Old 27th February 2017, 09:19 PM   #1
danny1976
Default Enggano spear / Ekajo
For sharing this Enggano lance ( comments and discussion are appreciated )
Last week I had the luck to bump up against some stuff that belonged to a Dutch family that had lived on Sumatra before the second ww.
My intention with buying the lot was to resale it again , but after handling this spear i decided that I kind of like it so it stays.
You don't see them so often and in my eyes the are very primitive but that is the charm of it.
Need to clean the point from the rust , the point also is a little loose because the binding and the damar did expand ? , the point is still attached but it wiggles ...
Some one a idea how I can get it tight again ?
There is some motive at the bottom of the point and also there is a small piece of tinn ( i ques ) on the shaft.
And a great patin and old dirt on the shaft also.
greetings ,
Danny
danny1976 is offline   Reply With Quote
Old 27th February 2017, 10:16 PM   #2
asomotif
asomotif's Avatar
Hello Danny,
Typical enggano lance.
The point is fixed with rope and resin. I would not touch it to much as it is fragile material.
The point wiggles.... Ok, in case you need to go hunting, pick another lance from the wall :-)
cleaning the point. also here, I would suggest to clean it carefully.
A lot of these lances are rusty, you can also decide to just apply some oil for conservation.
Ps. does it have a decoration on the shaft ?
Willem
Old 27th February 2017, 10:24 PM   #3
danny1976
Hi Willem,
The point wiggles a lot .. just come over and see than you see what i mean
About cleaning the point , i do not want to over clean it but stabilizing the rust is necessary.
I did look for decoration on the shaft but didn't find it but maybe under the dirt but i leave that like it is.
Ps... check your mail .
greets
Old 27th February 2017, 10:54 PM   #4
The dirt looks like deteriorating varnish or shellac applied by a past owner.
Old 28th February 2017, 07:36 PM   #5
danny1976
Hi Rick ,
I have to check what you are saying , but then only the upper part is in the lacquer .
It's only lets say on the 3th of the shaft , the upper part.
Any idea how i can check if it is some kind of finish ? Because when it is not i will regret the cleaning.
Old 28th February 2017, 08:28 PM   #6
Albert
Albert's Avatar
Thumbs up Nice!
On the top right photo an Enggano spear with a similar small metal plate.
(Photo's page 105 of: Traditionele wapens van Enggano. Een verdwenen cultuur van de Indonesische archipel. [Traditional weapons of Enggano. A lost culture of the Indonsian archipelago])
BTW is is a pity that you decided not to sell this item
Albert is offline   Reply With Quote
Old 28th February 2017, 09:23 PM   #7
Originally Posted by danny1976
Hi Rick ,
Maybe a bit of acetone applied in a small patch with a cotton swab somewhere unobtrusive would tell you something; although I would think a collector would have coated the entire haft with shellac/varnish.
Old 28th February 2017, 09:49 PM   #8
Hi Rick,
it will be "smoke" patina. Weapons of ethnic groups often keep their weapons in the "house"/hut near the open fire. One reason was that insects don't like smoked wood, an other that it's dry near the fire, think about the climate over there, so an iron weapon don't rust fast!
Old 1st March 2017, 09:10 AM   #9
Exclamation
Acetone will pretty much dissolve any residue regardless of origin - I won't go that route.
Detlef may be quite right that these are fat and smoke deposits from cooking.
Since this is a kinda "tribal" piece, I'd leave it as is.
Old 1st March 2017, 09:22 AM   #10
Hello Danny,
Thanks for sharing this nice find!
It will be tough to stop the spear head from wiggling (anything done should be fully reversible if you want to follow museum standards). You could try to gently squeeze in some durable foam; however, the increased pressure (even if fairly light) on the braiding may result in cracking of the fibers and would be a shame...
BTW, any signs (hole, broken remnants) of small spikes inserted into the braided ferrule? Often at the base of the ferrule (opposite of the plate?) and/or integrated into the braiding.
Old 6th March 2017, 10:27 AM   #11
danny1976
Hello Kai ,
I did check for small nails under and in the braided ferule , but no signs of such thing .
Maybe it is there but hided under the resin
Danny
