Old 7th January 2017, 04:11 PM   #1
Marcus
Marcus's Avatar
Default Two Badeks for comment
These two little gems came from Oriental Arms. The one with the silver scabbard I got some time ago and the other was a recent acquisition. Artzi attributes them both to Java but Zonneveld indicates that bakeks were used on Sumatra, Madura and Sulawesi as well. Anyone able to offer a more specific association for either one of these?
Marcus is offline   Reply With Quote
Old 7th January 2017, 04:39 PM   #2
Hello Marcus,
sadly I have to correct Artzi again, the first one isn't a badik but a sekin from Sumatra, Padang Highlands, the "greneng" at the base, called a'jour, is the giveaway also the typical bird shaped handle is typical for this daggers. A very nice example! I still look byself for a dagger like this. Artzi has sold in the past already some of this daggers but has described them every time as badik. Search here in the forum with the keyword "sekin", you will find a few examples. But the name sekin is also used for a short sword from the Batak people, see T.W.O.T.I.A. from Albert G. van Zonneveld, page 119.
The dagger in down is indeed a badik and here I am with Artzi, I think that this one coming from Java. Also a nice example.
P.S.: forget, both pieces could need a little TLC
Old 7th January 2017, 04:49 PM   #3
Marcus
Marcus's Avatar
Default Sekin
Thanks for pointing that one out.
Marcus
Old 7th January 2017, 04:50 PM   #4
Regarging sekin look here: http://www.vikingsword.com/vb/showth...ighlight=sekin
Old 7th January 2017, 04:52 PM   #5
Marcus
You're welcome!
Old 7th January 2017, 06:54 PM   #6
mariusgmioc
mariusgmioc's Avatar
Hello Detlef,
What is "TLC?"
Old 7th January 2017, 07:51 PM   #7
Norman McCormick
Norman McCormick's Avatar
Hello Detlef,
What is "TLC?"
Tender Loving Care
Old 7th January 2017, 09:57 PM   #8
Thank you Norman!
Old 8th January 2017, 12:53 AM   #9
Silver one is Jawa.
Old 8th January 2017, 11:00 AM   #10
Here a sekin which was sold recently by ebay. This one is without file work at the base.
Old 8th January 2017, 08:39 PM   #11
Maurice
Maurice's Avatar
Default Sekin, Padang highlands
Here another sekin, 40.5 cm in length.
This sekin is now in the collection of a good friend.
Maurice
Old 8th January 2017, 11:22 PM   #12
Sorry,
write down this in remembrance of an own search by Oriental Arms, but have found two examples by the keyword "sewar" instead of "badik". Sorry for any confusion.
It has been this both pieces.
Old 8th January 2017, 11:33 PM   #13
Hi Maurice,
unusual piece, never seen such a handle by a sekin. But I would call it as well as sekin, maby other origin?
Old 9th January 2017, 01:39 PM   #14
CharlesS
CharlesS's Avatar
TLC...on the silver one I would suggest at least an oiling of the blade to remove as much light rust as possible, and some ammonia and a soft brush to remove the unsightly old polish residue on the scabbard.
Old 9th January 2017, 02:34 PM   #15
Marcus
Marcus's Avatar
Default Another "sewar" that's a sekin
http://www.oriental-arms.co.il/item.php?id=705
Detlef,
Do you agree?
Old 9th January 2017, 02:34 PM   #16
Yes, this I have meant. And the handle of the sekin could use some oiling.
Old 9th January 2017, 02:37 PM   #17
Hi Marcus,
no, I think it's a little bit unusual sewar. Unusual because the file work at the base of the blade. Handle and scabbard are typical for a sewar.
