Old 3rd December 2016, 08:50 PM   #1
Kubur
Kubur's Avatar
Default Targui
Hi Guys
Any ideas about this blade?
Date or origin?
Thank you
Old 3rd December 2016, 10:02 PM   #2
Look like a takouba, think Ian will comment soon!
Old 4th December 2016, 06:54 PM   #3
TVV
TVV's Avatar
These blades are never easy to determine, as blanks in an older broadsword style were produced in Solingen until well into the 19th century. Markings often do not help much either, as many of them were applied locally. And then there is the possibility of a local blade imitating a European import. The hilt itself looks much newer, from the 20th century.
Iain has studied hundreds of takouba and has developed a good feel for these blades, hopefully he will respond. In the meantime, I would start browsing examples on his site with similar style blades:
http://takouba.org/catalog/index.php...-fuller-blades
Sincerely,
Teodor
Old 4th December 2016, 07:30 PM   #4
Kubur
Kubur's Avatar
Thank you both
I fund something similiar on his beautiful website
http://takouba.org/catalog/index.php/blades/takouba-123
It looks very similar - number 123- in the Tabouka Chinese menu...
Kubur
Old 5th December 2016, 10:07 AM   #5
Iain
Iain's Avatar
Mounts look to be 20th century.
The blade I think is not that similar to the example linked from my site. The blade profile is dramatically different.
I think this one is locally made and probably early 20th century. Are there any blade marks?
Old 5th December 2016, 03:14 PM   #6
If this is the turn of the 20th century, then it might have been part of the Mahdist movement of that time.
Old 5th December 2016, 04:06 PM   #7
Iain
Iain's Avatar
Unlikely as I think it's definitely later than that and its not from Sudan.
Old 5th December 2016, 05:23 PM   #8
Kubur
Kubur's Avatar
Thank you for your help
Maybe I don't know.
i looked again and you are right.
No I can recognize locally made blade. It's an import but i don't know from where... The marks are not easy to see, but yes they are some.
Old 5th December 2016, 05:45 PM   #9
Iain
Iain's Avatar
Maybe I don't know.
Do you have the sword in hand. If so post more detailed photos. I've handled quite a few, including the same single fuller and flat profile, it was locally made. But it's your sword... Look for grind marks in the fuller.
