Old 4th April 2006, 12:12 AM   #1
William.m
Default Need Help with my first Keris
Hello all, I bought my first keris today after having collected Talibon for a whole, but my keris has some problems. Firstly the scabbard is cracked along the side and the wide opening part is wobbles quite a bit, and may fall off at any time.
The blade itself looks okay but im very worried with the amount of red rust present on the blade.
I have read up on the various ritual cleaning techniques of the keris, but how do I properly clean the keris from this red rust in order to preserve the blade?
Thanks guys,
Will
Ps: If anybody has any info on this keris I would be fascinated to hear about it.
William.m is offline   Reply With Quote
Old 4th April 2006, 12:28 AM   #2
nechesh
nechesh's Avatar
Welcome William. Sometimes it helps to do a good search of the old threads since this is ground we have covered many times now. Here's a link to the old forum which has some very valuable info for you.
http://www.vikingsword.com/ubb/Forum1/HTML/000717.html
As for the wobble, you probably just need to wrap a little extra material around the tang (pesi) to tighten up the fit. You are going to need to remove the hilt anyway to clean your blade, so just twist it carefully back and forth while pulling it towards you and the handle should easily come off. You should use thin strips of material or thread (some use yarn), but add it slowly and check the fit. It you over do it you could crack the hilt putting it back on.
Did your keris come with a sheath?
Old 4th April 2006, 12:41 AM   #3
William.m
Hi nechesh thanks for the reply.
The looseness that I was talking about was with the sheath/scabbard. I will post some more pictures of the sheath tomorrow, as it is in pretty bad condition. I have been a long time lurker on this forum and the old, and I have read that post you kindly linked me. Thing is that I don't want to use these fruit acids on the blade as the blade's white pattern (nickle) will dull, and I do not have access to the arsnic needed to clean the blade, nor do I want to use it with there being kids running around the house.
Many thanks,
William
Old 4th April 2006, 02:03 AM   #4
Are those grind marks I see on the edge ?
William , try a toothbrush and some oil for starters .
Old 4th April 2006, 10:23 AM   #5
William.m
Okay done that, although instead of oil I used a dishwasher soap. I got some results but there is still plenty of red rust that will not go. Later today I am considering putting the blade in a bath of lemon juice, or possibly rubbing half a lemon on the blade. But instead of this could I give it a bath of vinegar instead?
Many thanks,
Will
Old 4th April 2006, 03:49 PM   #6
Will , I think you might do better with unsweetened pineapple juice as it is less acidic than your other two choices . Being less acidic the process might take longer but you will have more control .
Old 4th April 2006, 07:23 PM   #7
William.m
Hello, I have managed to clean off most of the rust using half a lemon, worked very well!
The only problem now is that the blade is a tad too shiny and so is there any way to blacken it a bit without having to use arsnic or anything like that?
Cheers,
Will
Old 4th April 2006, 08:32 PM   #8
Henk
Henk's Avatar
Will,
Although not the usual way you can use ferric chloride to get the pamor back. Another method is sulphur acid. But before you do this you should remove al the rust with the lemon juice. I suppose you already did this because the blade is shiny. But the best thing you can do is find somebody who can re-etch the blade with arsenic. Then you get the pamor back with the blade deep black.
Old 5th April 2006, 01:32 AM   #9
nechesh
nechesh's Avatar
William, if i were you i would go back to the thread i linked for you and work this out step by step. It seems you are in a bit of a rush to work this blade and i think it might be to your benefit to slow down and attack this situation more methodically. I agree with Rick that pineapple juice is a great acidic liquid to use. You really MUST remove ALL of the rust before you can even think about restoring the pamor pattern of this blade. I would let this puppy soak for a while (a few days) frequently brushing the surface with an old toothbrush. Once this is done you can start to figure out how to stain it. But truthfully, the arsenic and lime mixture (warangan) is the only thing that will restore the proper color to the iron. Other chemicals will raise the pamor, but it won't be quite right. There are people who can do this work for you if you don't want to mess with such sustances.
Old 5th April 2006, 11:03 PM   #10
William.m
Hiya, okay well it looks like my option is to find somebody in the UK who can do the whole arsnic thing. Do you know how anybody who I could contact?
As to the pinapple juice, I have some in a tin is this okay to use?
Thank you all very much for the help so far.
Will
Old 5th April 2006, 11:46 PM   #11
nechesh
nechesh's Avatar
Sure, the stuff in the ti is what i use.
Your blade looks like it has a very clear pamor and it should stain up nicely when you can find someone to do it.
Old 5th April 2006, 11:52 PM   #12
Will
Unsweetened pineapple juice ?
Okay .
Probably okay even if sweetened as sugar shouldn't affect the acid content ( but I may be talking out my a%se on this point ) I'm sure someone will correct me if I'm wrong .
You could send it to the US for traditional staining ; I'll ask a friend if he's up for the job . There may also be someone in Holland who can do this (any of our Dutch members , time to speak up) !
Old 8th April 2006, 01:03 AM   #13
BluErf
BluErf's Avatar
I'm going to wash a keris blade this evening, and I'm going to use grapefruit juice, straight from the tetrapak. As long as there is citric acid in the juice, it should work. Vinegar is fine, if you don't mind the smell. But based on my experience, vinegar gives a darker grey look while citric acid gives a whiter look. Not sure why.
Old 8th April 2006, 03:17 AM   #14
There's really no substitute for the traditional warangan stain .
