Old 29th November 2018, 11:46 PM   #1
Aslan Paladin
Aslan Paladin's Avatar
Default Outstanding Twist Core Moro Budiak Spear
This Moro budiak was recently auctioned over at E-bay and was suddenly pulled out, probably after the seller was offered a hefty sum by a private buyer. The seller wanted US buyers only so I couldn't bid on it. It is one of the most eye catching Moro budiak I've ever seen - twist core blade, plaited silver wire sleeve, wooden shaft exquisitely carved to imitate bamboo and a munsala cloth attached to it. Unfortunately the shaft is cut down. Hopefully the lucky buyer is a forumite and could post additional pictures.
Aslan Paladin is offline   Reply With Quote
Old 1st December 2018, 07:45 AM   #2
Yeah I like this one too. Unusual to have this type of wood carving like this. Great twist core and that bronze and silver weaving, amazing. That mansala intrigues me. Too bad it was cut down.
Old 1st December 2018, 10:14 AM   #3
Aslan Paladin
Battara have you seen any other budiak as ornate as this? I mean from the blade to the shaft everything is a stand out - it's as if whoever made this decided to pull out all the stops in terms of decorating it. The munsala is the icing on the cake - and the quality of the munsala itself is striking. And I haven't even seen any other budiak with a munsala before this one. Which makes me wonder - what other undiscovered unusual specimen of budiak could possibly there be, one with tiger bells perhaps?
Old 1st December 2018, 01:10 PM   #4
Aslan Paladin
Speaking of munsala, I found a similar-looking munsala while searching the web, this one on a kris.
Old 1st December 2018, 01:58 PM   #5
Lee
Lee's Avatar
Smile Decorative of functional?
From an old thread here is another 'carved' treatment of a budiak pole. Possibly it simulates bamboo, but functionally it might have assisted in reducing the likelihood of the pole slipping in the thruster's hands.
Old 1st December 2018, 03:02 PM   #6
Post
Hello Lee,
Yours is not carved: rattan is much more commonly utilized than bamboo because it is much sturdier, especially those varieties with many "knots" along the stem.
Fresh bamboo makes good and very simple instant spears just by sharpening the tip; once the bamboo dries out, it becomes quite brittle and not suitable for warfare.
Neither is formally wood: Rattan is from climbing palms while bamboo is a grass.
Old 1st December 2018, 04:31 PM   #7
I have never seen a budiak carved like this before. As far as metal work and bling, I have seen others, 2 even better (one owned by Ian) all decked out in silver.
Asian you are brilliant! The Kris mansala matches perfectly, which might indicate that this budiak is Maguindanao in origin. Great work! 👍
Old 1st December 2018, 07:01 PM   #8
Lee
Lee's Avatar
Default Natural Form
Originally Posted by kai
Yours is not carved ... rattan is from climbing palms
Thank you for pointing this out; upon close examination of this shaft I can see that you are correct and that this is a natural formation. Interestingly, I realized that I had two budiaks with this soft of a shaft. Both use the wire reinforcement and both have suffered some splitting of the rattan around the tang of the blade.
Old 1st December 2018, 08:48 PM   #9
My apologies Lee.......I had forgotten your beautiful examples (one which I forgot I restored).........😉
