Old 3rd August 2017, 02:33 PM   #1
Wisram
Default knobkerrie? War club?
Thank you all for sharing your passion and knowledge so generously.
I have an old club that I would like to know more about.
It is 65cm long made of two color hard wood and has a flattened head.
Here are 2 pictures and another one I found on line that look simmilar.
Is it a knobkerrie? Is it African at all?
Thank you for your help.
Wisram is offline   Reply With Quote
Old 4th August 2017, 08:04 AM   #2
colin henshaw
Its probably from Southern Africa, but not all that old.
Old 4th August 2017, 08:29 AM   #3
Wisram
Thank you.
Old 5th August 2017, 09:51 AM   #4
Martin Lubojacky
Could also be from south western Ethiopia
Old 6th August 2017, 07:28 PM   #5
Wisram
Thank you Martin.
If I may ask you both, what are the specific signs that indicate in your opinion the two possible origins?
Old 7th August 2017, 05:28 PM   #6
Martin Lubojacky
I bought nearly the same on Omo river in Ethiopia some time ago - at least the shape is the same. The bulbous part is a little bit flattened from the sides, creating something like edge. On the other side - if there are beads on the handle (see second Picture) - this is mostly the sign of southern Africa (but not only).
Old 8th August 2017, 08:07 AM   #7
Wisram
Thank you very much Martin.
