Old 31st March 2006, 03:17 AM   #1
Emanuel
Emanuel's Avatar
Default About a Khodme
Hello, I've had this simple khodme for a while now and I've been thinking a lot about it lately. I have some questions , not least of which is whether it is a functional knife or a tourist piece.
First of all it is 29.5cm long, with a 17.5cm blade.
The scabbard is wooden and covered in red/tanned leather.
Two things are very weird about it; the guard seems to be an unnatural addition, and the blade seems to have been re-worked at the base/ricasso. It starts off 1mm thick at the base, thickens to 5mm for a good part of its length and finally tapers to a fine point. The metal is solid, it seems functional, but I can't understand the thinness at the base, where the blade has been widened/hammered. There are signs of glue at the guard, and the hilt has some play to it. The underside of the guard shows a slit for the blade/tang that is wider than the hilt and only 1m thick, supporting the reworked blade hypothesis. Such knives have been discussed many times before, but they didn't show these problems. Any thoughts?
Manolo
Old 31st March 2006, 09:18 AM   #2
Hi Manolo:
I think it is a reworked flyssa blade. The blade profile is unlike other khodmi I've seen which are pretty much straight along the spine and they don't come to a needle point like this example. The hilt looks similar to a khodmi with its wire-wrapped segment and square handle with circular designs, but khodmi don't usually have a guard and the handle usually has a hole through it for a cord or leather loop.
Close, but not a typical khodmi.
Ian.
Old 31st March 2006, 02:19 PM   #3
Emanuel
Emanuel's Avatar
Hello Ian,
If it were a flyssa blade I imagine it would be just the tip then. The handle does have a hole in it right above the wire wrap and bellow the concentric circles. I still wonder at the need to re-fashion the base of the blade in such a manner, why make it so thin and wide?
The whole thing is surprisingly solid, I tried bending it and the blade won't budge. The hilt does move lightly and it seems that the tang is very short, no longer than the wire wrapping.
Anyway, many thanks for the reply.
Manolo
Old 31st March 2006, 04:14 PM   #4
Lew
Lew's Avatar
Manolo
I have two flyssa one large and one small and I don't think as Ian stated that your knife was made from a flyssa blade it would have a thicker tapered spine. I really think this is a locally made variant of a khodmi made for the tourist trade. I have seen the same hilt and guard on a few versions one actually had a kris style blade with the same markings as yours. Here is a link to that kris bladed one. As you can see the kris bladed piece is a nonfunctional blade which leads me to think these knves are made for the tourist trade.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=6602494709
Lew
Old 1st April 2006, 01:22 AM   #5
Emanuel
Emanuel's Avatar
Hi Lew,
The ebay example is extreme! The decorations on the blade are nearly identical to those on mine, so I guess that answers my question about it being a tourist. Still interesting that a functional blade was reworked instead of grinding from thin metal like so many other examples.
I noticed another weird thing; the scabbard is embossed with figures on what would be the back, while the blade is decorated only on the front. Seems the merchants responsible for this piece weren't at all careful.
Thanks,
Manolo
