Old 2nd October 2018, 03:11 AM   #1
Rafngard
Rafngard's Avatar
Default A batman keris selit
Hello All,
I picked this up a while back but am only now getting to posting photos. Size wise I think this would be called a keris selit, though I believe that term is Malay specific, and this seems to be from Southern Sumatra. I think I've read that these come from somewhere between mid 19th - WWII. Given the surface texture of the blade, I suspect this one has some age, but I'm not a very good judge of this.
The blade has a naga carved on it. I wonder if this is a latter addition.
As always, any thoughts, comments, opinions, etc are welcome.
Thanks,
Leif
Old 2nd October 2018, 10:48 AM   #2
Jean
The scabbard and hilt are from South Sumatra and the rustic naga seems original from the pics (the pamor lines are continuous).
Old 4th October 2018, 05:58 PM   #3
Wink
Hello Jean,
While the pamor seems to extend through the naga, the latter does seem to be a candidate for it being recarved from a plain gandik of an originally larger keris. In any case, it is rather poor craftsmanship as you laready suggested...
Old 4th October 2018, 10:47 PM   #4
The quality of craftsmanship in an item of tosan aji is most certainly relevant when that item is intended to be seen as a work of art, or if it is the production of a known and respected empu or pande.
However, when an item of tosan aji has been made originally for a talismanic purpose, or has been altered to fulfil a talismanic requirement, the quality of craftsmanship comes a very distant second to the esoteric content that the item is perceived to enshrine.
The craftsmanship of this little blade is certainly not what one would expect to see from a noted maker, and there is perhaps a possibility of alteration at a time following its original production, however, in view of the probable intent of a keris such as this, I personally would not consider the question of quality of craftsmanship to be relevant in even the smallest degree.
Old 6th October 2018, 11:38 AM   #5
Jean
I don't know if this kris was made for talismanic purpose but this type of short kris seems to be common in South Sumatra, see a similar piece (without naga) with a 25cm long blade of better craftsmanship.
Old 6th October 2018, 12:41 PM   #6
Or perhaps more recent Jean?
Old 6th October 2018, 06:25 PM   #7
Rafngard
Rafngard's Avatar
There's another one very much like mine (with the naga) in this thread, specifically in posts 1 and 8.
http://www.vikingsword.com/vb/showthread.php?t=23672
Thanks,
Leif
