Old 17th June 2019, 02:37 PM   #31
A crop.
The blade indentation is damage
Gustav, why do you say the von Sulz keris is heavily reshaped?
Old 17th June 2019, 10:57 PM   #32
Gustav
Alan, just to be sure - the area marked with red is damaged? Thank you for the cropped image.
Regarding von Sulz Keris - because the distance between center ridge and blade edge varies a lot. Generally it seems to have lost its original width above Sorsoran, it looks to me just like the edges were resharpened, sometimes seen on Keris in Europa used as (hunting) weapons. Very similar look above Sorsoran has the Keris on p. 94 in Jensen's book.
Old 17th June 2019, 11:40 PM   #33
Yes Gustav, the area you have marked with red is a big chip out of the blade.
Thank you for your reasoning on the possible re-working of the blade.
Old 30th August 2022, 12:05 PM   #34
I know little about these old keris and the history attached to them, but just a casual uninformed passing comment... there are numerous Sulawesi keris that in one sense or another follow this profile
I continue to read and learn.
Old 30th August 2022, 10:33 PM   #35
Thank you for your comment Gavin.
When you say that some Sulawesi keris have a profile similar to the stone carving that has a chip, I have never seen this, could you perhaps post an image of one or more of these Sulawesi keris with a profile similar to the chipped stone carving?
Old 1st September 2022, 10:38 AM   #36
Apologies for the mis quote Alan, I was referring to the keris Gustav presented, just loosely speaking...the first image is a rather acute cut away where more traditional lines flow through this area in a nice sweeping curve.. the second one, whilst not a pronounced cut away, does exhibit some features that are aligned with the von Sulz keris... to my eye at least...
Old 1st September 2022, 10:55 AM   #37
I'm sorry Gavin, but I don't really understand what you mean.
What I can see is the von Sulz keris with its slightly unusual form, and the two sections of keris that you have posted with nothing unusual at all that I can see.
Even the von Sulz form can be found in some Javanese keris of a later date.
To me, all three of these keris are just forms that fall within the parameters of Javanese & other keris form.
Gustav thought that the von Sulz keris might have been reshaped, & that is possible, probably most older keris have been reshaped somewhere along the line, part of the maintenance procedure for keris calls for frayed or chipped edges to be tidied up, so over time the keris loses its original form.
The von Sulz might have been reshaped for some other reason, to me all this is normal & expected its probably not even worth comment, it is just what happens.
