Old 30th September 2017, 04:43 PM   #1
Cerjak
Cerjak's Avatar
Default Early 19 century matchlock teppo with Tokugawa mon
With an Heavy smooth, octagonal, 15 mm cal. barrel, decorated with the Tokugawa mon
Overall 118 cm barrel 85 cm.
Unfortunately the serpentine is broken
Old 1st October 2017, 02:55 PM   #2
estcrh
estcrh's Avatar
Well a least the rest of the parts are there. How did you get this date "Early 19 century"?
Old 1st October 2017, 06:25 PM   #3
Cerjak
Cerjak's Avatar
Hi Estcrh
This Gun was catalogued as an early 19th century teppo.
What is your opinion about the period?
Thank you for the pics.
Best
Cerjak
Old 1st October 2017, 10:44 PM   #4
estcrh
estcrh's Avatar
Hi Estcrh
Best
Cerjak
From what I have learned, the area of manufacture can often be determined by certain characteristics but the date would have to come from removing the barrel and seeing if it is signed by the maker and or dated as is often the case.
Old 7th October 2017, 04:16 PM   #5
rickystl
Hi Cerjak.
Nice looking Teppo. Yes, too bad about the broken serpentine.
As Estcrh mentions, if there are any marks it is usually on the botton of the barrel/plug. And in my case, there was an additional mark on the inside of the stock and a small piece of linen with maybe an inspector's mark.
There are probably similar marks/dates on the bottom of your barrel.
Old 8th October 2017, 06:54 PM   #6
Cerjak
Cerjak's Avatar
Hi Rick,
Yes I believe that precious informations are certainly in the hidden side of the barrel but to remove the barrel without making damages around the pin holes it
will be difficult :There is some materials who obstruct the pin holes so it why I'm still not decided to do it.
Best CERJAK
