Old 12th July 2017, 02:58 PM   #1
corrado26
corrado26's Avatar
Default Small collection of Albacete daggers
I have this small collection of daggers/knifes made at Albacete in Spain. Two of them have cut-outs on their blades, one with a brass inlay. Is anybody here able to tell me what this brass inlay is made for?
Thanks
corrado26
Old 12th July 2017, 03:37 PM   #2
Norman McCormick
Norman McCormick's Avatar
No definitive answer as far as I'm aware, probably just a decorative touch. here's mine for comparison.
Norman.
Old 12th July 2017, 03:46 PM   #3
corrado26
corrado26's Avatar
Thanks for showing your Albacete dagger whose blade is obviously nearly the same then the blade of mine.
corrado26
Old 12th July 2017, 04:16 PM   #4
mariusgmioc
mariusgmioc's Avatar
Judging by the shape of the hilt, they could very well serve as plug-in bayonets.
With respect to the brass inlay, it is purely decorative... I assume.
Old 12th July 2017, 04:55 PM   #5
Judging by the shape of the hilt, they could very well serve as plug-in bayonets...
No Sir,
http://www.vikingsword.com/vb/showpo...3&postcount=10
Old 12th July 2017, 05:14 PM   #6
... With respect to the brass inlay, it is purely decorative... I assume.
So it seems ...
This part is called lengueta; it has been subject of various legends, like its purpose being to let in air in the wound or for anointing it with poision; but it is no more than an adornment.
(Forum Armas Blancas)
"El hueco en la hoja con lengueta de latón, se ha prestado a muchas leyendas urbanas. "Entrar aire en la herida" "untar veneno en la lengueta". Se trata simple y llanamente de un adorno".
Old 12th July 2017, 06:06 PM   #7
corrado26
corrado26's Avatar
Very good information, Fernando, thanks a lot.
corrado26
Old 13th July 2017, 02:17 PM   #8
Marcus
Marcus's Avatar
Default not a plug indeed
I agree that these are not suitable for use as plug bayonets. It is surprising how pervasive this misconception is. One supposition about the brass inserts (albeit also unlikely) is that they might in some cases been able to rotate 90 degrees and limit the depth of penetration, as with the cross bar on some hunting swords and spears. However, I have never seen one where the insert could swivel.
Marcus is offline   Reply With Quote
Old 13th July 2017, 04:35 PM   #9
Originally Posted by Marcus
... One supposition about the brass inserts (albeit also unlikely) is that they might in some cases been able to rotate 90 degrees and limit the depth of penetration, as with the cross bar on some hunting swords and spears. However, I have never seen one where the insert could swivel.
That would be another myth, Marcus
