Old 20th June 2019, 08:47 PM   #1
Wodimi
Wodimi's Avatar
Default unknown sabre, possibly North Africa
Dear members, maybe somebody can help me with this sabre and know what it is or have seen a similar sabre. The wooden scabbard, covered with leather, is for me typical African work. The handle have little similarities to a Flissa handle. The star marks on the blade could be from Morocco.
I would be very happy if somebody have an idea.
Thanks.
Wodimi is offline   Reply With Quote
Old 20th June 2019, 09:38 PM   #2
A.alnakkas
A.alnakkas's Avatar
Thanks.
An authentic Yemeni sword. Of lower quality iron mounts but with a good trade blade and what looks like a solid hilt. These are readily available compared to the other ones with finer and older mounts but still nice to own.
Old 20th June 2019, 09:57 PM   #3
Agree 100%
Old 20th June 2019, 10:07 PM   #4
Wodimi
Wodimi's Avatar
thanks friends, that was quick. With this help I found also an old thread with a similar sword.
http://www.vikingsword.com/vb/showthread.php?t=15084
Old 20th June 2019, 11:43 PM   #5
This Yemeni form seems to follow the 'karabela' hilt form in a more stylized manner (the left sword in the photo of three) which resembles the stylized trilobate silver repousse hilts of Hadhramaut (third photo).
The blade is of German trade blade form and the stars in configuration seems either a variation or interpretation of the Schimmelbusch maker group of 19th century. Similar markings with stars are seen on some of the so called "Zanzibar' nimcha blades as well.
The heavy, 'hatchet' point was favored throughout 19th c. in Arabia and into the early 20th.
Ive always considered these Arabian swords attractive and fascinating.
The entries on Schimmelbusch markings from Bezdek (2000).
Old 22nd June 2019, 01:13 PM   #6
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Thanks.
Wodimi, Pleased you traced through Library my thread on these weapons which I attribute to Sanaa although Muttrah was where the pictures were taken. They also go in for a lot of rehilting work there but usually of Omani style blades.. This almost Karabela form is Yemeni or at least rehilted there. Although somewhat rough they still retain a certain charm..The blade displays the famous 7 star cluster which I thought was Plieades or the 7 sisters... I can never remember.
Ibrahiim al Balooshi.
Old 22nd June 2019, 02:52 PM   #7
Further recognition for an excellent research note by Jim on this subject of the star cluster on blades ...The entries on Schimmelbusch markings from Bezdek (2000). Neatly tying down the issue.
Old 22nd June 2019, 08:19 PM   #8
Thanks very much Ibrahiim! Question....did the seven stars have special significance in Arabian arms as far as symbolism? I know that in China, the constellation of Ursa Major, or seven stars represented the configuration of the 'seven wells', a production center (I think Long Guan but cant recall) where high quality blades for China were made. A sort of Chinese 'Solingen' if you will.
Could such symbolism have transmitted into Arabian parlance in the manner that the dual moons (dukari) did in North Africa?
Old 23rd June 2019, 10:08 PM   #9
grendolino
grendolino's Avatar
Default Not a very simple one
Those sabres seems to me be not essentially a very simple ones but rather suitable for battle. All I have seen live or online were mounted on 18th century Hungarian or German blades, always being rather weary.
Their quillons though rough ones were forged thus being the better protection than those silver or steel but soldered sheet made or of cast brass.
Some of them also had a decoration similar to Sanaa or Sa'da Assib jambiyas what can give a clue of their origin.
grendolino is offline   Reply With Quote
Old 26th June 2019, 08:31 PM   #10
Reference..
A. https://www.bing.com/search?q=plaeid...ESR4N&pc=EUPP_
Full marks to Grendolino with this great example of The Seven Sisters star symbols better known as Pleiades or M45. Ref A above refers to much of the background at web on the star system and mythology. The German blade makers applied much Talisman for effect from astrology mainly the sun often with eyes nose mouth accompanied by fanciful rays.. and funniface moons. Peter Munch (Solingen)is credited with these under his name but a footnote also suggests these were not sword makers marks but applied purely as Talisman and quite at random. What may be seen on typical blades at thread are occasional locally applied marks perhaps to raise the price? On the other hand trade blades in the typical profile with heavy back blade and three deep fullers may well all originally have been star marked in Solingen. Other weapons must have also been so stamped...see below.
What is certain about the silver decoration on the example scabbard is its Yemeni origin as this is typical sand cast low quality silver often seen on Yemeni work.
Jim...Regarding the Big Dipper...The Plough or The Great Bear ...URSA MAJOR … I have avoided that but note its Chinese name and as you say the 7 wells etc and will place a post covering that situation but just to keep the two so called seven star constellations separate for the moment...
Old 27th June 2019, 10:09 PM   #11
[SIZE=4][SIZE=7][SIZE=6]Here an example of a completely different constellation The Plough or Big Dipper or Great Bear or URSA MAJOR but from the Chinese perspective. This star group famous as the pointer to Polaris or The North Star...
So below a Ming Dynasty Chinese sword with the main stars shaped in formation and inscribed on the blade top left.~
Naturally there are many interpretations of Ursa Major and although I am asked about the Chinese ..at the same time there are other fascinating accounts including Hindu and even North American Indian concepts worth viewing at https://howlingpixel.com/i-en/Ursa_Major
Staying with the Chinese concept please see https://www.chinasage.info/stars.htm from which I quote Quote'' The Great Bear is split into two constellations and is the seat of divine justice. The ‘Seven Stars’ in China can refer to sun; moon and the five major planets but also to Ursa Major ➚ (the Northern Dipper or Plow or Great Bear). The Great Bear appears directly overhead at times over parts of China and was therefore considered the center of the heavens. Known as 北斗 Běi dǒu ('Northern cup') in China it was represented as a red faced god who determining death and plays chess with the Southern Dipper. The seven stars of the dipper are important in Daoism and are often shown as august figures in pictures who can bring long life and wealth. In the ‘Flying Star’ system of Feng Shui it is these stars that determine good fortune. The Dipper has been used in the West to quickly find the pole star but the Chinese used other pairs of stars to find it, for example the stars in the constellation of Orion".Unquote
