as well as a side touch hole and pan.
(the last photo is a joke of course)
Old 16th November 2019, 01:04 PM   #16
Cerjak
Cerjak's Avatar
Dear Ibrahiim and Kronckew
Many thanks for the pictures. ( I have attached the picture #5)
actually it is a possibility to not dismiss this gun could very well be a camel cannon.
Best
Cerjak
Old 19th November 2019, 05:29 AM   #17
Philip
Philip's Avatar
I wonder about the reaction of the typical camel to any one of those guns being discharged above its head. I've read somewhere that it takes a bit of training to accustom a cavalry horse to the sound of gunfire; do camels have a notably different disposition as a rule?
Old 20th November 2019, 11:06 AM   #18
Yes they are trained to not notice the bangs and anyway they cannot run off as the firing is done when they are crouched and tethered. The guns are relatively quick to dismount completely but still the animals need to be tied so they cannot run off..They are funny creatures and even when trained can be spooked by a leaf blowing across their track and will bolt for the oddest excuse. They are trained to the camel stick. About ten camel sticks are used in a typical training program of a few weeks to bash the animal around the head until the stick breaks!! This is cruel but its how its done. consequently the beast is almost completely stick responsive except for a few additional guttural sounds from the handler. Conversely the stick is rather like a car key and the camel will not obey the rider unless he has one.
ACTUALLY THE STICKS SHOWN HERE ARE NOT THE MORE FLEXIBLE BAMBOO TYPE USED FOR CAMELS...BUT MORE THE DRESS ITEM..
Old 20th November 2019, 12:11 PM   #19
Please see http://www.vikingsword.com/vb/showthread.php?t=21529
Old 23rd November 2019, 07:40 AM   #20
To keep a camel tapped into line here are the sticks which are indian bamboo known in arabia as erg. On the left old and very expensive and on the right again costly single and multiple node sticks ...
Old 1st January 2020, 12:56 PM   #21
Spottedbull
This cannon is fascinating to me. I had no idea that there was a such a thing as a camel cannon! As I looked at the photographs I had thought that it was rather like a matchlock barrel.
Spottedbull is offline   Reply With Quote
Old 2nd January 2020, 02:23 PM   #22
The firing device is a matchlock form... Actually the thread landed here on European and I think it is obvious that it is Ethnographic thus I would suggest it be moved over there..
Old 2nd January 2020, 04:25 PM   #23
Alright then. Let's;move it .
