These two West African swords (need cleaning) are recent acquisitions. I havn't seen this pattern before, they seem to have a combination of styles.
Can anyone help to shed more light on them. The forested/coastal region of West Africa is very interesting but somewhat under studied... Thanks in advance. |
#2 | |
![]() Quote:
2 African swords, these are the 'blade form' of the usually ceremonial swords called 'hwi' from Dahomey (now Benin) in west Africa coast . The hilts are more known as a Sierra Leone form which usually had larger broadsword blades (some of kaskara form). Basically these are slave coast swords of mid 19th c. to latter. |
From what I can find, I think Ibrahiim is on the right lines ... most likely Fon (Dahomey) swords. However the Mende type hilts and "sandwich" style of blade attachment are a bit of a puzzle, as the Mende are about a thousand miles away from the Fon along the coast ??
Hi Colin,
when you have "panga na visu", there is on page 40 a Fon sword, very similar from handle and blade form (but here with cut outs) but also with the small "hook" at end of the spine, described as Fon sword called "gubasa". Regards, Detlef |
I think that in looking at these two 'cutlasses' which are distinctly with the curved 'hook' type tip blades with Dahomean character, and notably incongruent 'Mende' style hilts, we consider the dramatic diffusion knwn in these regions.
The Mende (of Sierra Leone) as well as the well known slave coast 'capital' of Ouidah (in Dahomey, now Benin) were among the littoral of West Africa which comprised this thousand miles of 'slave coast'. This region was still quite active in the mid 1900s, so movement of influences seem reasonable. It is interesting that the 'sandwich' type element of the blades is a well known element often seen on the blades of West African takouba in Saharan regions, and it has been noted that the Mende hilt style has been known to be mounted with kaskara type blades. This reflects diffusion of even more dramatic distances, which are well established in trade route networking over considerable periods. Then factor in tribal diffusion, warfare, and even religious influences transmitting these characteristics and feasibility is seen. These curious blade shapes are indeed representative of Fon type blades of Dahomey, and these are often known as gubasa, but in nearby Ghana similar swords are 'ada', and the Fon were in other contiguous regions as well. What is most interesting is that these blades are solid, and seemingly of functional character rather than the ceremonially decorated examples of these swords usually well embellished with pierced cutouts and extraneous features atop the blade back etc. |
I was looking at the Penn museum who write at https://www.penn.museum/collections/object/333303
Quote" See von Luschan, Altertumer von Benin, p. 440, figs. 697a and c, and drawings at end of text volume, E 696 a and c. The sword is of brass, the blade completely covered with ornament, the spaces between the designs being thickly pitted. The hilt is of wood partly covered with thin plates of brass or bronze and with copper (?) wire.''Unquote. See weapon examples below with Penn Museum weapon in black and white; |
Perfect example Ibrahiim!!
These with that distinct cross pierced in the blade seem most prolific and if I understand correctly, it is one of the varied symbols which may be connected to the Vodun religion (later Voodoo in Louisiana and Caribbean) of the Fon and Yoruba people among others. As in many ethnographic circumstances this cross symbolizes the four cardinal directions and similar meanings. Thank you for that cite as well..it really helps to have these additional references to add to the material being reviewed. |
Thanks to those who have input on these swords so far.
Thinking about them a bit more, I suppose they could have just as well been used by the Mende with influences from Dahomey weapons, as much as the reverse.. On the other hand .. the swords are heavy and robust with sharpened edges. Without being melodramatic, they swing well in the hand particularly with the extra weight towards the blade tip, in fact they seem just right for decapitation purposes ! Seemingly this was regularly done to captives (and criminals) by victorious Dahomey warriors. Here are some images from the internet, as well as an image of the hilt of a Mende sword I posted a while back, for reference. If anyone else has more to add about these swords, please do so. |
Whilst dabbling in African weapons I found this....see https://www.pinterest.com/pin/393009504964550873/
Great examples Ibrahiim!
One thing I have been wondering, That distinct four armed cross pierced into the blade near distal end on many of these.....they seem to correspond to the cross piercing on the Portuguese 15th century+ 'navigator (or 'black') swords of crab claw type in that the qullon discs of these often have such crosses. Could the Yoruba possibly have incorporated this symbol into their symbolic devices in their religion? The symbol is not necessarily consistant but seems to often occur on Yoruba ceremonial type weapons from areas from Togo, through Benin into Nigeria in variation. |
#11 | |
![]() Quote:
#13 | |
![]() Quote:
Reference; A. http://www.vikingsword.com/vb/showt...ighlight=Ibadan Salaams Martin Lubojacky ~ Indeed it seems they are the same picture and as is the Pinterest way they have simply been logged by an algorithm device. Your post directs readers to reference A and whet an excellent reference it is! I should at least try to add a few more pictures if I can find any... Yours seem to be the best . Wikepedia adds The Ida is a kind of sword used by the Yoruba people of West Africa. It is a long sword with a narrow to wide blade and sheathe. The sword is sharp, and cuts on contact but typically begins to dull if not sharpened regularly. It can be single-edged or double-edged. These blades are typically heavier by the tip of the blade. During wars, pepper and poison are added to it to paralyze anyone who is cut by the sword. It can be wielded in any way (either one-handed or two-handed). The Yoruba people use this sword for hunting, war and other uses. The blade of the sword is in an elongated leaf-shaped form. It is designed for cutting and hacking. |
In selecting this line up below there are some I have various questions about which I think I can find answers in due course thus your comments are welcomed.
My immediate reaction is that west African weapons must be related inter tribally as borne out by the similarities in these golock styles...The tendency to call them ceremonial is always there but my thought is that ceremonial may extend at least to executions... which were a sort of ceremonial ![]() The depiction of a lion is interesting as being the big cat favoured by the tribal kings and not as once suggested as some sort of spin back from the Portuguese influence in the Indian Ocean and copied or taken from Kastane in Ceylon. ![]() In that case it is on a hilt and below it appears on hilts and on the blade in cut out form. It is suggested that in the case of West African designs this is a home grown device. In looking at the cross geometry + cut into the blade; I include the Black Crab quillons device favoured by the Portuguese shown below but am unable to say if this is co-incidental or copied in regard to the tribal blade. Religion seems a far off indicator and knowing the several uses of the cross format I tend to rule that out; although black magic "as a religion" may rule this straight back in !! So some artwork~ Last edited by Ibrahiim al Balooshi; 28th August 2017 at 12:59 PM. |
The Cross.
See http://www.npr.org/programs/re/archi...interview.html This may be linked to the concept in Voodoo of a crossroads ...and as such was exported to Haiti and New Orleans etc by the advent of the slave trade. As a style of worship best described by the reference as "Jesus in the Morning Voodoo in the Evening" perhaps there is no better example of two religions living side by side, thus, it is not surprising to see crosses in tribal artifacts. On the other hand the cross is not unusual in other African cultures as seen by Tuareg jewelry and crosses therein linked to astrology. The cross in weaving and hand knotted rugs off the silk road refers or means welcome ...As a candle light insignia often seen on Yurt Rug Door Hangings called Ketchli or Yatchlu. Below illustrated cross concepts on Oriental Rugs and Tuareg Jewelry~ Last edited by Ibrahiim al Balooshi; 28th August 2017 at 07:17 PM. |
Of the Asante type shown below the British Museum says Quote"~...
Description. A state sword (afena) with slightly curved cast iron blade, pierced along the lower cutting edge with two arrow-shaped voids and an equal-arm cross motif. These voids are surrounded by punched line and dot patterns. Near the hilt there are two incised grooves filled with a herringbone pattern and five circular punch marks. The wooden hilt is bar-bell-shaped and has distinctive rounded pommels either end of the grip. The hilt is decorated with a series of carved geometric designs which were originally covered with gold leaf secured by small gold-covered (?) staples but only a small amount remains in place. Dimensions Length: 34 centimetres Width: 4.5 centimetres Condition Fair, extensive loss of gold leaf on carved hilt, with remianing traces in a fragile condition. Curator's comments It is not known when swords were introduced into area now known as Ghana but early examples probably derive from Islamic weapons that were passed down the trans-Saharan trade routes. The use of swords in Akan society was recorded by the end of the sixteenth century and they have continued to play a significant role in ritual and ceremonial contexts ever since. There are several distinct types of state swords normally found in the regalia of an important leader or paramount chief. By far the most important of the ceremonial swords are the keteanofena (literally; edge of the sleeping mat swords) which are revered and are passed from one ruler to his successor as a major portion of state regalia. This group is composed of two major sub-divisions the akrafena and the bosomfena. Akrafena, or ‘swords of the soul’ are used, as their name suggests, in fairly restricted, often private rituals for the purification of the ruler’s soul and the purification of the blackened state stools while swords in the second division the bosomfena play a more varied and public role. These two groups of swords embody and represent two distinct spiritual elements; those on the Asantehene’s right (akrafena) represent his soul or life-force (kra), those on the left (bosomfena), his ego, spirit or personality (sunsum) that was inherited from his father. Elders also swear allegiance to their ruler on these swords and they may be carried as badges of office for a ruler’s messengers. This small sword is the same shape as the larger state swords which suggests that it functioned in a similar way." Unquote. Last edited by Ibrahiim al Balooshi; 28th August 2017 at 01:57 PM. |
Hello Ibrahiim,
Thank you for such backround research.... You are right that the weapons of similar shapes were also used in warfare. As far as warfare is concerned, I think there were two main types used in the Guinea Gulf area (Dahomey Kingdom, Benin Kingdom in current Nigeria): 1.streight short swords (similar e.g. to Fang swords) and 2. machete style, often with bulbous point - which you can see on the picture. |
#18 | |
![]() Quote:
Regards, Ibrahiim al Balooshi |
#19 |
Reference;
A. http://www.vikingsword.com/vb/showth...4&page=1&pp=30 THE CROSS PART 2 The reference above is a delightful Forum Library thread with excellent artwork. SEE http://aladokun.com/african-history-...-of-the-cross/ which tables a few aspects of The African Cross. ![]() “Nkisi Sarabanda, symbolizing the signature of the spirit, is a representation of a bakongo cosmogram. This symbol portrays how the Congo-angolan people viewed the interaction between the spiritual and material world, or in other words between the living and the dead; the Congo-angolan people believe that these worlds are inherently intertwined. An Nkisi is a spiritual object used for worship purposes, and have been found in places where enslaved Africans have lived… https://www.thoughtco.com/vodou-veves-4123236 shows some interesting links between Voodoo and the Cross illustrated below and appears to represent a gateway or cross roads. This sign was transmitted to Haiti and New Orleans etc via the slave trade from West Africa... probably from slave centres and more than likely linked to the circle and crosses of the Nkisi Sarabanda.. There is a device on Portuguese Black Crab (shown below) swords manufactured in that region but with a cross incorporated in each Quillon and said to have been sharpened for close quarter work. Did this design flow from or to the Portuguese weapon or is it simply a coincidence? There seems to be no logical reason why African tribal swords would have a Christian Cross cut in the end of a blade..and the coincidental concept may be relevant but further research is needed. My suggestion backed by the above is that this is a home grown device locked into the Voodoo and like practice of regional tribes from ancient times. Regards, Ibrahiim al Balooshi. Last edited by Ibrahiim al Balooshi; 29th August 2017 at 08:50 PM. |
#20 |
THE CROSS PART 3.
Reference; A. African Art by Frank Willet page 65 cave drawings lower Congo and page 109 Egypt in Africa. ( a description of the old fashioned Myth) See above post my deliberate inclusion of the Black Crab sword and its Cross decorated Quillons and compare it with the cross design in the broad leaf shaped blades of West African tribal swords herein. The cross format has to be looked at in more detail and although there are those who from the old fashioned school who think everything is somehow related to The Egyptian Era that arguement will be addressed in a moment. For now the link between religious constructs of the Portuguese can be examined in viewing the cave drawings described in Reference A which says Quote. "at Mbafu Cave in the Lower Congo an area where Portuguese influence was very strong in the late 15th C...and where the crucifix has become a power symbol used by tribal chiefs when they sit in judgement. The crude cave wall drawings show various cross insignia but interestingly most outstanding is a group of figures; one with a pectoral cross standing on a platform; with a Latin Cross. These motifs seem to commemorate the consecration of Don Henrique, son of King Alphonso the first of the BaKongo as the first Congolese Bishop in 1518." Unquote. With this in mind and viewing the likeness to the cross on tribal blades I agree that these are linked in some way and perhaps in the power imbued in a tribal chief by the two styles of religion thus the same cross design in both ; Tribal and Christian. Turning to Egypt The author goes into simple but compelling detail in a short chapter which demolishes again the old theory that was dominant in the 19thC about Egypt and it being the source of everything! Chronology in this regard is vital. To infer direct connections without the intervening links between Egyptian objects and others made 2, 3 or 4 millennium later in Africa is dangerous. For example it has been claimed that the akua ba doll of Ashanti is derived from the Ankh, the Egyptian symbol for life, which does have its roots in the same region to 16th C terracotta dolls but nothing whatsoever to do with the Egyptian Ankh in either case. Parallel development in unrelated tribal systems seems to be the only link~ in other words a basket weave from Ancient New Zealand peoples has nothing to do with Eskimo baskets in Northern Canada. Unfortunately traces of such old fashioned and outdated influence and belief still exist in certain writers and we must be on our guard to point this out where it is found to have crept back in.... Regards, Ibrahiim al Balooshi. Last edited by Ibrahiim al Balooshi; 30th August 2017 at 05:32 PM. |
#21 |
THE BOOK... AFRICAN ART BY FRANK WILLETT IS FREELY AVAILABLE FOR RESEARCH AT http://muhomor.net/books/African-Art-Frank-Willett.pdf
#22 |
I noted an extraordinary sword example from this region with a standard hilt but zoo omorhic and geometric blade including a Cross already dealt with. The snake is particularly interesting.
![]() Wikepedia notes Quote" In Africa the chief centre of serpent worship was Dahomey, but the cult of the python seems to have been of exotic origin, dating back to the first quarter of the 17th century. By the conquest of Whydah the Dahomeyans were brought in contact with a people of serpent worshippers, and ended by adopting from them the beliefs which they at first despised. At Whydah, the chief centre, there is a serpent temple, tenanted by some fifty snakes. Every python of the danh-gbi kind must be treated with respect, and death is the penalty for killing one, even by accident. Danh-gbi has numerous wives, who until 1857 took part in a public procession from which the profane crowd was excluded; a python was carried round the town in a hammock, perhaps as a ceremony for the expulsion of evils. The rainbow-god of the Ashanti was also conceived to have the form of a snake. His messenger was said to be a small variety of boa, but only certain individuals, not the whole species, were sacred. In many parts of Africa the serpent is looked upon as the incarnation of deceased relatives. Among the Amazulu, as among the Betsileo of Madagascar, certain species are assigned as the abode of certain classes. The Maasai, on the other hand, regard each species as the habitat of a particular family of the tribe."Unquote. Tortoise Note the Tortoise between the hilt and the snake. See http://www.allfolktales.com/folktales.php for some of the important West African Myths and stories concerning the Tortoise which was revered as being the cleverest animal and a legendary force .. Last edited by Ibrahiim al Balooshi; 2nd September 2017 at 06:24 PM. |
#23 |
It may be useful here to have a basic description of Dahomey thus ~
Wikepedia Quote'' The History of the Kingdom of Dahomey spans 300 years from around 1600 until 1904 with the rise of the Kingdom of Dahomey as a major power on the Atlantic coast of modern-day Benin until French conquest. The kingdom became a major regional power in the 1720s when it conquered the coastal kingdoms of Allada and Whydah. With control over these key coastal cities, Dahomey became a major center in the Atlantic Slave Trade until 1852 when the British imposed a naval blockade to stop the trade. War with the French began in 1892 and the French took over the Kingdom of Dahomey in 1894. The throne was vacated by the French in 1900, but the royal families and key administrative positions of the administration continued to have a large impact in the politics of the French administration and the post-independence Republic of Dahomey, renamed Benin in 1975. Historiography of the kingdom has had a significant impact on work far beyond African history and the history of the kingdom forms the backdrop for a number of novels and plays."Unquote. Below I include; 1. The Benin Tribal Map. 2. The Cave Drawing from at Mbafu Cave in the Lower Congo showing the Portuguese influence (see #20 above) in the cross format illustrating consecration of Don Henrique, son of King Alphonso the first of the BaKongo as the first Congolese Bishop in 1518." . 3. The quality of hand carved Ivory in the region thus the availability of artisans giving rise also to locally produced excellent Lion and big cat carvings common on Dahomey hilts. 4. A Knights Templar Fort adorned with A Cross probably Portuguese. ( The symbol of the cross within a circle is very ancient and has played an important part in the History of Humanity. The symbol can be found in many cultures and many places around the world. From the ‘Rosy’ Cross of the Rosicrucians to the American Indians’ “Sacred Hoop”, from the “Celtic” Cross to the symbol of certain tribes in Western Africa’s Burkina Faso and Ghana.) Last edited by Ibrahiim al Balooshi; 2nd September 2017 at 09:43 PM. |
#24 |
This a great background on Dahomey (now Benin) Ibrahiim, and thank you for taking the time to add these most helpful details on the regions and people of West Africa. It is pretty complex trying to understand the various religious and incurred colonial influences that compound the character and symbolic motifs and elements so your observations also are much appreciated.
In reviewing much of the material researched and presented which concern the notable Portuguese influences which prevailed in these regions, it is of course interesting to consider the occurrence of this cross motif in many of these West African sword blades. With the Portuguese swords known variously as 'crab claw'; 'navigator' and 'black swords' colloquially, it has been established that many of these medieval form swords have equilateral crosses pierced in their discoid quillon terminals. It has further appeared that these openwork crosses seem to occur notably on examples of these swords which appear to be of colonial workmanship, thus probably produced in these West African regions. In Burton, "Book of the Sword" (1884, p.165) he describes one of these swords illustrated same page line drawing (but with simple apertures in the quillons, not crosses) , "...upon the glorious Congo river, I was shown a sword belonging to the Mijolos or Mijeres, a tribe inhabiting the upper valley. All declared it to be of native make, and used during the sword-dance in the presence of the prince. But it is an evident copy of some weapon of the 15th century; and the knightly model , like that of the mpangwe (fan) cross bow, had drifted into the African interior. The handle and pommel were of ivory, the guard was a thin bar of iron springing from the junction of the blade and grip, forming an open oval shape pas d'ane below and prolonged upwards and downwards in two quillons or branches, parallel with the hilt and protecting the hand. The blade, which had a tang for heftng, was straight, flexible and double edged". This is footnoted as well citing "The Cataracts of the Congo", p.234. Clearly the sword described is one of these Portuguese swords, and its diffusion eastward into the Congo is of course understandable. The absence of the crosses in the terminals is notable, and would certainly have been elaborated on if present, in the Victorian convention of drawing the connection to the crusades and occurrence of such weapons in native context at every opportunity. Returning to the west, and the dilemma of whether the cross in the quillons of Portuguese colonial swords of this form influenced the native swords of these 'cutlasses' or vice versa, it is surely a quandary. It is understandable that European observers would characterize the equilateral cross, if seen in native context, as a 'Greek' cross, well known in European heraldry and Christian symbolism. These were of course, the very cross of the crusades in many cases, so the previously mentioned conventions of course would likely be in place. While we have determined that these and similar equilateral crosses are probably not of the ilk of the Vodun or Obo types which seem of course in use later and with cross diffusion to Caribbean, it does seem quite possible they were known in the earlier native religious contexts of these regions. These simple crosses are well established into prehistoric times and quite universally, so much so that most scholars are inclined to consider them convergent and unlikely to be connected empirically. Still, one can imagine that the appearance of such a cross symbol would have been construed dramatically by arriving Portuguese, and vice versa, the natives seeing such device with them equally construed. The orders, such as the Order of Calatrava, certainly potentially present, might have provided such basis. I suppose the question is, just how often and in what character, were equilateral crosses used on Portuguese (or other) sword hilts, especially in pierced openwork in this fashion. It is intriguing to consider that the use of openwork designs, devices and profiling is profoundly the character of these native ceremonial 'cutlasses', and perhaps this application was carried into the colonial made swords of Portuguese form. Which came first? |
#25 |
In looking into the interesting symbol used by people in the Congo, the Nkisi Sarabanda (one of the primary deities of indigenous Congo religion) it is a 'cosmogram' configured exactly like the Jerusalem cross (attached).
This cross was significant as a coat of arms of the Kingdom of Jerusalem during the crusades (1099-1203 AD) and consisted of a cross potent with four small Greek crosses quartered. It is notable that the Nkisi Sarabanda cosmogram is configured and consisting of the same crosses as the 'Jerusalem' cross. While clearly many, perhaps even most, of the 'veve' (geometric device used to call on 'loa' or spirits) are later developed through the evolution of diasporic pantheons in the Americas and Caribbean through slave trafficking, it seems the Congo cosmogram may predate Portuguese arrivals in Africa. The similarity to the distinct Jerusalem device is compelling, and we know that trade contact and diplomatic embassies between the Congo and probably other regions were extant as early as 1246AD with Tunis and Egypt as well as others. There are often adoptions of certain kinds of symbols and devices by disparate cultures without syncretic intent, and used with their own interpretations. Perhaps this was such a case with the Greek cross as seen here in Congo/West African context. It seems that the tribal cultures in Africa in early times was much farther advanced than often realized in general, and that influences from Europe had diffused far into the interior and much of the Continent far before the European contacts recorded in exploration and colonization. |
#26 |
Thanks Jim and the geometry at #19 above ties in the diagram of the Jerusalem cross you show here... They are very similar and flowing from that the example also transmitted through the slave trade .
I have a snake worship temple to show here (at Whyda?)...and for interest following on and concluding snake worship as it enters the central Caribbean region New Orleans etc...Via the slave trade. A lady with a huge snake. The picture of the person sitting on the turtle is indicative of that creature which was viewed as being highly intelligent... The Lion – The lion is an emblem for royalty, strength, conquest, valor, pride, wisdom, authority, courage and protection. The lioness represents the moon, femininity and fierce motherhood. Last edited by Ibrahiim al Balooshi; 3rd September 2017 at 10:39 PM. |
#27 |
Reference;
A. See http://www.metmuseum.org/toah/hd/acko/hd_acko.htm The Cross Part 4 Substantial evidence exists to support the agreed Christianity Conversion in West Africa...Reference A states that Quote"Missionary documents from the seventeenth century claimed that they had found a people who believed in a single god but did not know his name."Unquote. and clearly the Cross on Swords in the region comes from that situation. This process took an opposite view to the way the Spanish did it by force compelling them to convert in South America and the Portuguese suggested that the West Africans had already found God but simply had not realized it. All they actually needed to do was convince them that this was what they already believed in ...an entirely different approach and one which was highly successful... What I have trouble with is the time line... Notwithstanding the discussion I admire very much the picture below of the Church being constructed in the early period of Portuguese presence in West Africa which I think is about 1491 although I cannot be certain.This is from #165 on http://www.vikingsword.com/vb/showth...1&page=6&pp=30 Please note the two chieftains at right with swords at the waist in typical West African machete style and consider the hilts in this finely engraved picture which so far as I can see is very accurate. Observe the Lion or big cat hilts. Sri Lanka, however,was not discovered until 1505 by the Portuguese thus this hilt form must be local by definition. I add that big cats lived in the region of course... and that the regal and powerful symbol of the chieftains was seen as enhanced with hilts of this nature. Top class carvers were common in the African region and multiple group carved examples of a highly complex nature were in fact highly prized trade items for the Europeans even before the advent there of slavery. The cross insignia was dominant across the spectrum and it is acknowledged that crosses on swords and crucifixes were worn by chiefs deliberating on tribal matters..Ivory carvings were made of Portuguese soldiers (in the traditional African style) adorned with Crosses. Below the famous scene of the Church being built and another cross decorated weapon from the region is shown for interest. Last edited by Ibrahiim al Balooshi; 8th September 2017 at 02:14 AM. |
#28 |
Other finely carved Ivory items from West African Artisans~The figure with the spear also wearing a Cross. This proves the expertise in Ivory carving in Dahomey thus in addition no reason to seek lion heads from elsewhere particularly a foreign unknown species and style from Ceylon.
#29 |
In considering the big cats... and which one... since all could be admired ...It is certain that the Lion is the fore runner in this regard. The Great King Ghezo was succeeded by King Glele who reigned from 1858 until 1889; He revered the lion as seen in the weapons of war and authority below.. and illustrating how the lion was further incorporated into weapons design...enhancing its known appearance on hilts.
#30 |
Well which was it? Lions or Leopards....This reference indicates a strong preference for Leopards...
http://www.beprimitive.com/stories-d...-royal-leopard On the other hand ...The lion was the personal symbol of King Glele, ruler of Dahomey (now the Republic of Benin) who reigned from 1858 to 1889. It was also used in a variety of objects to link relatives and would-be allies to the royal power. Below two masks One Leopard the other Lion. Last edited by Ibrahiim al Balooshi; 9th September 2017 at 11:47 AM. |
Display Modes | |
