Old 29th June 2017, 04:49 PM   #1
shayde78
shayde78's Avatar
Default Assistance for a keris novice
Hi all!
I'm new to learning about keris, although the form has intrigued me since I was a child. I only have one such piece in my 'collection' (if so few items can be called a collection). I am hoping some of the expertise of this forum can help me gain a more informed appreciation. I have attached pictures below. I have seen examples of very poorly executed naga that seem very superficially etched on the blade. For this piece, it seems the serpent was chiseled into the metal in a much more substantial way. Also, the edge is very thin, worn, and nicked. I'm wondering if this suggests age as I believe the acid etching done regularly can wear away the thinner parts of the metal. The hilt (forgive my use of generic terms) doesn't seem to have much age to it. The scabbard appears to be of a single piece of wood (rather than the collar being separate from the main shaft. Is this something more modern tools allow for, or does this suggest an older item.
Again, I know there are very specific words applied to each of these features, but at the risk of misusing them, and causing more confusion, I am relying on the more general terms. No disrespect intended.
Thank you to anyone who is able to provide information as to the form/style, country of origin, approximate date, etc. I am thrilled to have finally 'married' one, and will be equally happy if this was manufactured last week, or last century. I would just like to learn more.
Thanks!
Old 29th June 2017, 09:17 PM   #2
Hi Shayde, welcome to the forum.
Though your photos are not extremely clear it seems to me that there may indeed be some age on your blade, however i suspect the the somewhat crudely carved naga was done at a much later contemporary date, possibly to give what is a fairly standard, lower end blade more appeal in the marketplace. Of course there could be other reasons for the addition, but i can't think of any way to confirm why it was added. But i seriously doubt it was born with this naga.
Your sheath, as you have noted, seems to be made in one piece. We refer to that as wrongko iras, "iras" meaning one piece. That does not necessarily imply modern tools and i would say there is some age on this sheath. Wrongko iras are generally prized as they are rarer and more difficult to carve. I also like the brass (?) open-cut pendok though it seems to be a bit ill-fitted and may not be original to the sheath. The blade, OTOH, appears to fit the sheath fairly well so it was either made specifically for this blade or adapted to it. The dress is what is know as Surakarta gayaman (everyday) form.
Old 30th June 2017, 12:07 AM   #3
David, my immediate impression was that I was looking at an old blade that had been carved with the naga the day before yesterday, but as I studied it further I formed a different opinion, or rather, two opinions.
To begin, I'd place the dress as pre-WWII, the blade fits nicely so the blade was very probably as we see it, pre-WWII.
Something that used to be done a long time ago was to take very large Tuban blades and use them to produce more attractive keris. This happened in the late 19th century, through to WWII, and a few were even done in the 1950's. I'm pretty sure this died out by the 1960's, I'd guess because the great big Tuban blades that were used as the raw material had become scarce and expensive --- these days those original giant size Tuban blades are very rare, very highly desirable and very expensive.
So this keris could easily be one of the alterations based on a big Tuban blade, but from a long time in the past.
The other alternative is low quality work, probably from a village smith, but again, pre-WWII.
Either way, I'd consider this keris a pretty good start to a collection, but I would be inclined to give the dress a bit of a facelift.
Old 30th June 2017, 02:39 AM   #4
shayde78
shayde78's Avatar
David and AG,
Thank you so much for so quickly providing such useful information. You have confirmed some guesses I had about it. I too noticed how perfectly the blade fits the scabbard and thought they were indeed well matched. Also, the blade just 'feels' old aesthetically. Add to that the fact that I received her covered in cosmoline...yuck. I believe you can still see some residue in the pictures (since removed).
I will try to post some better pics tomorrow and see if that helps. Thanks again
Old 30th June 2017, 04:02 AM   #5
Agreed. I think that sheath could look pretty decent with a bit of renewal.
Old 30th June 2017, 05:33 PM   #6
shayde78
shayde78's Avatar
Thanks again. Out of curiosity, what would giving the scabbard a 'bit of a facelift' entail? Do you mean the metal components being replaced, or the wood itself? I ask because the wood is actually in beautiful condition, although that doesn't come across so well in the pics.
Here are additional images that I hope are more clear. Regarding the carving of the naga, it does appear to be integral to the blade itself (i.e. it seems as though the blade was forged with the idea of carving this figure). I am not at all familiar with the Tuban blades, and if they would afford enough 'meat' with which to work. I tried to include pictures that show the naga's head as being carved 'in the round' and being properly three-dimensional. Still, I'm eager to hear any additional impressions.
Cheers!
[note - for a sense of scale, the squares on the chess board are 2"x2"]
Old 30th June 2017, 05:35 PM   #7
shayde78
shayde78's Avatar
And just some additional views [for scale, squares on the board used for background are 2"x2"]
Old 30th June 2017, 06:25 PM   #8
Thanks for the better photos Shayde.
The pendok (metal part of the sheath) is even nicer than first appeared with these detail shots.
I remain pretty well convinced that your naga was carved well after this keris was forged. Whether that was still some time ago (pre-WWII) or later could probably still be a matter of debate, but i'm pretty sure this blade was not born to be a naga keris.
I will leave most questions of "facelifts" to others like Alan who have perhaps handled more renovation work than i have, however, if this were mine i would slide the pendok off and carefully clean and oil the wood. I might try to see if it is possible to carefully bend that pendok together a bit more at the top so that it fits more tightly to the wooded ridge on the sheath stem's center, though it may never fit quite right. I would certainly take a polishing cloth to the metal to brighten it up and maybe attempt to clean up the mendak (hilt ring) a bit. Keep in mind that keris dress is meant as an outward display during public wearing. Leaving tarnished metal parts would not be the way this keris would be maintained within the society.
Old 30th June 2017, 08:49 PM   #9
mariusgmioc
mariusgmioc's Avatar
But only if the pendok comes off easily! It might be the case the pendok is firmly stuck to the wood, and in that case I would leave it as it is and limit myself to giving it a gentle polish with a polishing cloth.
... well, at least that's what I would do.
Old 30th June 2017, 11:02 PM   #10
David's comments pretty much echo what I am thinking.
If I wanted to lift the appearance of this wrongko I would do this:-
1) Remove the pendok. If it does not slide off easily, gently heat the back of it, for this heating I use a gas torch turned right down low, because I can precisely direct the heat, but any source of heat will do, just be careful not to get heat directly on the exposed wood.
2) The problem with the pendok appears to be that a slorok --- the contrasting under layer that can be seen through the pendok open-work --- has been fitted, but fitted very untidily and without making room for it by scraping down the back of the gandar (the long section enclosed by the pendok). Fit the slorok so that its edges do not protrude beyond the edges of the pendok, and remove sufficient wood from the back of the gandar to permit a tidy fit. Easiest way to remove wood from the back of the gandar is by scraping with a small blade.
3) Polish the pendok with a Scotchbrite pad, and finish polish with 0000 steel wool and then an impregnated polishing cloth. It is very difficult now to get polishing cloths specifically for brass and bronze, but a silver polishing cloth will work OK. You can use various grades of steel wool instead of a Scotchbrite pad, but if you use steel wool be very, very certain to get rid of any residue. Don't forget to polish the slorok.
4) Clean the wooden scabbard with a good quality furniture oil, not a wood finishing oil, but the sort of furniture oil that is used on fine furniture, allow to stabilise well after polishing, then use a good quality furniture wax and polish.
5) It might be a good idea to clean out the inside of the scabbard while you're at it, a rifle cleaning rod with .22 bristle brush is good for this, followed by blowing out with compressed air.
6) Put the scabbard back together making sure that it all fits together neatly.
For the hilt:-
1) Remove hilt; you might have some problems with this, if it does not twist off relatively easily tell us and we can pick that problem up later
2) Hand-rub the hilt with a couple of drops of baby oil, brush out the carved sections with a hard tooth brush.
3) Soak the mendak (hilt ring) in white vinegar then brush vigorously with a toothbrush under running water to remove the loosened tarnish and dirt and residual vinegar.
For the blade:-
Probably just a spray with WD40 followed up by application of a light machine oil. Allow to drain off before replacing in scabbard. Actually there are much better ways to long term store a keris than this, but if you wish, that can be addressed later, or you can just trawl back through the old Forum posts, I think this blade storage thing has been gone over a number of times.
Tuban Blades
The very large, old Tuban blades were more than big enough to permit a normal sized keris to be carved from them.
Old 1st July 2017, 04:01 PM   #11
Jean
Hum, I am frankly not too impressed by this blade and would not like to waste an old Tuban blade to achieve this result!
Old 1st July 2017, 09:39 PM   #12
Neither would most other collectors in this day & age, Jean.
But things were different in the past.
If this blade is the result of an alteration, it is most definitely not a recent alteration, its old.
As for untouched Tuban blades of the giganticous ilk, well, they have all but disappeared, and when they do surface they bring a very good price, because of their rarity, a rarity caused in the large part by being altered to satisfy the market.
Something similar happened with Balinese blades, nearer to our own time.
Old 1st July 2017, 09:52 PM   #13
Bjorn
Does anyone have a photo of an actual Tuban blade? Preferably side by side with a blade of average size. I don't recall ever seeing one before, even though I've seen the name Tuban used quite often.
Bjorn is offline   Reply With Quote
Old 3rd July 2017, 03:51 AM   #14
shayde78
shayde78's Avatar
AG,
You state that the blade is old with such certainty. I would love to learn how such a determination is made from the photos provided. Is it the pamor, the condition, or just hard earned experience?
Also, to piggyback on yuuzan, are there pics available of a legit Tuban blade?
Old 3rd July 2017, 08:12 AM   #15
A post in the wrong hole.
Old 3rd July 2017, 08:16 AM   #16
Its just experience Shadye.
+60 years worth.
That plus the fact that I've handled literally thousands of blades and have been taught by probably the best and most knowledgeable teachers of their generation, two of whom were Surakarta Karaton Empus.
There is a good Tuban blade shown in this thread, and Jean has shown a pic of one of the super-size Tuban blades:-
http://www.vikingsword.com/vb/showthread.php?t=22862
Old 6th July 2017, 03:04 AM   #17
shayde78
shayde78's Avatar
Thanks again, AG.
I had found that turban thread too. Some properly beautiful examples.
There isn't much to provide scale in those pics...but it appears the blades have a more or less uniform lozenge-shaped cross section. That seems different from the piece in question, no? Could mine have been subjected to some serious stock removal?
Old 6th July 2017, 08:51 AM   #18
How do you reckon this blade might have looked before it was carved with a naga, Shayde?
Whether it was carved from an old Tuban, or some other old, beefy blade, or whether it was forged with the intent of carving it with a naga, it is absolutely certain that the cross section was way different to what you can see now.
Old 8th July 2017, 03:06 AM   #19
shayde78
shayde78's Avatar
I don't have an answer, other than to note the blade is now thin (compared to a tuban), so a great deal of material must have been removed. Seems like a loss
Old 8th July 2017, 04:59 AM   #20
Originally Posted by shayde78
Seems like a loss
Generally speaking it is...
