Old 12th November 2018, 02:17 PM   #1
alex8765
alex8765's Avatar
Default Unknown dagger
Hi gents,
Can you please help me to identify this dagger?
Thank you in advance
alex8765 is offline   Reply With Quote
Old 12th November 2018, 10:00 PM   #2
Welcome to the forum, Alex .
Let us see how challenging is to ID your dagger !
Old 12th November 2018, 10:24 PM   #3
alex8765
alex8765's Avatar
Thank you Fernando.
Old 13th November 2018, 01:27 AM   #4
kahnjar1
kahnjar1's Avatar
Welcome Alex.
Definitely not my field, but to me it LOOKS like a military type hanger of some sort (2 suspension rings). The blade could be from a shortened Lebel bayonet, but then I am only guessing. Hopefully someone will be able to identify more accurately.
Stu
Old 13th November 2018, 12:48 PM   #5
Looks to me like a typical soviet era eastern block/Russian style military parade dirk or dagger. I do not think it's a repurposed French bayonet. The AO mark may tell where it came from.
Old 13th November 2018, 12:55 PM   #6
alex8765
alex8765's Avatar
I agree, it looks similar to Imperial Russian naval dirk, but it's not. Russian or Soviet daggers don't have riveted handles or brass scabbards.
In the last couple of years I’ve seen two more identical daggers with the same markings “AO”. So, looks like this could be officially issued dagger.
Old 13th November 2018, 07:18 PM   #7
What are the handle grips made of; bone ... plastic ?
Old 14th November 2018, 08:11 AM   #8
alex8765
alex8765's Avatar
The handle grips made of bone.
Old 14th November 2018, 11:35 AM   #9
Madnumforce
Yes, it looks like a naval dirk of some sort, but that construction is unusual.
What I can tell you is it's not a Lebel bayonet blade. The geometry is all wrong. The "flutes" on the Rosalie are much narrower and deeper, with side at square angle to each other and a radius at the bottom. The taper doesn't match either.
Madnumforce is offline   Reply With Quote
Old 14th November 2018, 02:33 PM   #10
Belgian1
Default Poignard sous officier Russe
Bpnjour,
Il faudrait se renseigner du coté des poignards de sous officier de l'Armée Impériale Russe vers la fin du XIXe. Il me semble que les officiers avaient des poignards avec une lame fort ressemblante mais avec fourreau de cuir et garniture de laiton.
Belle journée
Belgian1 is offline   Reply With Quote
Old 14th November 2018, 04:46 PM   #11
Originally Posted by Belgian1
Bonjour,
Belle journée
It seems as Belgian1 forgot (or failed) to convert his post text into English.
Let's help him this time ...
It would be necessary to inquire on the side of the sub-officers (NCO) daggers of the Russian Imperial Army towards the end of the 19th century. It seems to me that the officers had daggers with a very similar blade but with leather scabbard and brass trim.
Have a nice day
Old 15th November 2018, 09:18 AM   #12
Kmaddock
Kmaddock's Avatar
Hi All,
The Russian 1891/30 Mosin Nagant Socket Bayonet also had a cruciform shape
As did a lot of Austrian and other Russian bayonets
Just google
Russian/Austrian Cruciform Bayonet
Here is a link the Mosin Nagant bayonet
http://worldbayonets.com/Bayonet_Ide.../Russia_2.html
Ken
Old 19th November 2018, 05:52 PM   #13
alex8765
alex8765's Avatar
Thank you gentlemen.
