Old 17th July 2017, 01:16 PM   #31
Kubur
Kubur's Avatar
Originally Posted by ariel
As it is now, the sword may be covered by the insurance. If it is not returned, the insurance is void. And, if the attempt of straightening fails, the buyer will be left with a broken sword and no money.
Yes of course, he has to send it back.
Plus the scabbard is damaged too...
Old 17th July 2017, 02:05 PM   #32
Yes, all true, my thoughts were directed at preservation, not remuneration.
Old 17th July 2017, 04:33 PM   #33
Nathaniel
Nathaniel's Avatar
Estcrh,
Sorry to see the shipping tragedy. It reminds me of a similar USPS incident I had a couple years ago when I bought a pole arm from a respected forum member.
Note before:
Old 17th July 2017, 04:38 PM   #34
Nathaniel
Nathaniel's Avatar
And imagine my shock and horror when the postal worker brought this out to the counter for me to sign for!!! I told the postal worker are you serious you want me to sign for this!?!? And they just shrugged and said my best bet was to fill out a damage claim form Luckily this was fully insured! But still would have rather had a straight pole arm! Because the post paid the claim USPS keeps the pole arm!
Old 17th July 2017, 05:09 PM   #35
estcrh
estcrh's Avatar
Originally Posted by Nathaniel
And image that sinking feeling when the postal worker brought this out to the counter for me to sign for!!!
Nathaniel, thanks for posting your pictures, I know exactly how you feel, even though I will get the money I paid returned it hurts to see this happen to any antique. The damage to your naginata looks just like what happened to my shamshir.
As I mentioned earlier, I just shipped a naginata much like yours in order to get some missing fittings replaced (habaki and tsuba), Tim Pepin the owner of Samuraisword.com just messaged me that it arrived safely but after what happened to the shamshir I kept thinking about how I could have done a better job of packing, I did not add any wood strips etc which would have greatly increased the chance of avoiding any damage to the blade or shaft, next time I will do that just as added protection.
Below is a picture that Artzi of Oriental Arms just sent me showing how he has reinforced for shipping the Chinese bow I just purchased. A great example that I intend to copy in the future.
Old 17th July 2017, 05:22 PM   #36
estcrh
estcrh's Avatar
Once is one thing, but seeing this other very similar extreme damage example has really opened my eyes, I do not think I will simply rely on luck anymore when I ship any kind of weapon in the future.
Old 17th July 2017, 11:53 PM   #37
Pieje
Pieje's Avatar
Several months ago I've sent a naginata from Europe to the USA using DHL.
I bought a 2m long plastic tube to be sure it arrived safely, off course it did.
Pieje is offline   Reply With Quote
Old 18th July 2017, 12:44 AM   #38
Nathaniel
Nathaniel's Avatar
I would agree with,Pieje. Thank you for bringing this up! These plastic tubes are a good option however you have to make sure that the plastic some flex and is not brittle. I have had a plastic tube crack apart before.
Old 18th July 2017, 01:33 AM   #39
Default Industrial Strength
I showed you guys some of this stuff in post #9; it comes in varying diameters and is practically indestructible due to double wall construction. It is also lighter than the PVC tubing shown in other's posts.
The stuff can be a bit hard to find; try electrical contractors supply companies.
Old 19th July 2017, 06:56 AM   #40
Philip
Philip's Avatar
These tubes are really handy for just about all spears, and polearms like nagynatas that aren't too wide or curved. Others, like halberds, ronconi, and the like, are problematic due to the width. But you can still use the PVC tube to "armor" the shaft area, then run a couple pieces of wood to brace the sides of the head, extending down the shaft a ways, following the principle that Artzi used to reinforce the Chinese bow. You have to "build" a heavy cardboard or thin plywood casing to enclose the head where it comes out of the tube, but if everything is strong and tight, there should be no worries. I'm a great believer in Gorilla Tape to hold things together.
The trick is to protect sharp points and corners on weapons that don't come with scabbards. Corks, or wrapping with a strip of cardboard plus lots of tape and a prayer, are NOT foolproof. The sides and end of the casing need to be protected with wood covering any possible area that the tip can move and poke out.
Old 19th July 2017, 11:29 PM   #41
estcrh
estcrh's Avatar
Another near disaster, this box contained a rather rare and valuable pistol and tabar. The box was split open and the end of the pistol barrel was sticking out, fortunately there did not seem to be any damage. The box was lined inside with additional cardboard and the items were bubble wrapped.
Old 20th July 2017, 12:28 AM   #42
Philip
Philip's Avatar
Angry ouch! ready for another horror story?
Just today UPS delivered 3 talwars sent by a customer for restoration. I set the box down on one end so I could sign the delivery receipt, and felt something heavy go "thunk" inside. Turns out that one tip protruded about an inch, enough to nick the hardwood floor of the vestibule and it wasn't the first time it happened in transit because the point was already bent at an angle Sender used a flimsy box, not enough padding to keep contents (banded together) from "sloshing" , and absolutely nothing to guard the exposed points on these swords!
I tend to discourage the use of UPS anyway, they tend to beat up parcels in general, almost as bad as the postal service, but neglected to advise sender in advance. One shipment, last year, was received with corner of box cut open and a couple of sword fittings purloined
Old 21st July 2017, 09:18 PM   #43
rickystl
Here's another handy item to use in packing. Works well for many items.
Air Conditioning tubing insulation. It's very inexpensive and you can pick it up at any Home Depot or Lowe's. If I recall, it comes in about 4 different diameters. Saves a lot of extra packing wrap, etc. in many cases.
As an example: I wrap gun barrels with this insulation, tape the ends, and then slide it into a PVC tube. That way the gunsmith can simply return it to me in the same tube. Just change the shipping label.
I can see this assisting in packing some blades, crossguards, handles, etc.
Just an extra idea.
Old 22nd July 2017, 01:03 AM   #44
Neil
Neil's Avatar
So Sorry. For whatever it is worth you are clearly not alone. I have had numerous bent blades and broken tips over the years too.
I tape wooden shims over the ends of the bare blades I send and pack the surrounding areas firmly. Over seas packages go in strong tubes. I also write in fragile in large print on all sides of the packages.
Just my two cents.
Neil is offline   Reply With Quote
Old 23rd July 2017, 10:14 AM   #45
estcrh
estcrh's Avatar
I just received a full refund including shipping. The seller offered a partial refund if I decided to have the sword repaired but I decided not to risk it.
Old 23rd July 2017, 06:16 PM   #46
rickystl
Well, glad you received a full refund in this sad situation. Probably the best outcome in this case. But I'm sure you will not forget about that shamsir for a while. Such a shame.
Old 31st July 2017, 03:26 AM   #47
silberschatzimsee
silberschatzimsee's Avatar
That tip with the plastic pipe is very good. With smaller diameterpipes i trsnsport my fishing rods in the plane.
silberschatzimsee is offline   Reply With Quote
Old 3rd August 2017, 10:09 PM   #48
Helleri
Helleri's Avatar
I like using cardboard edge/corner reinforcement for objects that are significantly heavier and hard than a box they would be shipped or moved in.
Old 12th August 2017, 08:44 AM   #49
GePi
Umm, it seems the sword has come back to live.
Perhaps the listing got reposted automatically, but perhaps someone should contact the seller...
I too would like to add my condolences. Literally the same week I was delivered a shamshir (the package simply dumped in front of my apartment door without me being present) with the point literally sticking 2 inches outside of the package! Luckily no damage to the blade and no blood spurts in the surrounding area, so it seems I dodged a bullet there. Exceptionally bad packaging, from a reputable acution house no less...
Last edited by Robert; 12th August 2017 at 09:46 AM. Reason: The posting of links to any live auction or items currently for sale is strictly against forum rules.
GePi is offline   Reply With Quote
Old 12th August 2017, 10:20 AM   #50
estcrh
estcrh's Avatar
Yes and the pictures appear to be the exact same ones from the old listing, before the damage...very strange???
Old 1st September 2017, 12:05 PM   #51
estcrh
estcrh's Avatar
Another near miss, this Egyptian rolling block bayonet was shipped to me from Europe, see how it arrived, fortunately is does not seem to have been damaged.
Old 1st September 2017, 12:19 PM   #52
lucky.
me too,
my UK CG sabre arrived by courier this morning, box had been torn across by an impact midway down the length on 3 sides of the box. it was saved by the multiple layers of bubble wrap and a surfeit of packing tape over that and the one remaining box side.
Old 1st September 2017, 12:59 PM   #53
estcrh
estcrh's Avatar
Originally Posted by kronckew
lucky.
me too,
Here is a pistol that did not make it in one piece, it was sent to me from Europe but it was for some unknown never delivered and it was instead returned, the owner received it in the condition you see below.
Old 1st September 2017, 01:08 PM   #54
estcrh
estcrh's Avatar
I just sent a Persian percussion rifle to Philip Tom for a stock repair, taking into account the damage shown here you can see my successful attempt to get it to Philip and back in undamaged condition.
Old 1st September 2017, 06:51 PM   #55
rickystl
Hi Estcrh.
That's a beautiful Persian rifle!!! Looks like it "just" fit the gun case. I've found that even double-wall boxes are good for only one round trip. I wish they made those plastic gun cases for long barrels, but they don't. I've looked everywhere.
Here's a Sind rifle I sent to the gunsmith to make a small fix on the lock position where he needed the entire gun. Imagine trying to find a gun case to fit this. LOL If you've seen these guns the butt stock is not only very wide, but also very thin. So I ended up having a co-worker make me a crate from pine wood, reinforced at the corners and the middle. He actually went a bit over board with the construction. The foam is the type used over the top of hospital beds. I could have dropped this crate off a one story building and the contents would be ok. LOL!! I was astonished that the weight and dimensions "just" made the limits for USPS. But I can use this crate again.
Old 3rd September 2017, 07:26 AM   #56
Philip
Philip's Avatar
Default shipping Sind rifles
There are two types of long guns that I simply hate to ship because of packing hassles (1) the deeply recurved stocks like these Sind guns and Afghan jezails and (2) the pronounced pistol-grip butts typical of China and northern Vietnam. You have to over-engineer the packing, otherwise you're tempting fate. Commercial gun cases aren't long enough for the barrels on these guns, either (although I've squeaked under the size limit by dismounting the barrel and packing it alongside the stock, which removes a lot of stress on the curved thin wood, anyway.) But you still need a proper box...
I've had good luck buying snowboard cartons that a well-known shipping and warehouse supply company sells along with a cornucopia of other containers in all imaginable sizes. The only thing you have to order them in bundles of 5 or 10, since I'm in the restoration business that's not a problem. These cartons are 14 in. wide by about 5 thick, and about 70 in. long -- they just make it under the USPS length/girth max of 108 in. And are the only off-the-shelf size that will accommodate the two types of guns mentioned above. They are of very heavy corrugated stock and I use all the methods mentioned previously in this post to support, stabilize, and pad the contents on all sides. So far so good, although for domestic shipping I use FedEx instead of the mail.
Old 4th September 2017, 08:53 AM   #57
estcrh
estcrh's Avatar
Originally Posted by rickystl
Hi Estcrh.
Rick, nice example, how long is it? I also have one, it looks to be much longer but it is hard to tell from photos, I will find it and take some pictures and measurements.
Old 4th September 2017, 01:49 PM   #58
ausjulius
Originally Posted by estcrh
The seller should have insured it, I have asked for a refund of course. I think only a wood box or gun case would have prevented this type of neglectful shipping.
looks like the forklift hit it full force i think a gun case would have failed. must have been 1000snd kgs slammed instantly on it
